Old 01-30-2017, 10:08 PM   #29
ztrevs
ztrevs's Avatar
Drives: 17' CWP BRZ ------- 15' GLA45 AMG
Originally Posted by justinco View Post
Apparently there is a bolt on the underside of the tip. You can loosen said bolt, and slide the tip back and forth for desired tip effect. I am going to be testing it out this week!
(really I'm just going for more tip lines from jefe )
PLEASE make a video on this! Would be super interested on how this works and will do it on my own as well!
ztrevs is offline   Reply With Quote
Old 01-30-2017, 10:18 PM   #30
JohnnyK
JohnnyK's Avatar
Drives: 2013 BRZ Sport Tech
Err, I don't think a video is necessary. It sounds just like 99% of all exhaust tips with a set screw (or bolt pulling it together like a clamp). Loosen set screw/bolt, adjust, tighten set screw/bolt.
JohnnyK is offline   Reply With Quote
The Following User Says Thank You to JohnnyK For This Useful Post:
funwheeldrive (01-31-2017)
Old 01-30-2017, 10:35 PM   #31
jvincent
jvincent's Avatar
Just an FYI, the odds of actually loosening the screw on the exhaust tip successfully, i.e. not snapping the head off, are close to zero unless the car is brand new.
Old 01-30-2017, 11:04 PM   #32
BboyRuda
BboyRuda's Avatar
Drives: Series.Yellow BRZ
How come?
BboyRuda is offline   Reply With Quote
Old 01-30-2017, 11:16 PM   #33
jvincent
jvincent's Avatar
Nearly everyone has ended up either cutting them off or using a hammer to bang it off.
They simply get corroded and the bolt has a small diameter and it just snaps off.
Old 01-30-2017, 11:54 PM   #34
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I'll be doing a follow-up of this video where I will go over the exhaust tip adjustment, plus some solutions for the other dislikes.
Exhaust tip adjustment looks pretty simple like Johnny mentioned...
justinco is offline   Reply With Quote
Old 01-31-2017, 12:46 AM   #35
RallySport
Drives: FRS
Originally Posted by extrashaky View Post
I love mine, well worth it.
RallySport is offline   Reply With Quote
Old 01-31-2017, 01:32 AM   #36
~el~jefe~
Drives: 2019 MX-5 RF
ok, so you grab the nut, twist it hard, then slide the tip back and forth till it is elongated. Got it. I recommend some lubricating copper grease on your nuts to keep them healthy and shiny for years to come.
~el~jefe~ is offline   Reply With Quote
The Following User Says Thank You to ~el~jefe~ For This Useful Post:
justinco (01-31-2017)
Old 01-31-2017, 01:35 AM   #37
~el~jefe~
I have a lot of *similar* videos to this in my private dvd collection in my closet.
Old 01-31-2017, 08:53 AM   #38
Here's a photo where you can see it. The one on the right is the OEM one that came on the 2013, but it's basically the same. The bolt that was holding it tight (its basically as set screw) is on the left. This is from my Owner's Journal where I replaced mine.
ztrevs (01-31-2017)
Old 01-31-2017, 09:10 AM   #39
Is there any difference to Jefe's process when dealing with a big black one?
Dadhawk (01-31-2017), daiheadjai (01-31-2017), goldenfri (01-31-2017), Ultramaroon (02-10-2017), why? (02-01-2017)
Old 01-31-2017, 10:16 AM   #40
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
Might need some more of that copper lube to make sure it slides in without problems
Barefootdan is offline   Reply With Quote
The Following User Says Thank You to Barefootdan For This Useful Post:
~el~jefe~ (01-31-2017)
Old 01-31-2017, 10:17 AM   #41
XK4
XK4's Avatar
Drives: 2017 BRZ, Pure Red with PP
Penetrating oil and patience may help.
XK4 is offline   Reply With Quote
The Following User Says Thank You to XK4 For This Useful Post:
Old 01-31-2017, 10:21 AM   #42
jvincent
jvincent's Avatar
I tried the penetrating oil, but clearly my patience wasn't enough. Mine had been through two winters or salt and grime as well so my odds were pretty low.
2017 BRZ things I hate. 1+CAN+1 CANADA 32 05-23-2017 10:50 AM
dislike your plain Toyota key? check my custom flip tibsy92 AUSTRALIA 38 02-22-2014 10:24 PM
3 likes, 1 dislike RaceR Scion FR-S / Toyota 86 GT86 General Forum 36 12-18-2012 06:11 PM
dislike about the FR-S xc Scion FR-S / Toyota 86 GT86 General Forum 83 11-28-2011 11:56 PM
