Old 12-19-2016, 11:50 AM   #29
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by djwishbone View Post
I just noticed that the fan blades are different on the oem rad from left to right. I really can't think of why? Fans are for slow or non moving speeds. I would think a single optimized design would be best?
Different flow rates and noises associated with the increase/decrease in flow rates. Typical OEM system where noise is paramount... the lower noise fan kicks on first and the higher flowing/noise-producing fan kicks on if the low noise fan cannot cool the radiator. There is also some logic thrown in there with regards to the a/c system and when each fan kicks on, but that is beyond my scope of understanding.
Thanks,
Eric
VerusEric is offline   Reply With Quote
Old 12-19-2016, 12:08 PM   #30
djwishbone
Last Starfighter
Drives: 2016 FR-S Series 2.0
Ahhh. That totally makes sense. There is no free lunch with fan design. You get flow/static pressure or low noise but not both. Also explains why the stock system is so quiet.
djwishbone is offline   Reply With Quote
The Following User Says Thank You to djwishbone For This Useful Post:
pgranberg11 (12-19-2016)
Old 12-21-2016, 12:22 PM   #31
VerusEric
VerusEric's Avatar
Correct. There's rarely ever free lunch, compromises are a necessity of all designs.
The SPAL fans on our radiator are designed for flow, the curved blade I spec'd out does reduce air noise though. They are SUBSTANTIALLY louder than OEM though, pull more amps, and very likely outflow OEM.
Currently the fans only kick on if I'm stopped in traffic for multiple minutes though, which is exactly what the fans are there for.
Thanks,
Eric
The Following User Says Thank You to VerusEric For This Useful Post:
djwishbone (12-22-2016)
Old 12-22-2016, 02:30 AM   #32
CHMBRZ
Drives: 2016 Subaru BRZ Limited
So would you not recommend this kit to someone like myself, I use my car as a daily and there is a lot of stop and go here in Hawaii?
CHMBRZ is offline   Reply With Quote
Old 12-22-2016, 03:03 AM   #33
VerusEric
VerusEric's Avatar
It will still offer greater heat rejection than the OEM radiator.
However, the fans not being on a shroud does reduce cooling efficiency at low vehicle air speeds. The good news is that the engine doesn't have large cooling requirements at these low air speeds typically (engine idling doesn't put a lot of heat into the cooling system), so the fans do their job and keep the engine cool without a shroud.
Thanks,
Eric
Old 02-23-2017, 11:06 PM   #34
VerusEric
VerusEric's Avatar
We wrapped up another few radiators and wanted to share the photos. These really are works of art as well as extremely functional .
Thanks,
Eric
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
CHMBRZ (02-25-2017), Takumi788 (02-24-2017)
Old 02-25-2017, 01:54 AM   #35
CHMBRZ
Thanks,
Eric
What's those connectors on the last pic?
Old 02-25-2017, 01:55 AM   #36
VerusEric
VerusEric's Avatar
Part of the kit so that you don't have to cut any oem harness wires for the relay install.
Thanks,
Eric
CHMBRZ (02-25-2017)
Old 02-25-2017, 02:27 AM   #37
CHMBRZ
Thanks,
Eric
Nice touch. Would this be better than running an oil cooler?
Old 02-25-2017, 03:33 AM   #38
megamarines
megamarines's Avatar
Drives: 2015 FR-S RS 1.0
Send a message via AIM to megamarines
Oil cooling is different than engine cooling. You should run a rad and oil cooler together.
megamarines is offline   Reply With Quote
Old 02-25-2017, 05:03 PM   #39
VerusEric
VerusEric's Avatar
This is for the coolant/water side of engine cooling. Oil cooling is a completely different part of engine cooling.
http://www.ft86club.com/forums/showthread.php?t=114293
Thanks,
Eric
cdrazic93 (02-25-2017), CHMBRZ (02-25-2017)
Old 02-25-2017, 05:19 PM   #40
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
This is why i like this particular forum. Bros helpin bros, while bein a bro
The Following User Says Thank You to cdrazic93 For This Useful Post:
bcj (07-08-2023)
Old 05-04-2017, 01:55 AM   #41
choi0706
Drives: t
no longer getting built?
choi0706 is offline   Reply With Quote
Old 05-12-2017, 04:39 AM   #42
MicheleAbbate
MicheleAbbate's Avatar
Drives: Grr Racing FRS & BRZ
Send a message via AIM to MicheleAbbate
Curious as well.
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
MicheleAbbate is offline   Reply With Quote
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 10:15 AM
Verus Engineering Billet Transmission Beta Tester Run VerusEric Engine, Exhaust, Transmission 62 04-26-2020 02:44 PM
Gauging Interest: High-Quality Vinyl (Reflective) Plate Replicas Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2014 04:06 PM
Gauging Interest for a Tint Install Day @ Pure Automotive Performance Pure Automotive Mid-Atlantic 71 03-03-2013 11:22 PM
Gauging interest: GB on a super high quality drying towel Hamza7 CANADA 34 11-25-2012 06:25 PM
