Old 12-17-2016, 05:22 PM   #29
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
It's not just about lowering the car. It's also about the wheels filling out the entire space. Larger diameter wheels and tires, spacers.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
Braces is offline   Reply With Quote
Old 12-17-2016, 05:38 PM   #30
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Golden ratio??
You could be right. Golden ratio == 1.618 and is used in the design of nature.
BRZ has a borderline porky body when viewed from certain angles that I can't see myself ever running the full body kit without going to 18" rims. I'm sticking with 17" rims and just the front lip as my car is only 15mm lowered. The black paint on the STI body kit helps a bit with the slight diet look.
The stock wheel gap and smaller wheels don't bother me as much as with most European cars in the looks dept.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
JD001 (12-18-2016)
Old 12-17-2016, 05:55 PM   #31
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
From where I sit (the driver's seat) I think the car looks fine, so I have no intention of lowering it and potentially ruining its handling, the very thing that drew me to it.
Flip side, I won't deny some cars look nice when lowered without getting ridiculous. I just have no desire to affect the driveability of mine on a daily basis for someone else's approval or satisfaction. I bought a car that doesn't need to be lowered to improve its handling. I'm not unhappy with the stock height and wheel gap, and I get no anxiety over it when I'm behind the wheel, so I'm leaving it alone. I can already hear all my friends asking when I'm gonna lower it, though. The same friends who have to swerve for seams in the road and take interesting angles into driveway ramps so they don't scrape their everything and/or chew up their fenders and outer treads. I'm good.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following 2 Users Say Thank You to Overdrive For This Useful Post:
humfrz (12-17-2016), JD001 (12-18-2016)
Old 12-17-2016, 06:00 PM   #32
Gunman
Drives: 2019 Mazda Miata RF
Golden ratio?? I recall reading something about a certain ratio but don't remember what it was now...
http://www.creativebloq.com/design/d...ratio-12121546
Gunman is offline   Reply With Quote
The Following User Says Thank You to Gunman For This Useful Post:
JD001 (12-18-2016)
Old 12-17-2016, 07:30 PM   #33
darthpnoy1984
Drives: 15 ZN6 Asphalt
The stock setup on these cars is already awesome from the factory, I think slamming this car is a overkill maybe a small drop by like 10 to 20mm is sufficient.
2015 ZN6 DD AT
darthpnoy1984 is offline   Reply With Quote
The Following 2 Users Say Thank You to darthpnoy1984 For This Useful Post:
JD001 (12-18-2016), why? (12-17-2016)
Old 12-17-2016, 07:43 PM   #34
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
If I could cut the bottom 3 or 4 inches off the car I would lower it. But I scrape on the smallest inclines even when I go as sideways as possible. I want another half inch or so of ride height just to cure that.
I've never messed with springs/dampers but had to on my BRZ. The standard step-up just looks wrong and I have noted the same on number of new cars mx5 et al.. then there is the sunken wheels in the wheel wells thing that also looks wrong!
I love the sunken wheel look, I think it is awesome.
The Following User Says Thank You to why? For This Useful Post:
JD001 (12-18-2016)
Old 12-17-2016, 08:46 PM   #35
hdbahn
Drives: '16 FR-S RS 2.0, '03 WRX,
I like a full look in the well and always wondered why so many American cars had huge gaps while BMWs were so tight. It's always bothered me that pick-up trucks have so much vertical gap in excess of the suspension travel/ frame and axle height limitations. It's as if they have clearance for a six inch coating of mud and snow on the tires. On the other hand, I tolerate my narrower track so I can use my old Subaru stuff, and pity the cars that are so overstuffed that people are running stupid camber just to get under the fender (and lowered with the differential 2" from the ground)
hdbahn is offline   Reply With Quote
Old 12-17-2016, 09:41 PM   #36
synchromesh
synchromesh's Avatar
Drives: Ultramarine Blue
It could be my generation's fault for why there are less and less lowered cars and having more and more trucks and SUVs.
In the last 10-15 years they built so many speed bumps where it is a grey area. Why?
Maybe because those involved couldn't handle it or there was so much snitching, bitching and complaining that it had to be done. Speed bumps aren't cheap. In some countries they build them on the highway and I don't blame them.
For me I admire lowered cars. The lower the better. In an emergency situation you need care, control and due process as variables no matter how much courage you have. Rather than driving over curbs or ruining supercars SPECTRE style.
How come nobody has hydraulics no more?
synchromesh is offline   Reply With Quote
Old 12-17-2016, 10:05 PM   #37
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Hydraulics are alive and well. Join a lowrider club. I had two pumps in my new yorker. (Learned I should have got a chevy) Got clowned all the time! Haha!
Wheel gap? Slammed on 13's. I don't think so!!!
Old 12-17-2016, 10:33 PM   #38
krayzie
Drive From Home
krayzie's Avatar
Probably because US crash testing for side impact has a cart that is set higher than the Euro counterpart, so they jack it up to get the 5 star rating.
Old 12-18-2016, 01:37 PM   #39
extrashaky
Drives: 2014 BRZ Limited
But if you cut the bottom 3 or 4 inches off, it would still look too high. So you would have to cut a few more inches off. And keep doing that, until you ended up with something like this:
And then you'd have to drive this when you had the kids along.
The Following User Says Thank You to extrashaky For This Useful Post:
Tcoat (12-18-2016)
Old 12-18-2016, 02:50 PM   #40
Had one or two that ended up looking like that after I cut all the rust out!
Old 12-18-2016, 03:49 PM   #41
humfrz
Zero wheel gap ...........
humfrz
The Following 6 Users Say Thank You to humfrz For This Useful Post:
bcj (12-18-2016), daiheadjai (12-21-2016), D_Thissen (12-19-2016), Leonardo (12-18-2016), new2subaru (12-18-2016), why? (12-22-2016)
Old 12-18-2016, 04:12 PM   #42
Leonardo
Country Boy 4 Life
Leonardo's Avatar
That... ^ is weirdly beautiful... thanks!
I LIKE TIRES!
Wheel DEAL Thread | TE37SL | GTV02 | 3SDM | Lug Nut Combo!! Kami Speed Wheels and Tires 11 04-24-2015 04:48 PM
FS: authentic JDM gt86 steering wheel new !! Great Deal low price !! darnbry Exterior Parts (Aero, Lighting, Etc.) 1 01-08-2015 02:14 PM
Great deal on wheel cleaner! rokius Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 02-22-2014 08:00 PM
The Vivid Racing Giant Wheel Deal Sale! vividracing Wheels and Tires 20 07-08-2012 10:03 PM
Advan RCII wheel deal!! vividracing Wheels and Tires 5 06-19-2012 01:17 PM
