| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 |
Enthusiast 86
Drives: Toyota 86 GT
I supposed it can be used for both, but mainly while parking in tight areas.
The plan is to install an android head unit then use the wifi function of the head unit to wireless connect to the camera. As at the moment I just got a phone mount and my android phone. |
#30 | |
I love peanut butter
Drives: 2013 SWP BRZ Limited
I think your setup will be just as easy running a wire from the cam to the radio -- I don't know why you're trying to get fancy with a wifi connection. Wired cams are dirt cheap and simple to set up. |
#31 |
Enthusiast 86
The problem is one port will be used for the reverse camera, so not sure I how I wire it up to the head unit. The camera has a lot of interesting flexible wires that allow you to change the reverse view and enable and disable lines on the picture.
However, it has a remote wire on that I think is causing a problem for me - I think its suppose to be ideal situations as a reverse camera so when you go into reverse it turns on via remote wire. As at the moment I haven't got it to work for some reason there is no picture. |
#32 | |
#33 |
Enthusiast 86
I am going to see an electronic guru at my University who does a lot of soldering and geeky wiring I am sure he will point me in the right direction, but it seems to me that the trigger wire is the problem here or the voltage is being drained somewhere.
Here is an example of it how wired up: |
#34 | |
I was in the same boat as you when I added a reverse camera since my camera requires 12VDC. Take a look at this thread, I explain a bit how you can easily fix the issue. Some people, and as your instructions indicate, tap into the wire that powers up the reverse lights, but I would advise against this as a power source. |
#35 |
Enthusiast 86
I connected the wifi transmitter to the battery, it seemed to work as before my old camera. I tried to connect the new camera to the battery with a switch, so I can turn off the wifi transmitter and camera when I don't need to use it and not use power on the battery. The only wire that I did not connect was the remote wire, I didn't really know what to do with it.....I assume at the time after a lot messing around that it's why it's not working or the wifi transmitter has packed up as I can no longer reset the wifi transmitter to the factory default.
I am holding back connecting it directly to the factory head unit as I want to upgrade in future to an Android version. I see what my Guru friend makes of it, maybe he can work his magic on the wires. |
#36 |
You need the remote wire to be connected because that is what tells the camera to turn on. If you're familiar with car audio amplifiers, it's the same principle as the remote turn-on wire on the amp. While the camera has power being fed to it, it's not being 'turned on'. You should try connecting the remote wire to 6 VDC+ and see what happens.
Here's how your wires should be connected:
#37 |
Enthusiast 86
Ah yes, the more I talk with you the more it's making sense now, yes I remember back in my younger days when I installed an amp in my older car, remote wire tells the amp when to come on when you switch the car stereo on.
I've sent an e-mail to the supplier asking for the remote voltage spec Here is the 903 wifi transmitter spec: https://www.amazon.com/WishRing-Back...TTSX872RV1062V |
#38 |
@FRS2017
Based on the images, it looks like the transmitter does not have a turn on wire--when it gets power, it turns on. You will need a relay if your radio outputs 6V on the reverse wire, which you need anyway to power the camera since it also needs 12V, so this doesn't require any extra work/wiring. It's very easy to wire up, I would even do it for you if you cover the cost of parts. |
#39 |
Enthusiast 86
I'm guessing the camera remote wire is 12volts, as it says under IMPORTANT part of the picture.
What are we talking about price here? - I have a current switch for the Wifi transmitter, so how is the remote wire going to work? - some sort of loop back to the 12volts wire or something? - As I said I am waiting till I can save up for the Joying head unit, which looks like the perfect head unit upgrade for the Toyota 86. I appreciate the input though it's certainly clear things up
#40 | |
Relay is only a few bucks, plus shipping the stuff to you. I have a unit sold by Eonon, same family of android radios as Joying. Perfect fit and I love it. This pic is 2 years old with the first cf wrap that I did.
#41 |
Enthusiast 86
I live in Australia, I'm not sure where you are based?
Just got a reply from the supplier: Power Supply 12V DC (3.3V IN) Current 3.3V/60mA, 12V/120mA Last edited by FRS2017; 05-16-2017 at 01:12 AM. Reason: updates |
#42 | |
Power supply voltage is not what you need, you need to know what voltage goes to the trigger/turn-on wire. |
| whiteout with vinyl wrap white carbon fiber bumper? | 914_WHITE_FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 04-26-2014 04:16 PM |
| Testing New 4D Carbon Vinyl Wrap. | ImpressiveWrap | Southern California | 11 | 03-03-2014 05:22 PM |
| Good carbon fiber vinyl wrap for ABS spoiler to wrap it? | dssence | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 02-07-2014 05:31 PM |
| partial carbon fiber vinyl wrap on OEM spoiler? | BRZPDX | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 03-16-2013 10:12 PM |
| carbon fibre vinyl wrap | tibsy92 | AUSTRALIA | 41 | 08-06-2012 09:22 PM |
