Old 01-24-2017, 05:31 PM   #29
Kendallkab
Drives: Black MT LMT BRZ
My car is still popping.. I literally typed pooping on accident 3 times... what are you guys talking about that you need an Allen wrench for. One came with my coilovers buy I never found a use for them
Kendallkab is offline   Reply With Quote
Old 01-24-2017, 06:01 PM   #30
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i found out when temp drops, it does more. try stiff up and there will be less pop. when temp goes up again, mine doesnt make any sound. funny thing is i hear this on only driver side..
sound is like squeak for me though
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Kendallkab (01-24-2017)
Old 01-24-2017, 06:02 PM   #31
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Its probably to adjust the dampner stiffness. What coils are they?
The allen wrench we are discussing is to remove stock springs without blowing the stock shocks
Old 01-24-2017, 06:47 PM   #32
Kendallkab
Pass through socket and wrench like was said. I will add the vice grips or locking pliers of some kind are very helpful so you dont have worry about keeping pressure on multiple ways
Tein flex z coilovers.. I thought the Allen wrench was to adjust the stiffness of the ride.. my "mechanic" friend thinks I need swaybars bars to stop noise.. could I have messed up with the adjustable preload on the coilovers?
Old 01-24-2017, 07:07 PM   #33
finch1750
finch1750's Avatar
It could be preload or sway end links. Easy test for the endlinks is to totally undo one and drive it and see if it still makes noise.
But yes, the allen wrench that came with it is to adjust damper stiffness. There is a small hole inside a larger hole so we are talking about 2 different allen wrenches which is confusing you.
Old 01-24-2017, 08:58 PM   #34
Kendallkab
It looks like me and my friend might have messed something up.. im was opened the hood and was going to adjust the stiffness and my left spring looks different from the right. Theres only 3 holes on the left for adjustment and 4 on the right. Almost like the left spring isn't in place.. and the plate at the top is blocking it.. I can literally see the ground through a little opening it has. I'm going to take it off this weekend and see if its supposed to be like that. I would think it's supposed to look the same on both sides.
Old 01-24-2017, 09:08 PM   #35
finch1750
finch1750's Avatar
Yeah, it should sit flush with the mounting location. Please dont drive on it til you fix it. That really isnt safe...
And honeslt yif you didnt notice something like that please find someone more knowledgeable in this or take it to a shop so you dont end up in an accident
Old 01-24-2017, 09:38 PM   #36
Kendallkab
The person I did it with claimed to know so much and the one that looks off is actually the one he mostly did by himself because it was the first one. I even pointed it out at first but we didn't think anything of it at the time for whatever reason. He works on trucks not cars. I plan on doing everything to my car and not paying so I can learn so that won't be happening any time soon. Hopefully this will fix the popping
Old 01-24-2017, 09:46 PM   #37
finch1750
finch1750's Avatar
Or post a pic to show it isnt messed up like i think it is
Old 01-24-2017, 09:52 PM   #38
finch1750
finch1750's Avatar
I posted right after but post a pic of the issue. You need to find someone else to teach you
Old 01-24-2017, 10:00 PM   #39
The person that did it doesn't know shit. Car or truck! Very commendable that you want to do it yourself but STOP DRIVING until it is fixed. Get somebody that KNOWS what they are doing to look at it. As Finch said that is a potently dangerous situation and you could kill yourself or somebody else out of your stubbornness. You won't learn anything if things get done wrong and you then ignore what the people here tell you.
Kendallkab (01-25-2017)
Old 01-25-2017, 01:57 AM   #40
zc06_kisstherain
Drives: SWP BRZ
sounds like preload is over-maxed?? yeah take some pictures and post it up
Old 01-25-2017, 08:52 PM   #41
Kendallkab
You can see the ground on one picture
The Following User Says Thank You to Kendallkab For This Useful Post:
zc06_kisstherain (01-26-2017)
Old 01-25-2017, 09:01 PM   #42
finch1750
finch1750's Avatar
Oh. Thats just the camber adjustment. Looks ok from that angle otherwise. Though get an alignment if you havent already cuz that seems a little funky lol
Double check the spring preload and possibly try unhooking an endlink to see if the noise goes away. I would also rear the threads with other people who have the same coils to see if they have the same noise and what the fixes were.
***NEED SOME HELP IN THE NEXT FEW HOURS IF POSSIBLE??*** NorCalGirl Northern California 1 01-21-2015 06:39 PM
Help installing coilovers eSOLOR Northern California 13 12-16-2014 01:51 AM
Installing Coilovers in Las Vegas bobsacamenoh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-09-2014 10:14 PM
Crap lights on my dash after installing coilovers. Eelusive BRZ First-Gen (2012+) — General Topics 43 02-12-2014 02:08 PM
32 Hours 7 Minutes Wes B. Other Vehicles & General Automotive Discussions 11 12-26-2012 10:10 AM
