Old 11-10-2016, 07:04 PM   #29
steve99
Originally Posted by BWilky View Post
Is this going to allow for tuning and replace the ProECU Programming Kit?
Then would you still need to get a tune?
to tune with ecutek you need three things
Ecutek cable kit about 350
Ecutek ecu licience about 350
A tune either you make it or you buy one from ecutek 100-500 or so
I suspect the blutooth dongle will be able to flash tunes like the standard kit but not 100% it appears to have a micro usb adapter socket on back which i suspect will plug into usb port of computer for flashing. Then logging and other stud is done via either usb or blutooth link.
Old 11-11-2016, 04:34 AM   #30
Kodename47
Kodename47's Avatar
Drives: UK GT86
Flashing is coming soon. In fact the BRZ product isn't finished yet, I spoke with ECUtek earlier this week. I have suggested some ideas to them so should hopefully see those. Android app is expected start of 2017.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-11-2016, 04:59 AM   #31
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
That doesn't make sense... ProECU cables are not application specific as far as I understand it, and there's no indication the Bluetooth modules are either. Unless the software just isn't complete.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 11-11-2016, 05:21 AM   #32
steve99
I suspect @Kodename47 is talking about the software changes required in the ecu to allow the live interfacing via the blutooth app rarther than the pro ecu software
Old 11-11-2016, 05:47 AM   #33
Luftwaffel
Boost Creep
Luftwaffel's Avatar
That's the only thing I can think of, though I'm not sure what would really need to be changed. Maybe something to support the higher polling rate.
Old 11-11-2016, 08:01 AM   #34
BWilky
BWilky's Avatar
Drives: 2016 Subaru BRZ WRB
Interesting! If this new product would directly compete with the OFT in terms of price and flexibility with tuning.
BWilky is offline   Reply With Quote
Old 11-11-2016, 08:49 AM   #35
cjd
cjd's Avatar
Drives: 2017 BRZ
It doesn't seem any less than the current setup... Still need license and interface and tune, all of which are separate.
Old 11-11-2016, 11:09 AM   #36
Kodename47
Kodename47's Avatar
Drives: UK GT86
A new RaceROM patch is required for the neater features. Not sure whether you'll require the new patches for only the new features or to connect at all, but things are still being tested and ironed out. Here's some more info for you though:
Originally Posted by Fensport on gt86ownersclub.co.uk
A little update now I've had chance to have a play
We now have it all working and have designed some custom maps around the 5 available inputs which can be fed in to custom maps.
The custom inputs can be re named, we have the option to use them as a switch, slider, numeric or listbox. Min and Max values can be set as well as text displayed.
Map switching can also be named which is nice*
The above shows some examples of what can be done for customer usage. We can also configure for tuning and allow live inputs in to the ecu.
Data logging is one of our favourite things especially for the race car, we can start a log on the startline and record the whole lap or laps and only need to carry an iphone in the car.
Another plus is you can see if vvt is on and its so cool to switch maps from your phone and see the rev counter move to the appropriate map
Datalogs can also be emailed direct from the app and there's a section to find your nearest Ecutek tuner with their contact details.
It's early days yet and I know Ecutek have big plans for the future which is great for us all
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-11-2016, 01:33 PM   #37
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Honestly I feel like US distributors mark up EcuTeK to pretty astronomic levels. A license tends to cost minimum $300 USD from a US tuner. If you buy from a UK tuner, it's around £150-160 GBP which translates to around $200 USD on the high end. You can't even argue that it has to go through customs (which is 2% on the high end anyway), because it's software. That's all retail pricing.
Visconti just ran a sale for $400 for hardware, license, and a tune. I realize there has to be some profit margin, but come on.
As for flexibility, EcuTeK is already more flexible than OFT. That's the difference between one guy and an entire R&D team.
Old 11-11-2016, 01:37 PM   #38
Luftwaffel
Boost Creep
Luftwaffel's Avatar
I figured there would be a RaceROM update for this. Good info.
Old 11-26-2016, 06:51 PM   #39
Kodename47
Kodename47's Avatar
Drives: UK GT86
V9.1 Racerom patches have been released. Interesting to have a poke about. 5 custom inputs available from the app.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-13-2016, 01:00 PM   #40
byun
byun's Avatar
Drives: 2015 BRZ CWP
Anyone else have been playing around with the app and tried the data logging? Curious as to see if you are able to see Advance Multiplier and Custom Maps to read e85 content.
Right now it doesn't show as a selectable parameter when trying to select what to data log.
byun is offline   Reply With Quote
Old 12-13-2016, 03:20 PM   #41
Kodename47
Kodename47's Avatar
Drives: UK GT86
Have you got the EVi dongle? It shows up on the images that I posted up before and I don't see why you wouldn't be able to access them. However those parameters are pulled from RaceROM logging and not standard logging, hence my original question.
You will likely need the RR9.1 patches too, so older versions may not have full logging capability.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-13-2016, 03:33 PM   #42
byun
byun's Avatar
Yup, got the dongle. Tried the logging last night and it didn't show AM or any of the custom maps. I'm going to talk with the tuner to see
Delicious Tuning Q & A - FlexFuel BlueTooth Kits for EcuTeK ProECU RaceROM DeliciousTuning Software Tuning 331 06-17-2025 02:36 PM
My Bluetooth in my 2014 FRS so stay connect Case1010 Electronics | Audio | NAV | Infotainment 3 02-24-2016 06:57 PM
Header/overpipe interface misooscar Engine, Exhaust, Transmission 4 11-22-2014 11:21 PM
Garmin GPS Bluetooth Won't Connect frssfo Electronics | Audio | NAV | Infotainment 0 08-20-2014 10:55 PM
Bluetooth connect mutes android NAV Rob_g Electronics | Audio | NAV | Infotainment 6 07-04-2012 04:38 PM
