Old 03-29-2016, 12:35 PM   #29
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by 200hp/tonne View Post
The plumbing in that thread is exactly like Forrester, from low pressure Heater outlet to suction side water pump inlet - purely an oil warmer as there would be very little flow across the oil cooler. Tstat only controls coolant flow through radiator, heater core and Automatic trans cooler get permanent flow. Check out the coolant flow diagram.
Sorry for thread jack, i promise this will be my last post on this topic.
No thread jack at all, I want it hooked up correctly and I believe I do but I can't find *any* coolant flow diagrams, I am merely going off intuition. Please post a coolant flow diagram if you have one!
VerusEric is offline   Reply With Quote
Old 03-29-2016, 01:16 PM   #30
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Velox ! good stuff
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 03-29-2016, 01:21 PM   #31
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Nice build thread, I can't wait for more content related to your car, and more details on the Forester oil cooler.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 03-29-2016, 01:23 PM   #32
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
I remember seeing one when planning this project out, cant find one now. I also went off of the arrows on the heater hoses.
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 03-29-2016, 01:28 PM   #33
VerusEric
VerusEric's Avatar
I cant find one now either, I remember i went off of the arrows on the heater hoses.
I don't think one exists! Not sure why, kind of disappointed at Subaru and the service manual for not providing one. I will gather pictures and post in here my thoughts of why I plumbed it the way I did.
Ultimately the OEM EOC is *not* going to do a ton, it's inlet/outlet are 1/2" and 3/8" respectively, that is *not* much flow, regardless of coolant temp.
Old 03-29-2016, 01:33 PM   #34
VerusEric
VerusEric's Avatar
Originally Posted by Joe-G View Post
Will the brake cooling plates require the hub to be removed, and sandwiched in for installation?
I will get pictures in here shortly as I am working on install manual now. They do not require removal of hub nor sandwiched between the units so they will work with both BBK and OEM.
The Following 3 Users Say Thank You to VerusEric For This Useful Post:
ATL BRZ (03-29-2016), BatStig (03-29-2016), Joe-G (03-30-2016)
Old 03-29-2016, 02:08 PM   #35
DHitHim
Drives: 2015 CWP Limited BRZ
Did I see Full-Racing Turbo Kit?!?!?!?!?!
DHitHim is offline   Reply With Quote
Old 03-29-2016, 02:23 PM   #36
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
And finally, we are gearing up for brake cooling kit production as well which is exciting. I'll have photos of it installed on car in a few weeks.
The blow molded pieces matched up well with the 3D printed units. We asked the manufacturer to make a few changes, namely wall thickness and change the color to black, and hit the go button on production.
Sorry if you've addressed this elsewhere, but are you planning on selling a brake duct kit that would work with the Essex Endurance package? Basically, all the inboard ductwork without the upright-side parts. If so, do you have an estimated availability date?
GSpeed is offline   Reply With Quote
The Following User Says Thank You to GSpeed For This Useful Post:
kask2_6.0 (03-29-2016)
Old 03-29-2016, 02:37 PM   #37
VerusEric
VerusEric's Avatar
Yes!
We can come out with a package like this; however, I believe the Essex unit uses 3" inlet into the bracket? Our outlet of the pancake/internal fender duct is 2.5". This could probably be easily adapted but you'll lose some efficiency as you know I'm sure.
We're trying to get kits out the door in the next 3-4 weeks, nearly everything is inbound at this time.
Thanks,
Eric
Old 03-29-2016, 03:22 PM   #38
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Yes!
Thanks,
Eric
Ah, didn't realize yours was 2.5". Yeah, no bueno. Thanks for looking out. We'll figure something out.
Jake
Old 03-29-2016, 05:04 PM   #39
DHitHim
Whoops I meant Full-Race as in the EPIC Manifold builders for Hondas and SR20DETs and etc.! That's so sick!!!! I would love an NA header from them! (I plan to go JRSC)
Old 03-30-2016, 05:29 PM   #40
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
That's awesome! I remember coming across a set, which seemed to be mounted that way... Sucks for those who have stuck hubs Not user friendly at all =T
Joe-G is offline   Reply With Quote
Old 04-11-2016, 02:00 AM   #41
VerusEric
VerusEric's Avatar
Apologize for the lack of updates, had a busy few weeks.
I moonlight (weekend warrior) for IndyCar for 2-3 races a year as a part time employee for the series. It's a fun time and I get to catch up with my buddies in the series. Below are some photos I snagged post race of the cars going through tech inspection.
Kind of neat little snippet, IndyCar engines use the same turbo CHRA that is going on the Velox shop car! It's a 7163 with different compressor and turbine housings to fit space and weight constraints, but the CHRA is the same. Pretty neat.
The radiator is in as well. Grabbed a few quick photos of it.
Thanks,
Eric
The Following 6 Users Say Thank You to VerusEric For This Useful Post:
ajaxthebetter (04-11-2016), Clint_1111 (04-11-2016), DAEMANO (04-11-2016), GSpeed (04-11-2016), johan (04-11-2016), SkAsphalt (04-11-2016)
Old 04-18-2016, 04:14 AM   #42
VerusEric
VerusEric's Avatar
Sorry for the photo overload!
Tear down:
Comparing OEM radiator to the one we designed:
Also did some assembly on the brake kits soon to be released:
And backing plate/carbon duct installed on car:
Thanks,
Eric
The Following 9 Users Say Thank You to VerusEric For This Useful Post:
ATL BRZ (04-18-2016), DAEMANO (04-19-2016), danny_d19 (04-18-2016), GSpeed (04-18-2016), ichitaka05 (04-20-2016), johan (04-18-2016), kask2_6.0 (04-18-2016), kch (04-18-2016), TCR (04-18-2016)
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
FRS / BRZ Intake Manifold - Development Thread - FT-86SpeedFactory by Velox FT-86 SpeedFactory Engine, Exhaust, Transmission 733 12-11-2018 10:13 PM
Hancha BRZ/FR-S/GT86 Aero Parts Development Thread Hancha Group Cosmetic Modification (Interior/Exterior/Lighting) 57 03-24-2014 05:40 PM
Raceseng | Development FT86 | Build Thread Raceseng Member's Car Journals 17 06-06-2013 09:22 AM
