Old 09-23-2016, 08:51 AM   #29
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
Konig Hypergram F 17 R 18
installed konig wheels yesterday.
Front 17x9J ET40 245-40-17 camber -2
Rear 18x8.5J ET38 255-35-18 camber -1.5
lowered with bilstein B14.
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
The Following 5 Users Say Thank You to Yobiwan For This Useful Post:
deejaylew (09-23-2016), funwheeldrive (05-11-2017), JMon85 (05-13-2017), makinen (09-23-2016), SG02WRX (07-13-2018)
Old 09-23-2016, 12:35 PM   #30
deejaylew
deejaylew's Avatar
Drives: AP1 Honda S2000, Focus RS
Seeing the hypergrams for the first time today. It looks like Konig took a big step forward with this wheel, lightweight and better manufacturing process for improved durability and a good design too. Nice.
deejaylew is offline   Reply With Quote
The Following User Says Thank You to deejaylew For This Useful Post:
CatDaddysBBQ (09-23-2016)
Old 09-23-2016, 01:05 PM   #31
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Hmm looks like they have decent BBK clearance. They're a strong contender for a set of good lightweight 17x9s if/when I go that route for a separate set of track wheels.
Lynxis is offline   Reply With Quote
Old 04-24-2017, 06:09 PM   #32
swarb
Taken from @sirbobbinhood please post more pics!!
Old 04-25-2017, 03:06 PM   #33
sirbobbinhood
sirbobbinhood's Avatar
Drives: 2014 WRB BRZ
I'll try to get some more pictures of them today if I can. It needs a bath pretty bad the wheels are dirty after 3 hours of driving and a full day of autocross.
I can tell you that they're awesome wheels so far. No problems with them at all and they look outstanding. I had one that took a bit more than usual to balance out but that could have been the tire too.
sirbobbinhood is offline   Reply With Quote
Old 04-26-2017, 11:35 PM   #34
sirbobbinhood
Wheel pics
@swarb Finally delivering on those pictures I promised. Pic heavy as you would expect.
These are 17x9 bronze wheels. I have some pretty aggressive camber because racekar.
The Following 2 Users Say Thank You to sirbobbinhood For This Useful Post:
mrg666 (06-18-2017), swarb (04-27-2017)
Old 04-27-2017, 12:31 AM   #35
e1_griego
e1_griego's Avatar
Drives: Many
^^We met at PIR a few weeks ago.
I have the bronze ones, too:
I think I'm going to buy the grey ones for next next set, but I'm curious how close the konig grey is too the factory grey (i'm hoping it's different enough that it doesn't look colormatched....)
e1_griego is offline   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
swarb (04-27-2017)
Old 04-27-2017, 03:11 AM   #36
e1_griego
e1_griego's Avatar
Drives: Many
I don't think I have any stationary pics. A few more from events, but nothing great:
The Following 2 Users Say Thank You to e1_griego For This Useful Post:
funwheeldrive (05-11-2017), swarb (04-27-2017)
Old 05-11-2017, 12:02 PM   #37
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Does anybody have a guess if they will clear BBK?
pgranberg11 is offline   Reply With Quote
Old 05-11-2017, 03:54 PM   #38
sirbobbinhood
Do you have a print out that I could use to check the clearance? If you can find something for me I'll pull a wheel and check.
Old 05-11-2017, 04:00 PM   #39
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
ah unfortunately I don't. I can tell you I have the STi brembos if that helps any. I'm not sure where I would even find a print out?
Old 05-30-2017, 04:33 PM   #40
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Originally Posted by Bog86 View Post
Just picked up a set. these are the Opal in 17x8 on Michelin PSS 225/45.
Reviving an old thread here but did you need hubcentric rings to mount these? Or was the centre bore a perfect fit?
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 05-30-2017, 04:48 PM   #41
swarb
www.konigwheels.com
You don't "need" hubcentric rings to mount them. If you want them to be perfect, just buy the rings.
Almost no wheels except oem have center bore at an exact fit. That would limit their market to almost zero cars. It's safe to say they aren't hubcentric.
The Following User Says Thank You to swarb For This Useful Post:
brzzy (05-30-2017)
Old 05-30-2017, 05:23 PM   #42
churchx
churchx's Avatar
Drives: 2014 GT86
swarb: i know, that lugcentric wheel is centered and mounted strong enough with tighening centering lugnuts .. but after experienced scare case of non retightened after while driving lugnuts getting undone a bit (i know, own lazyness & forgetfulness to blame), i'd prefer to have some extra ensurance for piece of heart. Have naive hope that if something like that happens again, i'll be able to notice with less chance of something major breaking. With larger center hole and non tightened lugnuts, won't studs break off due extra play after few wheel rotations? Also isn't it simpler to do first turns of lugnuts on wheel change/unmount, while wheel is still on ground? What will happen if trying to do that w/o centering ring on wheel with non native hole bore?
Konig Rims- what do you think? KatrinaR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-25-2015 02:35 PM
Konig Torch 18x8.0 +35 khan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-21-2014 01:27 AM
WTB- Konig Daylites solort Want-To-Buy Requests 0 01-08-2014 12:07 AM
Konig Wheels pghfan19 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-25-2013 01:24 AM
Konig deception oaroyale Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-02-2013 10:02 PM
