#29 | |
When it rains and gets wet, does the car have to be moving or will it get wet on the inside with the car just parked outside in the rain...?? humfrz |
#30 |
Drives: 15 FRS, 15 GTI, 88 928, 92 Skyline
I've checked all the carpets, under the seats, and taken apart the trunk. Can't find any water or damp spots. The smell happens whether or not the car is moving. It always happens when it sits still, and sometimes while I'm driving (the car usually sits before I drive it), but when i went on a trip to Florida I drove through a storm and the smell started. That's the only encounter I've had without the car sitting beforehand.
#31 | |
Now, you can either kill it (bleach or Lysol type products) or make it die of thirst. The logical approach is to kill it then rob it of moisture, so it won't come back. Back in the day, I picked up this old GMC truck that was "infected" with mold (yep, the green stuff you see on the shift lever and steering wheel). I must have used a half dozens cans of Lysol and a quart of bleach to get rid of it. Then I replaced the weather stripping around the doors ...... and the mold stayed away. So, step one ...... get rid of the mold (follow suggestions offered by others). Then find out how the excess moisture is getting into the vehicle and stop it. Happy mold hunting. humfrz |
#32 |
I shouldn't have to mold hunt in a brand new car. If it is this bad 8 months in, what will the quality be in 3 years? I dont feel like it's crazy to want them to fix it. If you buy a gallon of milk or loaf of bread and it has mold in it, you dont keep it in hopes that the mold will go away, you want the store to make it right...if the car were used, I'd suck it up and deal with it.
#33 | |
However, you do and you’re running low on options. After 5 dealer trips, it appears they are not going to “fix/correct” it. You can check the lemon law language and see if it might be eligible. I suspect your car/the condition, won’t qualify. Back in the day, we called it the “giggle test” …… your honor, I spilled catfish bait in my trunk, now the whole car stinks ……. I want the manufacturer to replace my car……..! If this were a widespread defect in the manufacturing of the car ...... why haven't we heard more about it ... ?? Hey, we are on your side, but I think your problem is relatively unique and it going to be up to you to fix it. humfrz |
#34 | |
#35 |
#36 |
Sleep Chomper
Did you figure it out? I also have similar problem. Bad smell when it rains
#37 |
Drives: FR-S,GTI
My car is the same. Another thing I noticed is it seems to "hold" smells for a long time. If I bring a pizza home in the car, I can still smell it the next day. Maybe it has to do with the small volume of the interior.
As far as the moldy/musky smell when it rains, I noticed it only smells when I'm wearing shoes (I hardly ever wear shoes when driving). I think what happens is the tread of my shoes transfers a lot of water to the floormat and for some reason that causes the smell. The smell is not immediate and it doesn't last a long time. But it does seem to happen anytime it rains and I'm wearing shoes. |
#38 |
Drives: car
I had mildew for awhile because I ran over something on a highway and it put a hole underneath the passenger side, so anytime it rained I'd get water ingress in there. I bought two types of flex seal and sealed it, no mold problems since.
But sometimes when I spill water or want the car to be extremely fresh, I put a damprid bag in there:
#39 | |
![]() humfrz |
#40 | |
Senior gif poster
Drives: 2013 Asphalt FRS
#41 |
Hombre
Drives: 1994 Supra Turbo
I did not see this thread until it was bumped today, since I recently joined.
After reading all the posts, I suspect the car had standing water of some sort before purchase (could have been an inadvertent spill or other) that was left long enough to grow a bit of mildew and mold. There may, or may not, be an obvious leak, since it may just be high humidity that is enough to activate the smell again (usually higher when it rains). I have had this problem in a used car, and had to really search to find the mold/mildew, and then had to use good cleaners to get rid of it. It usually is found in a spot that has at least one absorbent surface - like carpet. If there is mold, all the other measures mentioned will not get rid of it, even if they lessen the effects.
A Toyota Racecar A Toyota......................Because.
Anyway, should not palindrome be spelled palinilap? |
| Smell Gas? | Skurj | Issues | Warranty | Recalls / TSB | 14 | 05-25-2020 11:05 AM |
| Gas smell | S84kam | Issues | Warranty | Recalls / TSB | 6 | 02-14-2016 02:11 AM |
| Odd smell | FloridaBRZ | BRZ First-Gen (2012+) — General Topics | 11 | 01-18-2015 01:49 AM |
| Air conditioning Moldy smelling | njccmd2002 | Issues | Warranty | Recalls / TSB | 15 | 05-12-2013 09:34 AM |
