#29 | ||
Huge E85 fan!
Drives: 2016 Scion FRS
Unless when the wheels were swapped around they swapped the dampers too. |
| The Following User Says Thank You to guybo For This Useful Post: | Ultramaroon (10-17-2016) |
#30 | |
Shit, back to square one AGAIN.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (10-17-2016) |
#31 | ||
not playing cards
OP, are all four of your tires mounted properly on their wheels? Are you absolutely certain they are all the same size? ~~~~~~~~~~~~~~~ edit: ok, a lot happened since my last visit. Meh, I summarized.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | guybo (10-17-2016) |
#32 | |
Drives: 2013 Toyota 86
| The Following 2 Users Say Thank You to Midjetv8 For This Useful Post: | Tcoat (10-19-2016), Ultramaroon (10-19-2016) |
#33 |
Drives: Scion FR-S
Just an FYI even if the tires are directional and you mount it the wrong way, it won't make a difference performance wise in dry conditions. It only starts to get hairy when you get into wet/slippery conditions with directional tires being mounted the wrong way.
#34 |
A.K.A. Starlord
Drives: 2015 Series.Blue
Yeah in autocross, I'm told people run their RE71Rs backwards on dry days to even out the wear. No idea if it's okay to do, but I suppose that's a different circumstance than putting tens-of-thousands of miles on a DD tire.
#35 |
Just a quick update, problem has been fixed. Swapping the front right and the rear left corrected the pull. Car feels mint now. Bridgestone tech couldn't give me an explanation as to why. But it works so it's all good!
| The Following User Says Thank You to Midjetv8 For This Useful Post: | Ultramaroon (11-15-2016) |
#36 |
Drives: 15 FR-S Firestorm MT
Won't this be a problem again when you rotate your tires?
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
#37 |
#38 |
My guess is that even though the tires may not be directional they all still need to be mounted with the tread in the same direction. Swapping two opposite tires would have reversed the direction on both and now they match the others. There is nothing else it could have been.
| Aggressively pulling to the left on acceleration | sero901 | Issues | Warranty | Recalls / TSB | 39 | 01-12-2021 06:39 PM |
| Pulling up floor rug? | ndsleep612 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 12-11-2013 02:23 AM |
| Brz pulling trailer? | subiesteve | Southwest | 7 | 11-20-2013 10:04 PM |
| 94 octane not pulling | Scalzo | Forced Induction | 44 | 10-08-2013 11:15 PM |
| Pulling your FRS off of the lot, what are you bumpin'?? | poormans_LFA | BRZ First-Gen (2012+) — General Topics | 201 | 06-09-2012 10:52 PM |
