#29 |
You may just not be fast enough at it.
#30 | |
not playing cards
| The Following User Says Thank You to Ultramaroon For This Useful Post: | cat94 (12-15-2016) |
#31 |
need more lubricant
#32 |
not playing cards
Nope. That would be true for upshifts like the cold 1-2, but not downshifts. Unless you double clutch effectively, the synchros have to spin up the input side for a downshift.
#33 |
not playing cards
Actually the opposite is true. The synchros will do a better job of biting through the fluid as they break in.
#34 |
That is what I mean. To long a delay in the rev blip of the double clutch.
#35 |
#36 | ||
not playing cards
#37 | |
Drives: '17 86
For good measure I tried doing the 6-4th without double clutching (but with a rev match) and the blocking feeling I described was there. Definitely agree that this is a user error. Thanks for the advice everyone! |
#38 | |
#39 | |
Drives: 2013 Scion FR-S Series 10
But as I mention, my transmission is worn in. I don't need to rev match either. Though it does help a lot. You may need to just plan out your passes more and just go down through the gears. Meaning, go to 5th and off the clutch, then do the same down to 4th. You might get stuck in slower traffic for a while until things wear in.
#40 | |
not playing cards
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | cat94 (12-15-2016), Stang70Fastback (12-15-2016) |
#41 |
A.K.A. Starlord
Drives: 2015 Series.Blue
I have yet to read this entire thread, but I skip gears all the time when shifting - in just about every possible combination. 2-4, 3-6, 6-4, 5-3, etc... and have never had any issues, or needed to double clutch or anything to make it happen. As long as you match the revs, you shouldn't have an issue with a properly functioning transmission. It should function just like any "normal" up/downshift.
There is nothing requiring you to go through every gear during the shifting process. Some people think shifting from 3rd to 5th is "strange" or "unusual" or "wrong," but it's no different than shifting from 3rd to 4th on a 4 speed transmission. We just happen to have more gears in between to choose from. There is no reason why you NEED to follow any specific progression. When you're riding your 18 speed bike, you don't shift through every gear to get to the one you want. You spin those levers right to the gear you want, and the chain jumps to that spot on the sprocket (probably a bad example, since the chain actually does "climb" through the gears.) Point is, you only need to use the gears you NEED to use. The rest are there just in case! You aren't required to use them all. You could use just 1st and 4th for the life of the car if you decided to. EDIT: I was wrong, lol. Last edited by Stang70Fastback; 12-15-2016 at 06:26 PM. |
| The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post: | cat94 (12-15-2016), Ultramaroon (12-15-2016) |
#42 |
not playing cards
Skipping gates without without matching up puts a tremendous additional load on the synchros. The energy dissipated accumulates at the square of the velocity so it makes a big difference.
Spread the wealth. It's not necessary to engage the clutch in each gear, just rake through all the gates if you're not double clutching.
| Blocking Your TPMS Light | DarrenDriven | DIY (Do-It-Yourself) Guides | 77 | 03-29-2017 11:18 PM |
| Dealers wrongly mounted your front plate, blocking airflow | Zhangy | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 04-20-2015 01:47 AM |
| Rev match downshift possible with OFT | Simon99 | Software Tuning | 24 | 08-17-2014 04:20 PM |
| Blurring/Blocking Licence Plates in Photos | btoast | Off-Topic Lounge [WARNING: NO POLITICS] | 18 | 06-10-2014 12:42 PM |
| downshift to first | swpbrz | Engine, Exhaust, Transmission | 13 | 05-07-2014 08:33 PM |
