Old 11-18-2016, 04:33 PM   #29
LotsaMiles
Drives: Scion FR-s, xB, iA, Silverado Z71 4
Like most car forums people love to focus on fluids. Probably because it is a really easy DIY thing that makes them feel closer to their car. Although I certainly appreciate the need to have the right thing in the right quantity I also am of the mindset of "if there is enough and it works then leave it alone and don't worry about it". There really is no perfect amount of oil but simply a point where there is too little and a point where there is too much. Anything in between is fine and of equal effectiveness.
Yeah. This is kinda funny. I've replaced timing belts, water pumps, rebuilt manual transmissions and used to change my own oil. This changed in the late 90's. It really changed when I bought my brand new 2001 Chrysler 300m. I used to be intimate with the engine compartment of the cars I owned. With that car, the only time in 185,000 miles I popped the hood was the times I cleaned the K&N air filter.
And the same goes for my FRS, xB and iA. Well, I had to pop the hood on the xB to straighten out a few parts and stretch the fender after I hit that deer, but I haven't since then...
Wish I could say the same for my 2003 Silverado Z71. What a piece of trash.
LotsaMiles is offline   Reply With Quote
Old 11-18-2016, 10:05 PM   #30
humfrz
Originally Posted by LotsaMiles View Post
Yeah. This is kinda funny. I've replaced timing belts, water pumps, rebuilt manual transmissions and used to change my own oil. ..........
Yep, there's ol @LotsaMiles .......back in the day .......
humfrz
Old 11-19-2016, 05:07 PM   #31
bhmax
Drives: 13 BRZ, 17 Focus RS
How about you guys check your oil 5 minutes after shutdown when you know it'll be sitting overnight. Then, the next day, check it again when cold. That way you know how much difference it really makes.
bhmax is offline   Reply With Quote
Old 11-19-2016, 05:41 PM   #32
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Too sensible and would waste good quality clucking time.
Scrappydoo is offline   Reply With Quote
Old 11-20-2016, 01:58 AM   #33
humfrz
Logic, science and experimentation have no place in this thread .......
humfrz
Old 11-21-2016, 08:12 AM   #34
LotsaMiles
humfrz
Dang! Where'd you get that picture of my brother and me?
The oldest car I had was a 1954 Chevy station wagon. I once ran the tires so bald that one day I heard a pst, pst, pst, pst sound and pulled over. I'd worn through everything and it finally broke through in a spot. Adjusting the valves on it was kinda fun...
Old 11-21-2016, 10:26 AM   #35
humfrz
Oh, yes, running on retreaded bias ply tires, till the retread was worn off and they were down to ......why they were retreaded ..... made for "interesting" driving ....
Adjusting the valves (with the engine running) took 3 hands (or two quick ones), one to hold the feeler gauge, one to work the wrench and one to try to keep the screwdriver on the adjustor post .......
humfrz
Old 11-21-2016, 06:16 PM   #36
cjny
Drives: 2016 BRZ
Did it. Long ago. More than once. Hence my previous post: it makes a difference. But not much.
cjny is offline   Reply With Quote
Old 11-21-2016, 06:44 PM   #37
JoeC
Drives: Subaru BRZ Limited
I always figured you were supposed to check the oil hot because I thought engine oil would expand a lot and if you filled it and checked it cold there'd be too much oil once it got up to operating temp.
The reason I thought this is because peanut oil expands a ton when heated. But, I did some reading on the internet and apparently that's not the case with engine oil. very little expansion.
JoeC is offline   Reply With Quote
Dipstick question Qwimby2 BRZ First-Gen (2012+) — General Topics 26 11-27-2015 12:59 PM
transmission dipstick location ikeryder13 Engine, Exhaust, Transmission 28 06-11-2015 09:15 PM
oil on dipstick but not on hole ZionsWrath Engine, Exhaust, Transmission 2 09-08-2014 07:46 PM
Show me your dipstick.... Trashed675 Engine, Exhaust, Transmission 6 01-03-2014 01:09 AM
Change trans fluid thru dipstick bigsley18 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 07-18-2013 10:16 AM
