Old 08-25-2013, 08:44 PM   #29
DNAPoPo
GreddyBRZ meets GreddyFRS
DNAPoPo's Avatar
Drives: SSM Limited BRZ
Originally Posted by AG3NT_5CARFAC3 View Post
Awesome video! Thank you! I am going to remove the third break light and put some dynamat inside there and see if it will stop some rattling on the rear window
Did it work?
CO>CA|Greddy Intake + EVO 3|Enkei Raijin|KW V3|BeatSonic
SoCal 86 OC Club
Tuesday Night Irvine DJ Meet Thread
Irvine FR-S & BRZ Car Meet(FaceBook)
DNAPoPo is offline   Reply With Quote
Old 08-27-2013, 09:53 PM   #30
Lytheum
Drives: 2013 BRZ Premium 6MT
+1 I was just thinking the same thing and found this thread. Did it work?
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 08-27-2013, 10:26 PM   #31
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
I haven't tried yet; I dont think it will work because its the outter shell of the 3rd break light housing and the inner rear windshield that causes the tapping; I am going to try to use a black felt pad and cut it to the shape of the 3rd break housing to see if that will work @Lytheum @DNAPoPo
AG3NT_5CARFAC3 is offline   Reply With Quote
The Following User Says Thank You to AG3NT_5CARFAC3 For This Useful Post:
DNAPoPo (08-28-2013)
Old 08-31-2013, 03:03 AM   #32
notout86
Drives: GTS 86 auto
Folks, be aware that your highmounted stoplight may have three lugs holding the seam across the edge nearest the front of the car. These are in addition to two clips inside. If the plastic is cold and hard, you may need to separate at the seam with a screwdriver.
notout86 is offline   Reply With Quote
Old 01-19-2014, 10:45 PM   #33
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Could one access the plastic welds from inside the trunk, grind them off, unconnect the wiring and remove the whole brake light assy without removing the rear panels? The through of climbing into the rear seat of this car is quite painful...
Old 01-19-2014, 10:52 PM   #34
Skorov
Skorov's Avatar
Drives: 86 GTS White
Nope. You have to get to the under-side of the parcel shelf. Don't worry, after doing this 3-5 times, you'll start to think of the back seat as "cosy".
Skorov is offline   Reply With Quote
Old 01-20-2014, 12:33 AM   #35
tm86
Drives: 2013 Dark Grey 86B
Not going to work Even after removing the shelf, grinding through those plastic welds is a bitch.
tm86 is offline   Reply With Quote
Old 01-21-2014, 09:12 PM   #36
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
this is a great diy. kind of absurd how hard it is to move that little brake light tho amiright?
"Careful though, I've seen many of my friends turn from ironic bros to full on bros by accident." - cfusionpm
bdanisi is offline   Reply With Quote
Old 01-21-2014, 09:23 PM   #37
ramiram1984
Drives: 2016 STi DGM
What's the benefit of doing this again?
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 03-04-2014, 06:32 PM   #38
dawnst3ar
Drives: 2013 MT FR-S Asphalt
I would add that it is a lot easier to just remove the trim next to the rear seats - had a heck of a time getting things back together until I finally pulled those out. Otherwise, thanks a ton for this info!
dawnst3ar is offline   Reply With Quote
Old 04-20-2014, 06:38 PM   #39
SuperKazRacing
Drives: 2013 RED FR-S
did that work for you ? My new system is driving me nuts when it rattles
SuperKazRacing is offline   Reply With Quote
Old 07-06-2014, 11:39 PM   #40
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
What a PITA all complete will get it bqck together tomorrow
Jmonty is offline   Reply With Quote
Old 08-11-2014, 11:44 PM   #41
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Draco-REX View Post
I just tugged it out from the sides.
Originally Posted by engee View Post
That's what I did. You shouldn't need to take apart the sides if you are just trying to get the deck out.
So can someone please confirm this...can you remove the rear deck alone without removing all those other pieces?
And I just found this in another thread dealing with a rattle issue:
Originally Posted by jdubz View Post
Solution: Take the rear deck out. There are multiple ways to do this--I pulled the plastic pins out that you see when you put the rear seats down and then was able to pull up on the deck after locating the 4 plastic grommets. This is much easier than totally disassembling the rear pillars, etc. Do this at your own risk--you can easily bend or crease the deck if you get in a hurry.
Phaedrus29 is offline   Reply With Quote
Old 08-12-2014, 12:30 PM   #42
DC2R
Drives: 2014 Scion FR-S
is just removing the top half of the brake light good enough for a tint shop to get in there? i have taken my car twice already and both times they just made a cutout for the third brake light.
Im taking the car a 3rd time today and would like them to not do the cutout.
DC2R is offline   Reply With Quote
Third brake light out? Longhorn248 BRZ First-Gen (2012+) — General Topics 21 11-23-2015 03:23 PM
How to remove third brake light (to tint back window) 96z2 Cosmetic Modification (Interior/Exterior/Lighting) 10 06-07-2012 04:14 AM
The third brake light looks like a car! Longhorn248 BRZ First-Gen (2012+) — General Topics 12 06-06-2012 07:14 PM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
