#29 |
Poor Adult Male
Drives: 2013 Subaru BRZ
It's possible, but to get the DI's as OP has, the manifold needs to come off, so I'm assuming the gasket was checked / resealed.
#30 |
They got the engine out today and found that the valve spring had gone bad. Hopefully this is the actual fix
| The Following User Says Thank You to sybrite For This Useful Post: | RavioliG (03-01-2016) |
#31 |
Drives: Hydra EMS Powered FRS Raven Black
I wouldn't overlook the potential this is a valve rocker arm coming apart. Been there and done that unfortunately. Before a catastrophic failure the pin rocks partially out and it effects the valve lash which can result in just one cylinder misfiring.
Mine personal car did that before it catastrophically shot out the valve cover. Given all you've already done I would pull the valve cover and inspect cylinder #4 rockers! Phil |
#32 | |
Drives: Full race 4cyl boxer
He must have pulled a vacuum on each cylinder while the valves were (supposed to be) closed and detected a leak bigger than some expected value on the cylinder in question. That would point to a valve not closing properly or hard enough. (burnt valve is misshaped and bad spring means not pulling closed hard enough) A leaking vacuum test could also point to a leaking DI seal, or rings, but those would leak the same under a pressure bleed-down test. So it seems it would have been prudent to ask that original guy exactly what he meant by "leaking vacuum" |
#33 |
Duh, I didn't see the post before mine. A broken single linear valve spring is really rare unless it was a rocker and the service writer had no idea what that is and told you it was a valve spring. LOL! Rocker failures have been common around here.
#34 |
Sounds like as soon as they get it running I might need to look to trade in. I really can't afford these expensive repairs if the potential for more internals to fail. I know it's 80k miles, but the car is only 3 years old. Kind of crazy since people talk about how long Subaru's last. I put a lot of highway miles on my cars, but I haven't really driven her that hard since I had her. Sure, every once in a while, but it just seems crappy to have these problems given that I have had all of the oil changes and services completed per the schedule with the dealership. Rarely have I ever had to use anything less than 93 in the tank, so I have taken good care of her.
#35 |
Yeah unfortunately there are just some known issues with this motor you have to deal with if you're unlucky.
#36 | |
They are still waiting on the parts so it may be Monday or Tuesday when I figure out if this fixes it. |
#37 |
Drives: Late 2014 Subaru BRZ
Start small like I don't know... maybe a burnt out sparkplug? Hm.....
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#38 |
Alright, so I got her back today and she sounds great. They gave me the souvenirs in a box (broken valve spring). It was completely broken off a few spirals up (not sure if it was the top or bottom of the spring. But either way, I'm glad to have her back. Just unfortunately around $2800 later. I suppose, given them being the dealership, it could have been worse given all the work they did.
#39 | |
Now I'm on pins and needles about this damn fa20 motor.
2014 Subaru BRZ
#40 |
Yup. Everything sans the wheels and catback exhaust is fatory. It's my daily driver so I didn't really want to do anything to it. Apparently that didn't keep me from problems lol.
#41 |
Here is a picture of what the valve spring looked like. And the direct injector (which I guess wasn't technically bad).
#42 |
You sir are a lucky man. I'm so happy you didn't blow your engine and for a valve to break like that really really makes me question the quality control on these engines.
2014 Subaru BRZ
| FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped | susko | Transmission and Driveline | 2 | 01-21-2016 04:42 AM |
| GSC FA20 Valve Spring Kits | MAPerformance | Engine, Exhaust, Transmission | 41 | 07-20-2015 11:22 AM |
| Skunk2 Dual Valve Spring and Titanium Retainers | limitedblkwrx | Engine, Exhaust, Transmission | 0 | 01-05-2015 12:12 AM |
| My car got BROKEN into. | Hiros86 | Northern California | 25 | 02-25-2014 12:33 PM |
| WTB RCE spring or RS*R spring mounted on stock strut | jshum | Want-To-Buy Requests | 1 | 10-11-2013 03:47 PM |
