Old 04-27-2016, 11:00 AM   #29
ka-t_240
Hi Everyone, quick question as I am getting ready for my first event with NASA. Still trying to figure out the points thing. Have been seeing many different "views" when it comes to OEM Spoilers.
I have a BRZ Limited, which comes with the spoiler from the factory). Does this mean the spoiler is BTM, or since the BRZ Premium model does not have a spoiler, does that mean my limited automatically takes the +4 for the OEM Spoiler.
ka-t_240 is offline   Reply With Quote
Old 04-27-2016, 01:10 PM   #30
ja1217
Drives: 2004 Toyota RAV-4 5M
Some people think that BTM means "By The Manufacturer", but it really means "Base Trim Model". So, since the spoiler is not included on the Base Trim Model BRZ, you would indeed need to take the 4 pts for non-BTM aero.
ja1217 is offline   Reply With Quote
Old 04-27-2016, 01:32 PM   #31
ka-t_240
My undertanding was getting hit with 4 points for it. I understood BTM, but had been seeing lots of posts in regards to BTM being linked to the specific model vs the car: Limited vs Premium, SE vs none SE, and all sorts of comparisons.
I am at that point where I will end up running TTC because I don't want to deal with pulling body parts off my car for a couple events per year, so wanting to make sure that everything is 100% before ordering stickers.
Old 04-27-2016, 01:43 PM   #32
ja1217
Yes, you would take 4 points for the spoiler. BTM is always linked to the base trim model with no options (so premium for the BRZ, which does not come with a spoiler). I think there are a few special cases with other cars with major upgrade packages, like the Mustang Boss302, where they are classed separately from the base mustang, but for our cars there is no special classing of for the different trim levels.
Old 04-27-2016, 03:20 PM   #33
Uplink
Uplink's Avatar
Drives: anything you let me
Where did you find the base class for our cars? The classifier spreadsheet doesn't list that and the 'base class' field is only a dropdown, not referenced from anywhere else.
*EDIT* Nevermind, found it in the rules. Thought it was in their 'classifier program' like they said on the website.
Uplink is offline   Reply With Quote
Old 04-27-2016, 04:22 PM   #34
ka-t_240
Ya, they are in TTD. Its in the normal TT Rule Book. Then you can play with the fancy spreadsheet and be all like to TTC you go!
Old 04-27-2016, 04:41 PM   #35
Uplink
Uplink's Avatar
Your best bet is probably TTC, it'll give you plenty of wiggle room too. With 0 suspension mods, on 200tw Direzza's and just due to my minor street mods (OP-Back exhaust, pulleys, slightly less weight)... I fall about 3 points from TTC.
That said, the car is already competitive with TTC times so putting the extra 23 allowable points into suspension/tires would make it a formidable competitor.
Old 04-27-2016, 04:45 PM   #36
ka-t_240
Are the pulley's really worth the points? I've already got T2s, Sway Bars, Bushings, Endlinks, Full exhaust/tune, 4.56 FD, and RE71s. And then some useless OEM Wing Points as well as an intake(not sure what to say about it) and front strut bar.
Not sure if the brz can compete with an S2k w/ aero.
Old 04-27-2016, 04:45 PM   #37
Uplink
Uplink's Avatar
Came to that conclusion about 30 seconds in.
Old 04-27-2016, 05:15 PM   #38
Uplink
Uplink's Avatar
Ya, not sure if the brz can compete with an S2k w/ aero.
They aren't worth the points, that's the problem. I never built anything to TT spec (or really any spec for that matter) so backtracking to add up points shows how silly a lot of it is. I'm in the same boat as you on the intake. Perrin silicone inlet to get rid of the noise tube and the HKS snorkel. Neither make any appreciable competitive difference, but they fall into the category that includes doing a true cold air intake because non-BTM.
No, definitely not. @Aero It's all in how you build the car though. Ideally, the best way to hedge your is you have to pick only 1 race series and build/spec your car to their rules eeking out every points advantage you can. Don't do anything extra or 'wasteful'. Ie, rather than Z2's, pulleys, and the snorkel, those points would have been better spent knocking a set of R888's or RE71's down to +2.
Old 09-21-2016, 10:23 AM   #39
enivid
enivid's Avatar
Drives: WRB JR BRZED
TT4 is a go! http://nasaforums.com/viewtopic.php?f=18&t=132031
Sent from my Nexus 5X using Tapatalk
enivid is offline   Reply With Quote
The Following User Says Thank You to enivid For This Useful Post:
CSG Mike (09-21-2016)
Old 09-21-2016, 03:25 PM   #40
woooooooooh
Can you give me a quick TL;DR vs TTC/TTD? I'll read the full post later when I'm at a computer...
Old 09-21-2016, 04:05 PM   #41
ja1217
woooooooooh
If you are familiar with the rules for TT3, its pretty much the same except the power to weight ratio is 12.0lbs:1whp, with the power being your average horsepower, not peak.
BUT, here is what I'm 95% certain we are going with for 2017, and I hope that we will have the rest before the end of the month
1) ALL ST (1-4) and TT1-4 classes will use the Avg. HP calculation for Dyno tech inspections for compliance with the Adjusted Wt/HP Ratio.
2) ST4/TT4 will use the current ST Adjusted Wt/HP Ratio Formula with some modifications to the Mod Factors (like we did with ST3/TT3)
3) ST4/TT4 will have a limit of 12:1 Adjusted Wt/HP Ratio
4) ST4/TT4 will have a maximum Tire Size of 275
5) Non-DOT tires will not be permitted in ST4/TT4 (might need some exceptions for designated rain events--still being worked out)
6) DOT-approved "A" Tires will have a Modification Factor in ST4/TT4--similar to the current non-DOT Mod Factor in other ST classes.
7) No non-Production Vehicles or Modification Factor for ST4/TT4, except for pre-approved vehicles (such as Legends, Legacy's, etc.) that shall be listed in the rules. There may be some individual waivers granted by the National Director under appropriate circumstances for currently unforeseen circumstances (with appropriate Mod Factor if necessary).
8) PTB/TTB will be deleted and no longer available.
9) Aero modifications will be limited to a rear wing/spoiler, front air dam/splitter, and those modifications currently listed as okay under the OEM Aero rule in ST3.
I'm still waiting on a clarification on the aero rule as I don't want to remove my diffuser, but we'll see.
Old 09-22-2016, 01:57 AM   #42
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Time to go back to NA
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
NASA TT - how do you do it celica73 Tracking / Autocross / HPDE / Drifting 3 09-11-2014 10:14 PM
Joining the NASA cjsporl1996 Tracking / Autocross / HPDE / Drifting 33 12-26-2013 05:51 PM
NASA made me do it robispec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 04-05-2013 12:48 AM
NASA-x at MIR with video about350 Tracking / Autocross / HPDE / Drifting 2 08-11-2012 11:42 AM
