Engine Swaps Discussion of engine swaps. |
05-29-2017, 03:34 PM | #29 | |
Drives: 2015 Raven V8
Almost every single problem I've run into in my build has come down to garbage used/cheap parts. Spun bearings on a high km engine, T56 blowing up, cheap fans not cooling enough, etc. Even if you get a cheap LS engine, the rest of the parts to do the swap don't get any cheaper. You could easily spend more on little swap parts than the cost of the engine. I don't regret my build at all but I wish I had the money some of these guys have so I could have done it all with new reliable parts. Even now I'm driving around with a T5 transmission temporarily until I finish building my new trans. |
The Following 3 Users Say Thank You to wutsaiu For This Useful Post: |
05-29-2017, 04:59 PM | #30 | |
I Love custom Turbo kits
Drives: Limited BRZ
05-30-2017, 08:18 AM | #31 | |
Drives: 2016 Subaru BRZ
And as for 100k... not to sound like my dad, but that's literally just getting broken in for those engines. My buddy tunes as a side job and one of his client's 4.8 finally died at 600k miles. I myself had 165k on my old 4.8 before I sold it like an idiot. There wasn't a thing wrong with the motor. As for old T56s. Well, rebuild it yourself if you need to. Or find a different transmission to use. I'm seeing $3k on Jegs for a "new" T56 from Hurst. You may not believe in inexpensive LS power, but I don't believe in inexpensive engine swaps, period. It can all be done for cheap but it takes patience and networking and weekends traveling to junkyards (which is why I abandoned my last project). And finally, "inexpensive LS power" is just that, no one said anything about transmissions, lol. |
05-30-2017, 08:33 AM | #32 |
And FYI, 2007-2010 are the GM truck engines to avoid. But I'll concede they really shot their own reputation in the foot with that AFM garbage.
But even during those years, not all LS truck engines had AFM. None of the 4.8s had it. Not all of the 5.3s had it. And if you can get a 6.0 non-AFM 2500 work truck engine, those are even more bulletproof than the others. |
05-30-2017, 09:57 AM | #33 |
Drives: RAVEN
My point would be that if you build a car with used parts, your results are going to be a used car; with all the unpredictability and ongoing maintenance issues of that class of car.
Even if you use recycled parts, the total project is going to cost silly money, and even with new and/or rebuilt parts, you are going to have enough little things to debug over the first year of driving, that the fewer used parts you use the less frustrated you will be while you sort the car ( and probably end up spending the time and money that you saved the first time.) My current project uses either all new or rebuilt components for every system. The goal is to build a new car, not one that needs the ongoing maintenance of a 100k + old beater. So, yeah, if you are building a GRM Challenge car, then I am all for make shit work, cause you are going to scrap the thing after the party, but if you are building a hot rod for the old lady to DD, then don't skimp on the parts. |
05-30-2017, 04:02 PM | #34 |
If you're buying all new parts, nothing will be cheap. Period.
And I'll reiterate that 100k miles isn't anything to a domestic V8. I'd give one to my wife to DD. |
05-31-2017, 09:11 AM | #35 |
Drives: Limited BRZ
I agree with that ^
05-31-2017, 11:07 AM | #36 |
Road-hole
Drives: 2013 Whiteout FR-S
20K USD...
Not 20K quid, 20K USD, 20K quid would be like 26K usd...besides selling original motor trans etc makes the net a lot less if you do it right, especially if you can fab yourself. Me, personally, I would never do a swap if I couldn't do the majority of the work myself.
Jaden |
05-31-2017, 05:03 PM | #37 | |
Drives: GT86 Harrop S/C
05-31-2017, 07:22 PM | #38 | |
Road-hole
It's more difficult probably for you over in the UK.
For instance, wrecked camaro ss' are going for like 6-10K. Having a donor car can give you access to a lot more parts that when having to fab them or purchase them separately would cost a lot more. If you can get one at auction on the low end, say $6k, then a kit, colin's can module, then sell your engine and trans, be able to weld and fab some stuffesses yourself, you can walk away spending only about 12-15K, including supporting mods. In fact I bet with some body work and or a wide body kit, you could weld up some rear sub frame adapters that would allow you to just use the camaro IRS and Big brakes in the rear, giving you stronger axles, stronger rear end that's easily modifiable with final drive gear sets etc. all included for the cost of the wrecked camaro. Jaden |
Similar Threads | ||||
hate me now | Gilwith1l | Engine, Exhaust, Transmission | 47 | 03-31-2014 01:50 PM |
Hate the car above you. | Jive Turkey | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 11-15-2013 02:24 PM |
Hate the car Above you. | Jive Turkey | Other Vehicles & General Automotive Discussions | 28 | 11-14-2013 11:17 PM |
I hate it when... | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 255 | 03-13-2013 01:57 AM |
much hate for the FRS | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 180 | 09-08-2012 08:36 PM |
