Old 03-22-2016, 05:26 PM   #29
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
found it ish, Next, mirror drag is quantified at 3-6% of total vehicle drag for a modern car in a report called Contribution of different devices to the total drag (PDF):
"A very well designed mirror increases the drag of a car of approximately ΔCd=0.012. But this value can reach 0.025 to 0.030 for the worth [worst] designs. Actually it seems reasonable to think that the average value for ΔCd is of around 0.015"
"...[the mirror's] combination with the A-pillar contributes to the creation of trailing vortices at the side front of the car, which are highly drag-consuming
source:PDF: Contribution of different devices to the total drag - from the reports archive of Professor Lennart Löfdahl, Chalmers University of Technology, GÖTEBORG, SWEDEN
fumanchu1 is offline   Reply With Quote
Old 03-22-2016, 05:47 PM   #30
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
are we really arguing over the fuckin drag co-efficient of a CAR MIRROR?
The Following 3 Users Say Thank You to cdrazic93 For This Useful Post:
86kahl (03-22-2016), Juvenile (03-22-2016), Tcoat (03-22-2016)
Old 03-22-2016, 06:04 PM   #31
extrashaky
Drives: 2014 BRZ Limited
Here's a picture:
If the US Air Force felt like it was okay to put a rear view mirror on the U2, the presence or absence of a mirror is going to make fuck-all difference on your car.
The Following User Says Thank You to extrashaky For This Useful Post:
86kahl (03-22-2016)
Old 03-22-2016, 06:22 PM   #32
Austontatious
Drives: 2016 FR-S manual
Wow. You know it doesn't matter what you are discussing on the internet, everyone always has to be ****s.
1 - EVERY car manufacturer on the planet is working on replacing mirrors with cameras. The hold up is with archaic rules in the DOT. The same rules that are holding up active LED and laser headlights. The fact that major manufacturers have already developed these systems pretty much invalidates every one of the "dumbest idea ever" posts.
2 - my phone has a 1080p display and can record 1080p video. the components are off the shelf at this point. In terms of hardware required, this could be done for the same amount of money as a set of high end aftermarket mirrors.
3 - you guys will discuss cat deletes all day for a gain of ONE horsepower, but reducing the drag of the car by 3-5% is "not worth the time" and "illegal". If aero is so insignificant, why did Toyota bother with putting under body panels on to smooth airflow under the car?
I'm not sure if I have ever seen a forum so full of trolls. Good to know that a community is so unsupportive and stagnant that they are unable to answer a simple question of "have you ever seen an off the shelf system that would work?". A simple "no" would have sufficed.
Austontatious is offline   Reply With Quote
The Following 3 Users Say Thank You to Austontatious For This Useful Post:
Brayden_23 (03-23-2016), IceFyre13th (03-22-2016), p1l0t (03-22-2016)
Old 03-22-2016, 06:28 PM   #33
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
LOL don't listen to these Trolls OP!
My girlfriend's 1966 Ford Bronco only has 1 side mirror and it's on the drivers side and hey, if Ford can do it why can't you? Go right ahead! post pics when done!
Instagram: trevor.parque
The Following 2 Users Say Thank You to MisterSheep For This Useful Post:
86kahl (03-22-2016), go_a_way1 (03-22-2016)
Old 03-22-2016, 06:30 PM   #34
Austontatious
And extrashaky: the U2 had a pair of turbine engines generating 38,000lbs of thrust and it flew at 70,000ft where the air is less than 5% the density that it is at sea level. out of all of the troll posts, this was the one that was the least relevant.
The Following User Says Thank You to Austontatious For This Useful Post:
Old 03-22-2016, 06:36 PM   #35
NahumCC
Drives: 2013 FR-S 10 Series
Originally Posted by extrashaky View Post
This is a silly idea. Please do it so we can laugh at it.
What's funny is this car is about being each to their own. I'm sure there were probably people who thought the same thing when I kept pushing the heated mirror issue on US spec FR-S and what it would take to add them since it was clearly established up to that point FR-S didn't come with them here.
Well guess what. We found you could add it on a 10 Series buy adding the mirror housings and plugging in the correct relay for a total plug and play and through the efforts of @Silent_Dan doing it on his base model FR-S we've found you can just add the pins to the door harness (both ends) and splice wiring between the pins you add because we also tracked down the Toyota Wire Harness repair manual which list all the part numbers to order the repair pins with a section of wire pre-crimped which more or less makes it plug and play as well other than having to run the extra bit of wire.
So kudo's to this guy/gal who wants to do something unique. Good luck.
