Old 10-23-2014, 01:10 PM   #29
steve99
Originally Posted by legendz View Post
Hi any solution this code p0328 i have corolla 08 with this code and change knock sensor, check circuit, check harness and nothing.. the code is intermitent.. do you habe solution about this....?
Knock sensor is basically a microphone/vibration sensor tuned to pick up what it thinks is knock frequency's (uses some weird fast Fourier transform mathematical algorithm thingo to process signal via ECU). Loose bolts , loose engine components crook bearings or rattling exhausts can cause noise/vibration that the sensor/ECU may interpret as knock.
also check the earthing strap/wire to engine block.
Chevrolet Code 130R Zaku Other Vehicles & General Automotive Discussions 66 05-29-2013 04:48 AM
check engine/CEL/DTC/MIL code list arghx7 Engine, Exhaust, Transmission 3 07-04-2012 11:37 PM
Check engine light code reader FRSCoupe Engine, Exhaust, Transmission 14 06-13-2012 06:06 PM
SWP same colour code as IS250 WP? stevo_12v FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 14 04-22-2012 01:36 PM
