Old 08-19-2012, 02:34 PM   #29
pinoyplaya
Drives: WRB MT-BRZ LMTD
Subscribing. I'm hearing this problem on my BRZ as well. Kind of worries me that one day, after much changing gears and clutch use, the transmission will just fall apart in the middle of driving
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM
Traded for Black 2013 Camaro 2SS RS
pinoyplaya is offline   Reply With Quote
Old 08-19-2012, 03:13 PM   #30
Sargy
Long Distance Driver
Sargy's Avatar
In a weird way it sounds normal to me, OP. some of the issues your mentioning in your first post I can relate to in my own car (06 Solara 5MT) but the video later on, thats no exception. sounds normal but at the same time dosent sound right especially if it happens this soon.
Sargy is offline   Reply With Quote
Old 08-20-2012, 01:52 PM   #31
wheelhaus
wheelhaus's Avatar
Since this only appears to be happening when the engine is idling, what you're hearing most likely requires something to be spinning. To narrow it down, the clutch IS spinning, always, because it's attached to the engine; this is one possibility. When you engage/disengage it from the tranny, the only part it's affecting is the input shaft; the second possibility. Since the gears are helical, when one shaft turns it tries to corkscrew itself forward or backward against the mated gear. Since no gears are engaged in neutral, we may be hearing the near-instantaneous force of acceleration on the input shaft, and the drag caused by the thick tranny oil slowing it down quickly. Considering this car has had extreme efforts put into engineering it's transmission "feel", the noise may simply be a byproduct of the bushings or shifter linkages making a normal action become more audible.
I wouldn't necessarily suspect a throwout bearing I'd expect to feel and hear it pitching a fit with the pedal depressed.
When you move the clutch in/out more slowly (say 2sec in, 2sec out) does it still make the noise?
wheelhaus is offline   Reply With Quote
Old 08-20-2012, 02:38 PM   #32
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
In mine, it makes a noise if you slowly depress the clutch. It isnt the same loud clunk though.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-20-2012, 08:37 PM   #33
jm1681
Drives: MKVI VW GTI
My car makes this noise as well, but I figured it was nothing more than the transmission not liking me trying to get it into gear with some residual speed on the clock. You know how it's been said that you shouldn't try to force a trans into a gear at a speed that exceeds the maximum of that gear (!)? Basically, that's what I figured was happening.
Lately, I've been letting the car come to a complete stop, and THEN sliding it into gear, but as my clutch use is getting smoother (As I'm getting used to the clutch take-up), I'm noticing less and less of the clunk.
Honestly, I wrote this off as a quirk of a RWD car, but if you guys are all having serious trans problems, I'm in for more info.
jm1681 is offline   Reply With Quote
Old 08-20-2012, 09:23 PM   #34
pyro530
Drives: Ultramarine FR-S 6MT
Just had to put my 0.02 in. I definitely hear that same clunk when I let my clutch out.
As far the clutch taking a second to be fully engaged, I also have experienced this slightly. Really neither issue was much concern to me, but please keep us updated.
Current: FR-S Ultramarine 6MT - Took delivery 05/30/2012 - Now for sale here
1995 M3 Coupe MT - the "Bavarian Bumblebee"
Past: 1994 Integra - Sold | 2005 Dodge SRT-4 - Totaled by Hail | 1997 Acura 2.2 CL slowmobile - Sold | 1991 BMW E30 - Sold | 1991 Acura Integra GS - Wrecked | 1971 Chevy C-10 shortbed stepside - Sold | 1973 Camaro Z-28 Clone - Stolen
pyro530 is offline   Reply With Quote
Old 08-21-2012, 01:55 AM   #35
mashal
DADA
mashal's Avatar
Drives: 2013
Any new updates ? I have this also but I thought it was normal since the two manuals I test drove did this as well... Wrx/Sti's have this but not all the time
mashal is offline   Reply With Quote
Old 08-22-2012, 04:18 PM   #36
Skye
Drives: TR2,CooperS,BRZ
After reading posts and hearing same clicking when disengaging clutch idling I went to the dealer, they checked a brand new identical model and it made the same noise as mine!
Skye is offline   Reply With Quote
Old 08-22-2012, 04:37 PM   #37
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Mines a little more server, as mentioned in my past posts I have play engaging initially in every gear, the most consistent is 5-6 gear under 3k rpm, you can feel the initial slack in the powertrain before it goes smooth, and also while coasting in gear and re accelerating, you can feel a good amount of slack, as if the main shaft in the tranny is a little loose, but however once it gets over that initial slack everything is fine, and under WOT or heavy load its fine, my dealer has forwarded the issue to Toyota Canada, awaiting response.
If anything what bugs me is it makes it very hard for smooth shifts when driving economically, again I went to the dealer and test drove there demo and I was able to drive it smoothly effortlessly, no matter how I drove and shifted it was smooth and effortless.
The sound I posted in the video no longer bothers me as it exist in every FRS/BRZ ive seen in person, seems to be a very normal thing, anyone share any symptoms I jsut talked about?
there is also a clunk sound when engaging every gear in my car too. Same clunk that you would hear popping it to first.
Bu-Tang is offline   Reply With Quote
Old 09-27-2012, 02:04 PM   #38
TennisHsu
TennisHsu's Avatar
Drives: 2013 Whiteout MT Scion FR-S
I'm not sure if this is something to be concerned about, but I am experiencing a *Clunk Clunk* when depressing the clutch at parking lot speeds. The sound is very predominant, especially in reverse gear. I would partially engage the clutch to get the car rolling (in reverse) then fully disengage the clutch, this is when the clunk clunk sound happens, and happens every time.
TennisHsu is offline   Reply With Quote
Old 09-28-2012, 08:39 PM   #39
cRazy604
too nuts
cRazy604's Avatar
Drives: Scion FR-S
I have the clunking noise only when i go into first gear, but i read somewhere that if you do an oil change and change the tranny fluid it goes away so im not really worried about it
cRazy604 is offline   Reply With Quote
Old 09-28-2012, 10:08 PM   #40
TennisHsu
TennisHsu's Avatar
My condition is more of a double clunk, like something is snapping back under a spring load. I was getting this all morning while in stuck in stop and go traffic and on a slight incline. Get the car to creep a little, *Clunk Clunk* literally every time I pushed in the clutch.
Old 09-28-2012, 10:33 PM   #41
stevan
This and the laggy throttle response are my 2 hates for this car. I also find when I'm shifting there's way too much slack and it gives me the shits because you can't shift smoothly. Does anyone suspect this issue to be due to very soft engine mounts?
In my last car (honda Integra DC5) I had poly mounts and it shifted and had the response of a race car. I just find the response and shift feel in this car to be very below par.
stevan is offline   Reply With Quote
The Following User Says Thank You to stevan For This Useful Post:
Bu-Tang (11-23-2012)
Old 04-01-2014, 07:32 PM   #42
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Just got my car back from the dealership and now it's clunking pretty loud when I release the clutch. It definitely wasn't making this noise before...at least not this loudly. I guess I can live with it, but honestly it sounds like something is loose. It's not a solid sounding "clunk"...more like a weak/loose clanking sound. Maybe I'm just being paranoid.
Here's a video:
[ame="https://www.youtube.com/watch?v=Mo_TyeMEYL4"]BRZ Clutch Clanking - YouTube[/ame]
ericmpena is offline   Reply With Quote
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Engagement... so expensive. merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 43 08-02-2012 09:55 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch billysangi BRZ First-Gen (2012+) — General Topics 10 06-15-2012 02:29 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
