Old 01-02-2017, 02:23 PM   #29
.RYAN
AWOLBRZ
Drives: 2017 BRZ
Originally Posted by 2086GT View Post
Just going to point out top tier racing classes are not using swan neck. So either they are doing it wrong, I don't know of some class rule against swan necks, or swan neck isn't even worth it. So I am going to say A.
Tell Porsche that.
.RYAN is offline   Reply With Quote
The Following 3 Users Say Thank You to .RYAN For This Useful Post:
ATL BRZ (01-25-2017), Hyper4mance2k (02-04-2017), Insurme1 (01-03-2017)
Old 01-02-2017, 03:20 PM   #30
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Swan neck is superior for wing performance, there are plenty of blogs/articles/documentation about this. We may do our own blog at some point on it. In certain instances it doesn't make sense to have the added complexity of swan neck mounting or it is outlawed in regulations.
That's the inherent problem with judging off of what top tier racing teams do; they all have rules that govern what can and cannot be done to limit costs and performance. All too often enthusiasts get stuck on what a company did or didn't do and they don't understand that this company is making a compromise in performance to stay within class rules.
Originally Posted by StegaDragon View Post
How about option #3 and go with a set up like the rocket bunny, less chances of distortion to the trunk, and leaking, then just develop something to brace the trunk to the chassis, like replacing the rubber stoppers with something that has less give and make it more direct transfer of Force to the chassis
Sent from my XT1650 using Tapatalk
We're looking into this style of mounting but I think it will be difficult to make it look good without the wing hanging pretty far rearward of the trunk. I believe this puts a wing like this out of classes.
Originally Posted by Takumi788 View Post
Velox. what do you think about this idea? It seems like you could design a swan neck from this type of mount.
I still stand by my original post in which I stated that a "typical" trunk mount solution would be preferred. But this could be a plausible solution to create a swan neck design.
We're attempting to come up with something that mounts to the trunk while remaining rigid for the forces it will produce.
I picked up a spare trunk that I will be able to cut into and figure out rigidity on. Looking forward to getting something finalized, hopefully, within the next month and prototypes a few months after.
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
Jonsey (01-02-2017), Takumi788 (01-02-2017)
Old 01-02-2017, 05:10 PM   #31
StegaDragon
StegaDragon's Avatar
Drives: 13 Sc10n FR-S
Thanks,
Eric
Just curious would it affect the aero that much if the swan neck came from the back instead of the front
StegaDragon is offline   Reply With Quote
Old 01-02-2017, 07:01 PM   #32
Pat
Pat's Avatar
Drives: 2023 BRZ
I had the same thought. It seems as if it could only help the aero.
Old 01-14-2017, 03:43 PM   #33
Ashikabi
Ashikabi's Avatar
Thanks,
Eric
For me a chassis mount isn't an option (at this time) as I require trunk access. Unless it folds back like the one posted above. I have the GReddy wing and love the look. Far superior to a wing that mounts to the top of the trunk.
Old 01-14-2017, 05:53 PM   #34
.RYAN
AWOLBRZ
Drives: 2017 BRZ
Can you post your data to back your claim.
Old 01-14-2017, 08:23 PM   #35
Ashikabi
Ashikabi's Avatar
Far superior looking. If that's what you were getting at
Old 01-15-2017, 05:58 PM   #36
VerusEric
VerusEric's Avatar
We may be doing a blog post on swan neck vs. traditional mounting which would dive a bit deeper into this topic. In a nut shell, you want as little interference between mounting style and the bottom side of the wing, which is where the majority of the work is performed. This is why swan neck is beneficial. So coming from behind could net a similar benefit as coming from the front, dependent on the interaction between the mount and the bottom of the wing's flow.
Hope that makes some sense.
Thanks,
Eric
Old 01-15-2017, 07:20 PM   #37
cjd
cjd's Avatar
Drives: 2017 BRZ
Thanks,
Eric
If my "learned from reading about WWII planes" engineering means anything (hah!) I might suspect that the further back you put disruptive elements in the air flow, the better it will perform... Probably wrong, but I'd be curious. I won't be sporting this kind of aero any time soon, regardless...
Old 01-24-2017, 03:01 AM   #38
2086GT
Drives: 15 Scion FRS Halo
If this is mass market item and not just dedicated track car wing I would imagine swan would be cost prohibitive. I know it's beneficial it's benefit vs cost that will cause it to sink or swim. Then again the other companies could just be charging around a grand more due to "cool" tax.
2086GT is offline   Reply With Quote
Old 01-24-2017, 09:27 AM   #39
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I figured I would share the "teaser" that is Velox's website. I'm excited.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following 4 Users Say Thank You to Takumi788 For This Useful Post:
CarzCarzCarz (01-24-2017), Hyper4mance2k (02-04-2017), jmimac351 (04-15-2017), VMRamos (04-15-2017)
Old 02-04-2017, 08:18 PM   #40
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
The more it looks like this the more likely I am to buy one.
Just trying to build a Subaru BRZ GT-Poor
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following 3 Users Say Thank You to Hyper4mance2k For This Useful Post:
batlwagn (02-14-2018), jmimac351 (04-15-2017), VMRamos (04-15-2017)
Old 02-05-2017, 09:46 AM   #41
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Interested for sure.
Mad1723 is offline   Reply With Quote
Old 02-27-2017, 01:42 PM   #42
Takumi788
JHerbert Racing
Takumi788's Avatar
I know your busy but are there any updates on wing development?
WTB: Header, Rear Diffuser, Rear Wing/Spolier, Trunk, Tail lights Apples_ZN6 Canada Classifieds 0 06-04-2017 12:27 PM
Street Faction Engineering Chassis Mount Wing FRS/BRZ hellokyles Exterior Parts (Aero, Lighting, Etc.) 19 08-19-2016 06:20 AM
Freed Engineering custom metal fabrication and parts development bFreed Announcements, Contests, Giveaways 23 03-24-2012 04:35 AM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 07:11 PM
