| View Poll Results: POLL: What RPM is Your Rev Light Indicator Set To? | |||
| 7400 RPM |
17 | 18.89% |
| 7300 RPM |
3 | 3.33% |
| 7200 RPM |
11 | 12.22% |
| 7100 RPM |
3 | 3.33% |
| 7000 RPM |
22 | 24.44% |
| 6900 RPM |
5 | 5.56% |
| 6800 RPM |
7 | 7.78% |
| <6800 RPM |
22 | 24.44% |
| Voters: 90. You may not vote on this poll | |||
#29 |
Senior Misanthrope
#30 |
OK, so much for the red light. How many times y'all hit fuel cut off in moments of over exuberance?
#31 |
Drives: 2014 BRZ Limited
Okay, that makes sense if he's only driving the car on a track. In traffic he'd never get out of second gear.
#32 |
Me neither that is why I say it is set to off. I don't need no stinking light to tell me where I am at. As I have said before when I teach the grandson to drive the car I will be covering the tach so he learns by sound and feel not by reading a gauge. Not like everybody drives the same way and needs to shift at exact revs all the time anyway.
#33 |
Drives: 2016 FR-S
It is set at A mere 3200. A nice gentle brake in period
Sent from my SM-G900P using Tapatalk |
#34 |
If you read the whole break in procedure it says very specifically not to do the same things all the time. Supposed to vary the speed you drive, stay off of cruise and mix things up. Not sure if that applies to shifting as well though but I still shifted at varying revs at break in.
#35 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
The motor has a 7450 redline but you can't access that so I put it at 7400.
#36 |
Dozens over the past 3 years and 46k miles, bet some cars have hit hundreds.
#37 |
If you listen to some people on here then every single time they shift! At least that is what they will tell you.
#38 |
Drives: 2015 BRZ
First lights at 5500, red lights at 7500.
Sequential FTW. |
#39 | |
Drives: 2016 FR-S
#40 |
Given that there's probably a few dozen 86's autocrossing every single weekend, bouncing off the rev-limiter down the straight is better than shifting to third or worse lifting off the throttle, we'd know if there were serious issues with hitting the fuel cut multiple times.
#41 |
I may be confused ........
but, as I thought I understood the question ...... I have the shift light set at 6,500, because it takes me a while to react and I don't like hitting the fuel cut off.Yes, upon rare occasions, I have hit the fuel cut off ...... because I was having an exceptionally slow day ....... ![]() humfrz |
#42 |
hey you, yeah you <3
Drives: 2014 37J FR-S
I meant I shift by 7k. Not at.
1st at 3.5, 2nd at 2.5, 3rd at 6.5k, 4th around 4k and 5 and 6 below 4k
| Tags |
| rev, rev light indicator, rpm |
| How to set the Shift Light & Gear Indicator Display Settings | EsoBOFH | DIY (Do-It-Yourself) Guides | 76 | 04-21-2020 08:42 PM |
| Slip Indicator & ABS light turned on during highway driving... | Pwolf | Issues | Warranty | Recalls / TSB | 24 | 01-15-2018 11:52 AM |
| Engine Light On (malfunction indicator lamp) | polarstorm | Engine, Exhaust, Transmission | 0 | 06-01-2013 11:14 AM |
| Slip Indicator Light | erom | BRZ First-Gen (2012+) — General Topics | 17 | 06-10-2012 10:17 PM |
| Setting rev indicator light video | ayau | BRZ Photos, Videos, Wallpapers, Gallery Forum | 3 | 06-09-2012 10:58 PM |
