Old 05-18-2016, 02:35 PM   #29
Originally Posted by Apex-Apex View Post
I'm still trying to figure this out myself. It's been a few track days but I think I'm getting closer.
Just have ken set up your car, if he can manage to not spin out
Or I can do it.
Old 05-18-2016, 02:52 PM   #30
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by dp1 View Post
Of those of you who use(d) JRZ RC1 TWO, what springs and what settings do you use track vs street, out of 14 clicks for compression and 24 clicks for rebound? I don't know if JRZ gives starting recommendations.
For example - made up values you can copy/paste/edit:
Front springs (~500lb/ft or 9kg/mm) + Rear springs (~600 lb/ft or 11 kg/mm)
Sway Bars (front stock 18mm + rear stock 14mm)
Street Front (-12 clicks from full hard compression and -15 clicks from full hard rebound)
Street Rear (-12 c / -15 r)
Rough Track Front (-9 c / -12 r)
Rough Track Rear (-9 c / -12 r)
Smooth Track Front (-8 c / -10 r)
Smooth Track Rear (-8 c / -10 r)
I understand that rough surface at Sebring would benefit from different settings than a brand new and smooth surface at Watkins Glen for example, but I don't yet know which settings I should start with. I have more to read up on, from resources shared by @CSG Mike and web pages like http://www.renntrack.com/forums/show...e-As-requested, https://rideapart.com/articles/suspe...ession-damping, http://www.hyperracing.com/pages/tec...y_no_more.aspx, etc.
Please PM me if you prefer to keep private, thank you.
On my adjustable setups (motorcycle and car), I start with the adjusters in the middle, spend some time getting comfortable, then analyze what the car is doing that I want to correct from there.
Old 05-19-2016, 08:23 AM   #31
Apex-Apex
Apex-Apex's Avatar
Or I can do it.
Ken will die. We'll be at Buttonwillow on 5/28.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 05-25-2016, 12:52 PM   #32
@dp1, @enivid has also gone from Ohlins to JRZ. He may able to shed some light...
Old 05-25-2016, 02:02 PM   #33
dp1
driving smoother faster
Drives: Sold
Thanks! I've been in touch with @enivid and he's been kind to shed light. Much respect for his TT experience and happy for his lower lap times with JRZs
dp1 is offline   Reply With Quote
Old 05-25-2016, 03:11 PM   #34
He's been playing with the adjustments, but even with everything out of whack, he was STILL 2 seconds faster than his best time on the Ohlins.
His latest lap time is 6 seconds faster than his best on the Ohlins, on a 100 second lap.
He's also on the same 9k/11k that we got for you, which did have a bit of a learning curve from the understeery biased Ohlins.
Old 05-25-2016, 03:23 PM   #35
dp1
Drives: Sold
Thanks...good times...bye bye comfy understeer...I can see busy hands (in the corners) in my future
Old 05-25-2016, 04:11 PM   #36
Quick hands, quick driver.
Old 05-26-2016, 12:30 AM   #37
enivid
enivid's Avatar
Drives: WRB JR BRZED
We're 50 emails deep already. He's my new best friend.
enivid is offline   Reply With Quote
Old 06-03-2016, 02:22 PM   #38
dp1
Drives: Sold
Need feedback on JRZ RS Double vs JRZ RS1 vs Tein SRC
Recommended settings for JRZ RS double adjustable dampers, out of 14 clicks for compression and 24 clicks for rebound.
These settings from JRZ USA are the starting points for 9k (~500lb) front and 11k (~600lb) rear springs, so ask your vendor or JRZ USA how to go about fine tuning from here on. I bought these through CSG and they gave me recommendations for initial settings (not the same as below) and instructions on how to adjust from baselines based on observed behavior.
First go full clockwise to full soft, then go counterclockwise to the first groove/click - the starting/0 point - then stiffen by going further counterclockwise for a specified number of clicks. Stop at the count of the last groove/click. In other words, C6 below means it refers to the compression knob and once you get to full clockwise/soft, go counterclockwise and stop at the 7th groove/click (fist click is 0 then 6 more from there).
- Street Front C6/R8
- Street Rear C4/R5
- Track Front C8/R12
- Track Rear C7/R8
Please post your settings when you've dialed them in to your liking, and note spring rates if different and sway rates if not stock. Thanks
Old 06-10-2016, 01:03 PM   #39
dp1
Drives: Sold
Anyone knows height of the front vs rear springs on JRZ RS double adjustables? Just the main springs without helper springs. Is it 6" front and 4" rear? @CSG Mike?
Old 06-10-2016, 01:30 PM   #40
That is correct for your setup; use the helper springs in the rear.
Old 06-10-2016, 02:10 PM   #41
dp1
Drives: Sold
Clarified with @CSG Mike, it's 500lb 4" spring + helper spring in front and 600lb 6" spring + helper spring in rear. Thx
Old 06-17-2016, 11:34 PM   #42
dp1
Drives: Sold
I don't know how much to attribute to the most recent suspension reinforcements vs new JRZ RS vs increasingly feeling more comfortable driving closer to the limit but I'm 4 seconds faster at NJMP Thunderbolt than last year and the mild oversteer with proposed initial JRZ USA track settings is very easy to control. Will try different adjustments. I am easily leaving few more seconds on the table 8). Not cheap but worth every penny.
Double oil cooler kcam86 Tracking / Autocross / HPDE / Drifting 16 05-20-2016 09:46 PM
ABS feedback?? calidus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-17-2015 06:39 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
sorry double post LS13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-29-2012 02:42 PM
Double U T F...is this for real? Hawk77FT AUSTRALIA 20 07-14-2012 05:21 PM
