Old 12-10-2016, 08:13 PM   #29
cf6mech
Drives: FRS Silver LS1 swapped.
Happy to see another swap project .
cf6mech is offline   Reply With Quote
The Following User Says Thank You to cf6mech For This Useful Post:
Sportsguy83 (12-10-2016)
Old 12-10-2016, 09:06 PM   #30
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You're the pioneer my man
Old 12-11-2016, 12:43 AM   #31
cf6mech
As they would say, as in critics, it isn't self built. But it was a concept I and it seemed another entity had and it came together. Another shop actually planted the seed and have been very helpful as well......The can- bus guru was found by another shop in Seattle who through this forum contacted me.......so this forum and car forums in general which many are critical of has been extremely helpful to me and I'm thankful for all involved, Truly wish you luck on your conversion.
The Following 9 Users Say Thank You to cf6mech For This Useful Post:
Calum (12-12-2016), civicdrivr (12-12-2016), Draco_PR23 (12-11-2016), DustinS (12-11-2016), kmbkk (12-11-2016), Sojhinn (02-12-2017), Sportsguy83 (12-11-2016), wooly35 (12-11-2016), wparsons (12-19-2016)
Old 12-18-2016, 04:37 PM   #32
Amir Ghadiri
Amir Ghadiri's Avatar
Use the FiTech Ultimate LS ECU. It will be released next month. I am running it on my own swap and it is great.
Amir Ghadiri is offline   Reply With Quote
The Following User Says Thank You to Amir Ghadiri For This Useful Post:
Sportsguy83 (12-18-2016)
Old 12-18-2016, 06:31 PM   #33
Calum
That Guy
Drives: 2013 asphalt FRS MT
What makes it great?
Old 12-18-2016, 06:38 PM   #34
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Papi's thread... can't miss this
Cartman is offline   Reply With Quote
The Following User Says Thank You to Cartman For This Useful Post:
Old 12-18-2016, 06:47 PM   #35
Amir Ghadiri
Full self tuning kit with aluminum LS style intake manifold, throttle body, injectors, engine ecu & ignition box, wire harness, knock sensor control, boost control, etc. literally everything for only $1500. Designed, tested, and supported here in California. It's as kick ass as it gets.
The Following 2 Users Say Thank You to Amir Ghadiri For This Useful Post:
Calum (12-19-2016), Draco_PR23 (12-19-2016)
Old 12-18-2016, 06:57 PM   #36
Sportsguy83
Drives: Limited BRZ
And how does it integrate with the stock CAN systems? What works and what doesn't? You still have the OEM dash? What lights are on?
Old 12-18-2016, 10:11 PM   #37
Amir Ghadiri
It's a standalone EMS. Not meant to integrate with CAN systems. You can still setup your EPS, Tach, ABS with an Arduino, but no TC, Cruise, etc.
Old 12-23-2016, 08:16 PM   #38
nmctacticz
2010 WRX - 2015 FRS
nmctacticz's Avatar
Drives: 2015 FRS
so besides the engine swap... what transmission are you getting? what about the drivetrain and axles, power steering, fuel system, cooling?? wtf happens to all that?
Although i wana do the same to my FRS this sounds like a nightmare and you"ll lose some of the luxuries that came with the car
2010 Subaru WRX - 2015 Scion FR-S
"Life's too short to drive boring cars"
nmctacticz is offline   Reply With Quote
Old 12-23-2016, 09:28 PM   #39
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
You have a WRX and a FRS
wutsaiu is offline   Reply With Quote
Old 12-23-2016, 10:46 PM   #40
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
If the swap is done right...
You lose nothing.
All OEM features work.
It's expensive and time consuming, but not prohibitively so.
A proper kit will supposedly exist... Eventually.
For MT, most people use t56. TR6060's and TKO's get used, rarely.
The frs differential is very robust.
Power steering is electric and self-contained. It needs a few ECU signals to start and work.
Stock returnless fuel system can be used, with a pump change only necessary for peak flow. There are plenty of pumps available off-the-shelf.
There is plenty of space for a sufficient radiator... The stock A/C system needs 2 new compressor lines, but can otherwise be completely reused.
Weight increase is negligible.
The car needs only 1 sheetmetal mod in the transmission tunnel. It involves cutting a few spot welds and throwing away a small stamped steel brace, which can be replaced.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 4 Users Say Thank You to Spartarus For This Useful Post:
Anthony (01-20-2017), JD001 (12-24-2016), Sportsguy83 (12-24-2016), Summerwolf (12-23-2016)
Old 12-23-2016, 11:17 PM   #41
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Wtf kind pf post is this? When done correctly you lose no luxuries and gain reliability / power.
Old 12-24-2016, 11:21 AM   #42
nmctacticz
2010 WRX - 2015 FRS
nmctacticz's Avatar
Drives: 2015 FRS
You lose nothing.
Thanks for clearing this up I really appreciate it... I have put some thought into to it and have put aside 7 grand for this project. I want to to do a LS1 swap but finding the right mechanic to do it is my only issue
Sportsguy's LS2 Swapped BRZ Sportsguy83 Member's Car Journals 2969 08-20-2018 11:12 AM
FS: (Sold) Sportsguy ArmRest kvnchu Interior Parts (Incl. Lighting) 22 03-13-2014 02:40 PM
Sportsguy's AVO Turbo experience, the Good the Bad and the Ugly Sportsguy83 Forced Induction 155 08-05-2013 06:17 PM
Motegi 126 customs kioton32 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-26-2013 12:34 AM
FS: NY - Sportsguy Handcrafted Armrest xxscaxx Interior Parts (Incl. Lighting) 43 05-04-2013 05:30 PM