NahumCC is offline   Reply With Quote
The Following User Says Thank You to NahumCC For This Useful Post:
Silent_Dan (03-22-2016)
Old 03-22-2016, 06:39 PM   #36
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
A couple of things.
I was going to troll you and you sincerely deserve it; this is ridiculous, but I see those positions are already filled.
Even though the amount the mirrors are dragging is likely as much as the front license plate and a really insignificant thing to focus so much effort on, I'll help because I claim to see no basis for being able to dictate to others what they can do with their own cars. This is me walking my talk.
Snarking system deactivate.
Sarcasm cannons do not lock target.
TRD claims that these split the air effectively and allow the mirrors to slide through that slot more smoothly. You don't have to engineer anything, just buy em and bolt them on. I'm actually looking at picking up a set myself, for that reason secondly, firstly for aesthetic reasons. I think the trim at that spot now looks stupid.
http://www.trdparts.jp/english/86_pe...line/aero.html
The Following User Says Thank You to themadscientist For This Useful Post:
Old 03-22-2016, 06:49 PM   #37
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
See, when i saw this thread my brain said fender mounted mirrors, but I think this thread is just about as good
Sent from my Glade Air Freshener
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following 3 Users Say Thank You to yelsew For This Useful Post:
86kahl (03-22-2016), go_a_way1 (03-22-2016), p1l0t (03-22-2016)
Old 03-22-2016, 07:09 PM   #38
p1l0t
p1l0t's Avatar
Yeah that's JDM AF. As a pilot though, and having taking master's level advanced aerodynamics, the delete is a great idea. In cars you only really care about your C sub d (Coefficient of Drag). Mirrors may "only" reduce drag by 3-7% but on our cars since they only have a .27 Cd anyway (part of the reason I bought my BRZ besides the 18" CG) it will probably be more towards the latter. As far as 'oh who cares' well every little fraction of a second counts. 1hp, 1lb lighter, 1% better aero... it's all improvement. Plus deletes could be a pretty inexpensive mod even with the electronics. I like the idea of the purposeful boundary layer drag vortex generators to reduce the overall drag too, although I never buy them because I feel like they are designed more for looks and not actually wind tunnel tested which could make them hurt more than help if it's done wrong. (Like they should probably be WAY smaller than most are). Mirror deletes are a pretty safe bet though because anything that just sits out there in the wind is pure drag. As for the U2 the little tiny ass mirror caused a 2% increase in fuel burn! It was necessary to make sure they weren't leaving a contrail which is a like a giant arrow in the sky pointing out your location. Not a good thing for a stealth aircraft...
Old 03-22-2016, 07:30 PM   #39
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by cdq85 View Post
I'm going to remove my steering wheel and maneuver the car with my mind.
[ame]https://m.youtube.com/watch?v=Kb43Nxuwc4I[/ame]
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
cdq85 (03-25-2016), Ultramaroon (03-22-2016)
Old 03-22-2016, 07:32 PM   #40
How fast do some of you guys drive where the mirrors drag is even a measurable impact on speed or mileage?
I have factory mud flaps, drive with my windows open and frequently have my arm out the window. Does this mean I am sucking up gas and going way slower than I should be?
This is not a formula one car we are talking about here and some things can be taken too far for the results that are gained.
Gonna head over to the Prius room where they really know their stuff on this topic and see how many thousands of dollars I can spend to save .002 mpg.
cdrazic93 (03-22-2016), Cole (03-23-2016), soulreapersteve (03-22-2016), Speck (04-01-2016)
Old 03-22-2016, 07:38 PM   #41
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
I'm too short to hang my arms out the window in a relaxed way.
Then again, I have the seat adjusted to 2 pumps from the very bottom...
The Twins make me smile
Old 03-22-2016, 08:11 PM   #42
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
No.
cdq85 is offline   Reply With Quote
***Rexpeed Convex Side Mirrors and Carbon Fiber Side Mirror Covers*** FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 249 12-07-2015 02:28 PM
WTB Driver Side Side Mirror Cover technoid Want-To-Buy Requests 0 08-20-2015 10:34 PM
WTB: Side view mirror(Pearl P/side) Vesalera Want-To-Buy Requests 4 02-19-2015 03:46 PM
WTB right side mirror BRZRey Want-To-Buy Requests 0 02-04-2015 11:03 PM
OEM Rear View Mirror and OEM Side Mirror hanabie Cosmetic Modification (Interior/Exterior/Lighting) 2 03-28-2014 11:07 PM
