#29 |
Drives: 2015 FR-S
Sorry to piggyback but I'm looking for the '15 TSB for rough idle. I keep throwing a P000C CEL and it usually correlates with rough idle. Car goes into limp mode for a bit, then it clears itself within 30 miles or so. It's happened enough times that I can predict it when I start seeing the idle go wonky. I've only had the car for a few weeks and am looking to take it into the dealer as soon as I start a new job that I can commute to on my bike.
Can someone please point me at the '15 TSB for rough idle so I can do some research before taking it in? I did check the TSB thread but the link on the front page is for '13 models and I read through the last few pages from '15 on and don't see an updated TSB |
#30 | |
Drives: 2016 Subaru BRZ
And I can't help but use prior years as a point of reference when all three prior years had the exact same problem. Counterspace Garage even described and posted a video of my exact problem on this forum. It's the same issue this car has had for three prior years. |
#31 | |
Drives: 2005 Toyota Camry
TSB is only useful for the technician to use when it applies to specific VIN that it references. Otherwise, Subaru will just view your case as an individual isolated case of "bad idle" and go from there to diagnose it. You can reference a TSB all you want, but at the end of the day the dealership can't use that TSB to actually write up a work order, nor use it to perform any repair work. They can write it up almost word for word, but the actual TSB itself can't be used because it doesn't apply to your car. -alex |
#32 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Just call Toyota first. Mine was out off the year for reflash ECU, I called Toyota, they told me some vehicles post-ECU TSB still had the old ECU software. They called dealership, 20min later I had my ecu reflashed.
#33 |
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
OK, here's what my invoice said for my "hesitation" problem:
"Found TSB reprogram for this concern. Out of calibration. Reprogram ECU. TSB0021-15.4" I don't know if this will help any of you out, but I hope it might send you in the right direction. Again, this is for my 2015 Scion FR-S automatic transmission. Good luck! |
| The Following User Says Thank You to winstonscifi For This Useful Post: | Da Brz (10-28-2016) |
#34 | |
I don't care how it gets fixed. I'm also not the one who will be diagnosing it. On MY end, I can't help but notice how my issue is eerily similar to the issues from 2012. On THEIR end, I couldn't care less how they fix it. My OP was mainly about how my dealership says they've never heard of this car having any idling issues whatsoever when that's clearly a lie, and if it's not then they're a Subaru dealership with their head in the sand. |
#35 | ||
This car (to you) could mean 2013 - 2016 BRZ/FRS/86 worldwide. The dealership being 1) fully aware of TSB, 2) never experiencing specific customer issues with idle out of cars sold at their dealership, and 3) not having issues on MY 2016 is entirely possible. Just because there's a TSB for a car doesn't mean the TSB will actually be used... Another example is the taillight condensation issue and the TSB issued for 2013 model year cars. My car was serviced using this. I've heard of 2014+ cars with the same issue, even after the supposed manufacturer fix was put in place at the factory. Those cars were fixed using the same method, but the key part is that the TSB was not used as a means of justifying the warranty reimbursement between dealer and corporate. As someone else already referenced: Quote:
People misunderstand what the purpose of a TSB is and throw it around like it's a fix or solution. Plenty of cases have popped up where a TSB really didn't fix the warranty issue at hand. -alex |
| Turbo Rough Idle & Stall | BRZtoni | Forced Induction | 40 | 05-25-2016 06:28 PM |
| Rough Idle, Cel, Skid light... | Freeze2196 | Issues | Warranty | Recalls / TSB | 2 | 06-10-2015 12:58 AM |
| '14 BRZ Ltd. - Rough Idle | leicaboss | BRZ First-Gen (2012+) — General Topics | 20 | 05-22-2014 07:40 PM |
| Looks like CEL/Rough Idle is getting a lot more attention. | wawro569 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 10-06-2012 01:24 AM |
| Rough Idle & CEL *video | JiB | Issues | Warranty | Recalls / TSB | 5 | 10-04-2012 11:28 PM |
