Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 07-06-2012, 02:23 AM   #29
Ravine
Ravine's Avatar
Drives: Red FT-86 GTS Auto
Originally Posted by RAN94A View Post
Hey Stanley
yea lifestyle is way to exxy for all their stuff and TBH im not interested in "audio perfection" i just want to be able to crank my music loud and have bass present lol.
So i'll be going down the cheap and easy route.
Hahahaha i'm the opposite. I'm happy to spend the money as long as it's gonna be goooooood.
Also the custom box is pretty appealing because the boot is too small. This won't even fit in. We tried.
http://www.rockfordfosgate.com/produ...?itemid=120453
Ravine is offline   Reply With Quote
Old 07-06-2012, 03:14 AM   #30
RAN94A
Grand PooBah
RAN94A's Avatar
Drives: Toyota 86 GT MT
gotta have that crisp note for all the happy hard mixes haha.
far out.. im surprised that doesnt fit.. too tall??? Guys in the states have got some pretty serious looking subs in their boots..
RAN94A is offline   Reply With Quote
Old 07-06-2012, 03:28 AM   #31
Ravine
Ravine's Avatar
Hahaha of sho. Gotta get that punchy kick going hard!
Also, that doesn't fit in the GTS because of the floor mat with the raised donut for the full size spare.
I'm sure it'd fit in the GT.
Old 07-06-2012, 04:39 AM   #32
Z86
Drives: 86 GTS Auto in Pegasus White
Pretty sure GT and GTS have the same boot space, full size spare (16 steel in GT, 17 alloy in GTS) and that "86" mat with the raised donut..
Z86 is offline   Reply With Quote
Old 07-21-2012, 10:21 PM   #33
proficience
proficience's Avatar
Drives: Velocity Orange 86 GTS M/T
Bump!
So what have people done to their audio set-up so far?
C'mon guys!
proficience is offline   Reply With Quote
Old 07-21-2012, 10:40 PM   #34
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Nothing but stockpiled... waiting for the car haha
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 07-21-2012, 11:23 PM   #35
st162celica
Drives: 86 GTS Manual - Tornado Grey
I'm waiting for my car too. Wish the gts came with option nav like Brz.
Who needs nav. I want head unit rca's and sub control.
st162celica is offline   Reply With Quote
Old 07-22-2012, 04:03 AM   #36
BD
Drives: GT86
I'm from a home audio background and know naught about car audio, but as wondering: would the stock head unit be able to comfortably drive a pair of Dynaudio front splits to ±90db or would an outboard amp be needed?
Cheers
B
BD is offline   Reply With Quote
Old 07-22-2012, 07:44 AM   #37
ChocolateNick
Drives: Sonic Blue GTS AT
Cheers
B
Depends on the wattage of the splits. From experience I can tell you some head units can drive splits, but they are almost always better off when run through an amp.
ChocolateNick is offline   Reply With Quote
Old 07-22-2012, 08:10 AM   #38
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Cheers
B
A set of dyns deserve to be run off an external amp, a HU, even though it may say it has 4 x 50wrms, usually is no where near that, that number may be correct but at a certain frequency.
Dyns love power, i would use a minimum of a quality 2 x 50wrms amp on them, if not 100wrms.
At one stage there in my SQ setup i was putting over 300wrms into my OZ Audio/ Vifa front stage (each side)
When i was competing i had a 4 x 75wrms amp running the fronts, one channel for each speaker (2 x tweeters, 2 x mids)
Old 12-01-2012, 03:34 AM   #39
st162celica
Has anyone pulled their Aus 86 HU out to see if there's spots in the back to add an aftermarket subwoofer??
I've seen a couple of the guys in the states have done it... but we get a different head unit to the FR-S.
And dont just say replace the head unit, i'd prefer to keep it simple and stock looking just with some extra kick in the back.
Cheers!
kept my stock sat nav from the GTS.
4x100rms - 2 powering the stock front speakers.
2 powering the 12in sub ( standard non ported box ) Box re-sealed again and glued in some house roof insulation.
Pulled out the full size spare and all the foam, sub box just sitting in the middle down low, facing rear. Puncture repair kit in the boot and a foam in a can. Got roadside assistance too. When travelling up the coast, pull out the sub and put the spare in.
Amp and sub are about 7 years old. Still going strong.
