Old 07-20-2012, 03:20 AM   #29
Boxer-4
Drives: Toyota
[ame="http://www.youtube.com/watch?v=K3PZE-L_jNQ"]Toyota GT 86 Nürburgring Nordschleife Onboard 2012 - YouTube[/ame]
Boxer-4 is offline   Reply With Quote
Old 07-20-2012, 04:42 AM   #30
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
regardless of the the lap time that video looked way quick enough for me.
Old 11-13-2012, 05:14 AM   #31
David1976
Drives: GT86
Nice wobble at 6.30...
David1976 is offline   Reply With Quote
Old 11-13-2012, 10:25 AM   #32
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by justaquestion View Post
If the twins are just about having fun driving, than why do you all post things like "If the FRS had better tires the outcome would be different". This site has so many fanboys that change their perspective of the car to accommodate the situation.
I had a long reply and realized I was getting too wordy. To put it simply:
This car is not holy or sacred, neither is the tire choice. The stock tires are perfect for what the car was sold as, but inappropriate for any sort of performance driving. Tires, in general, are the easiest and most important way to tune your car; even the most un-handy owner can swap on a set of track tires. So saying a car will do better with better tires in a performance environment is perfectly appropriate. It's not fanboy-ism, it's step #1.
Old 11-13-2012, 10:40 AM   #33
wbradley
Sarcastic SOB
wbradley's Avatar
Subtact the straigtaways and you have a car that beats many many others. Add the straightaways and you get beaten by high powered SUVs among others.
Also, drifting around corners doesnt necessarily get you the fastest lap times. It is fun as hell and it does allow you to approach corners a lot more agressively. I watched a bunch of Initial D anime last night so now I get the "drift".
I think to sum up this car, it allows you to have fun without fear of what happens when you reach the friction limit. Many other cars might have higher limits (tires can change that), but few cars are so predictable and stable beyond.
Nordschleife is irrelevant unless you set the car up specifically for that course. The claim to fame is that it's used for benchmark times on super cars with super power. I am sure the chassis itself could preform very well numbers wise with some modification to the friction devices at all 4 corners and more agressive springs/dampers. For the straightaway, either remove them or you need more power to compare times to the big boys.
My only concern with adding more power is that it has to be in a form that can be modulated similarly to stock to maintain the drift control. Makes me think more about adding in a S/C.
Old 07-19-2013, 09:56 AM   #34
davidp
Drives: BRZ Limited
I destroy these times in gt5 and the times are pretty much spot on with other cars.. i think this car can do 8:40 bone stock if the driver has the guts to push it
davidp is offline   Reply With Quote
Old 07-19-2013, 10:28 AM   #35
STV3
Señor Member
STV3's Avatar
Originally Posted by davidp View Post
I destroy these times in gt5 and the times are pretty much spot on with other cars.. i think this car can do 9:40 bone stock if the driver has the guts to push it
Im guessing you meant 8:40?
Looks like ill have to blow the dust off my PS3 and logitech steering wheel today and see what I can do
STV3 is offline   Reply With Quote
Old 07-22-2013, 12:37 AM   #36
davidp
Drives: BRZ Limited
My personal record is 8:32.. stock car with oil change and that s it
Old 07-22-2013, 03:57 AM   #37
BentAnat
Drives: 2013 86 STD SPW
Having read the article (thank you, German upbringing), the laptime is less interesting than the rest of the piece.
Essentially (for those who aren't German speaking), the piece talks about the different corners, the stability and the fun on the Nürburgring more than the laptime. The Laptime is disregarded as "Not representative, thanks to mixed conditions" and concluded with a tone along the lines of "Well, we don't care, let's go again"...
That's kinda what this car was built for. Anyone expecting a GT racer's speed should rather buy hot-hatch... :P
BentAnat is offline   Reply With Quote
Old 07-22-2013, 04:44 AM   #38
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
Originally Posted by 7thgear View Post
what do you mean laptime is meaningless
this isn't a drag strip, this is the ring! 170 turns.
also the problem with lightweight cars is that it's harder to drive them at max speed on highspeed courses because it's just so damn scary to go into corners without much braking :/
you got that backwards. Cars with more power are scarier to drive. Light weight cars are very easy, especially this car being so noob friendly.
bkblitzed is offline   Reply With Quote
Old 07-22-2013, 05:44 AM   #39
Re_Invention
Re_Invention's Avatar
Drives: '22 Tacoma, '19 Macan, '22 BRZ
Originally Posted by BlaineWasHere View Post
The Ring is a power track. Wanna post a fast time bring your 427 Vette.
Why the convertible??? I'd say a Gran Sport is fast on any track, not just the Ring.
Re_Invention is offline   Reply With Quote
Old 07-22-2013, 06:51 AM   #40
autogyro
Drives: Toyota 86 GTS
To all those who think the GT86 would be easy to drive at the 'ring:
http://www.carscoops.com/2013/06/toy...s-painful.html
Never undestimate how much someone can noob it up
autogyro is offline   Reply With Quote
Old 07-22-2013, 09:39 AM   #41
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Convertible? Any LS7 powered Vette is a "427" that's the C.I. of the motor. The Grand Sport is LS3 powered.
Old 07-24-2013, 10:54 AM   #42
Re_Invention
They also have a model specifically called the '427'
http://www.chevrolet.com/corvette-42...ports-car.html
No harm no foul :happy0180:
CONGRATULATIONS TOYOTA! TRIPLE WIN FINISH AT 24 HOURS of NURBURGRING!! Moto-P Scion FR-S / Toyota 86 GT86 General Forum 59 05-29-2012 12:39 PM
Great video of GT86 VLN racer on Nurburgring Sport-Tech FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 05-16-2012 12:59 AM
Predict the Nurburgring Lap Time for the FT-86 bofa Scion FR-S / Toyota 86 GT86 General Forum 170 03-31-2012 11:37 PM
Toyota captures Nurburgring EV record 1660 Other Vehicles & General Automotive Discussions 2 09-01-2011 03:05 AM
Toyota looks to set Nurburgring record for EV 1660 Other Vehicles & General Automotive Discussions 1 08-21-2011 10:34 AM
