Old 01-16-2017, 04:21 PM   #29
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
OK, my recommendations for service might have been a bit of an exaggeration, also leaving out a few things.
All depends on just how long, how many miles a person keeps a car.
In addition to checking fluid levels once a month, I also check cabin and engine air cleaner filters. Usually vacuuming them works just fine.
I don't believe in changing transmission fluid (manual trans only), differential fluid, or brake fluid. Though brake fluid does get moisture in it over time.
Spark plugs I'll think about at 60k miles as it's recommended. Maybe check with others who've let them go longer and see what they've experienced.
I do check under car on occasion...and that means removing skid plate under engine to check for leaks.
Tires are now rotated at 7500 mile intervals.
Many things are just obvious...Check brake linings and rotors whilst rotating tires. Eyeball remaining tread at same time. Check wiper refills very often, replace when tears appear, or when they won't clean up.
Might be good to check with those with high mileage...as Tcoat. See if they've experienced any mechanical problems needing emergency attention.
Still, best to do the minimal, then trade the car, give it to someone else to worry about.
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
Tcoat (01-16-2017)
Old 01-16-2017, 04:29 PM   #30
humfrz
Originally Posted by PSi View Post
someone had to ask something ridiculous like that eventually...i just tired of that someone to come along so i've done it instead
Oh, PSi, I think you just got .. got by ol @Tcoat ...... just fess up now ......
humfrz
Old 01-16-2017, 06:12 PM   #31
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Someone is grumpy.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
Braces is offline   Reply With Quote
Old 01-16-2017, 06:24 PM   #32
humfrz
Originally Posted by Braces View Post
Someone is grumpy.
Who you talken to ...... sonny .....??
Old 01-16-2017, 06:27 PM   #33
Braces
Braces's Avatar
Not you. Someone else whose name starts with P .....middle initial S .... last name i.
Feeling guilty?
Old 01-16-2017, 06:32 PM   #34
PSi
Drives: 2017 86
Feeling guilty?
trolls are always grumpy..i wouldn't feel so grumpy if my ass was in a cushiony a7 tho
PSi is offline   Reply With Quote
The Following User Says Thank You to PSi For This Useful Post:
Braces (01-16-2017)
Old 01-16-2017, 06:33 PM   #35
humfrz
Feeling guilty?
Not really, but when it approaches my nap time ...... I never know .....
Back a few years, when I was a real estate broker, about once a day, my female partner would say "humfrz, you're getting cranky ..... go out in your car and take a nap ..... so I can get some of our work done"!
humfrz
Old 01-18-2017, 12:26 PM   #36
Darkone
Darkone's Avatar
Your pics look awesome!
No mind? TakuanSoho:.. even if your mind seems to be moved, do not let your mind be taken.
無心の心
Darkone is offline   Reply With Quote