So just spent money on plugs, speaker cable, power cable and fuse.
Amp has high input connectors, (so no need for RCA's and converter) ran all the speaker wire to the boot down the centre console. 1 side speaker cable, other side power cable, gets a bit tricky once you get to the back seat. Power cable straight down the middle, all other cabling in a hardened under the rear seat along the curves of the seat.
Bought 2 separate opposite M/F OEM connectors - repco, other off ebay. Basically ran all my cabling without even having to cut into the oem harness. Can easily pull out the headunit and connect back to stock set up. A bit of a fuss to do, but I guess I like clip plugs and soldering, wires.
Amp and sub just sitting in the boot. Still deciding where to mount the amp. It is quite big and I may just get a 5 channel smaller one in the future.
Took the back seat off and I was not really happy to cut into the back seat if I change it later on. May mount the sub in the spare tyre space and custom build a thin boot liner and have clips attaching the sub box to it in the middle. I want to be able to unclip the sub at anytime i need.
All speaker wire ran to the sub, 4 wires for front to amp to control front speakers then those wires go back to the headunit into the plug for the stock speakers. 4 wires for the rear speakers used for the sub. So that means i have bass control via the headunit. E.g Fade Front/Rear
Rear speakers not connected. May replace them with same size speaker and amp them once i get a 5 channel amp.
Cost me about $200
$140 ? for Kicker 4g kit.
$20 extra speaker wire.
$20-35 Oem plugs
Looking at sound deadening. Not really fussed at the moment.
2 days work - Soldering the extra harness's i bought took up a bit of time. Also pulling off all the panels in the car. (you may break clips) take your time.
Need to dig out all the pics.
Quoted around $1000 for the same thing with door deadening. Also they would not have done the OEM hot plugs like i did but rather cut into the factory harness. Once I saw the quote i took it as a challenge/project.
If anyone is feeling over whelmed with doing it yourself.
Go to this place. http://www.fhrxstudios.com/ @Fhrx
The guy there (Marty) was great to talk to. He know's his sh*t, and is a straight shooter. His passion for it, pretty much inspired me to get off my a$$ and do it myself like I wanted to but was putting it off. @fuddbutter can vouch for this guy. I would def recommend people go there.
In the end, presently surprised by the sound of the stock speakers when amped. Sub sounds awesome to the point, I turned it down a bit.
Dammm, rear view mirror vibration. 1st thing i need to work on. !!!!! Been ignoring it for weeks Had to bend out my rear number plate a bit due to the vibration.
Old 12-01-2012, 06:31 AM   #40
Palmy
Palmy's Avatar
Drives: '12 86 GTS (AUDM)
Im no expert but Im gonna have a go at making this work when I have some free time.
http://www.cadencesound.com/products/X1.html
Had it in my old car.
Palmy is offline   Reply With Quote
Old 12-01-2012, 07:10 AM   #41
a.beck
Doing it wrong.
a.beck's Avatar
[ame="http://www.youtube.com/watch?v=mR8KRBWKIoI"]Fat Pizza - Sick Mate Sick Subwoofer (Music Video) - YouTube[/ame]
a.beck is offline   Reply With Quote
The Following 2 Users Say Thank You to a.beck For This Useful Post:
JakeG (01-22-2014), st162celica (12-01-2012)
Old 12-01-2012, 07:22 AM   #42
nix
nix's Avatar
Drives: AVO BRZ
The BRZ eclipse AVN827GA nav unit has 3x rca preamps. :-)
Planning my audio build atm but it will just be fully dynamatted, speaker and wire replacement and amp and custom fibreglass oem style sub enclosure in the boot. I'll post it to my build thread when done.
nix is offline   Reply With Quote
Question with adding a subwoofer Shizuma Electronics | Audio | NAV | Infotainment 128 11-17-2014 02:45 AM
Subwoofer prewiring Nate219BRZ Electronics | Audio | NAV | Infotainment 3 09-09-2013 06:56 PM
OEM Audio Plus Subwoofer K2 Electronics | Audio | NAV | Infotainment 28 12-21-2012 11:28 AM
Subwoofer added mdf4uk Electronics | Audio | NAV | Infotainment 10 06-28-2012 02:37 AM
Does BRZ and FRS come with a Subwoofer? R0ME0 FR-S / BRZ vs.... 6 05-07-2012 03:54 PM
