Forced Induction Turbo, Supercharger, Methanol, Nitrous |
01-26-2013, 11:18 PM | #29 |
Drives: 2003 Subaru Outback
I think you are looking for Fast,Reliable,Cheap. Pick two.
01-26-2013, 11:36 PM | #30 | |
Add lightness!
Drives: 17' WRX
01-27-2013, 12:25 AM | #31 | |
Drives: '06 AM V8V Coupe
The more your engine is loaded the more efficient it runs, but a turbo only increases load when you want full power or because it's a restriction in the exhaust that needs more power to pump exhaust past. Adding a turbo to a gasoline drivetrain doesn't increase efficiency in most cases. |
01-27-2013, 01:17 AM | #32 | |
Drives: Future FRS
On the propulsion systems I have designed for ships, both gas and diesel propulsion always have dual turbos to increase efficiency by increasing the engine performance without having to increase the engine size, this is the driver for efficiency. The problem with efficiency on a car is the fuel mapping and the gearing. Like I was saying before your car has to be tuned correctly to maximize efficiency, as in running leaner. This can be done safely, but if not done correctly can lead to decreasing your longevity of your motor from heat issues. You also have to select the right turbo for your car. If the OP is questioning if a turbo affects your gas mileage, the answer is yes. You can significantly increase your gas mileage with the correct size turbo and associated ancillary systems. Mostly your decrease in your mpg comes from your foot. This curve is typical of a curve you will find for many compressor/turbine like applications. From centrifugal pumps to turbochargers. When designing a system, obviously you want to aim your system within the middle of the efficiency lines by adjusting turbo mass flow and pressure ratios. If your boosting your car like crazy 15psi your going to be wayy off the charts on the efficiency rating for your turbo and it just won't be worth it. But if you design your system appropriately your can gain a modest 2-4 mpg with a good turbo application. You won't melt your engine, you won't eat more gas, IF you tune your MAF, IF you adjust your gearing to compensate for the added torque. you can expect good mpg gains. If you drive the exact same, with a turbo and without a turbo you will gain more mpg with a turbo even though your putting in more fuel. You know why? One reason is volumetric efficiency. Adding a turbo can increasse the volumetric efficiency up to 30-60%. Second, the system is not linear, just because you think you add 2 times the volume of air and you add 2 times the fuel does not mean you get 2 times the pressure after ignition.. the pressure is not linear as it is an isentropic gas situation. and varies as a power. If you want efficiency, yes you can increase your mpg with a turbo. If you want performance only? Yes it decreases your mpg. Why? because your foot is ass ramming the gas peddle... Last edited by McDeLtA_T; 01-27-2013 at 01:35 AM. |
01-27-2013, 01:22 AM | #33 |
Drives: Future FRS
It really depends what the OP is after, performance or fuel efficiency?
01-27-2013, 02:42 AM | #35 | |
Drives: Future FRS
autospeed.com/cms/A_109931/article.html caranddriver.com/columns/turbocharged-engines-to-the-rescue-why-it-will-be-different-this-time-around fueleconomy.gov/feg/tech_engine_more.shtml If you want a production engine that comes with a turbo to save you money check out these cool cars in the link below!! autoguide.com/auto-news/2012/06/ten-turbocharged-vehicles-we-cant-wait-to-get-our-hands-on.html |
01-27-2013, 02:58 AM | #36 |
Drives: GT86
I think you guys are on drugs if you think having a turbine wheel in your exhaust with an exducer the size of a pea is going to improve fuel economy at ANY point.
01-27-2013, 03:38 AM | #37 | |
Drives: Future FRS
every single engine I have ever seen on ships diesel or gas or heavy fuel oil (HFO) have all been turbo charged. Why may you might ask? because they save money on fuel, especially when they spend millions to fuel their ships for they're long voyages. Another GREAT GREAT site to learn about engines and all that cool stuff is: (its not just about diesel, it has gas engines, turbines etc.) http://www.dieselduck.net/machine/in...l#.UQTnRGfRJHU Real Case Study: http://www.allpar.com/fix/holler/slant-six-turbo.html But look at this site: It's a really easy read on turbos and shows how they work with the benefits (and.. also talks about efficiency). http://www.popularmechanics.com/cars/how-to/4306310 I personally am not going for efficiency, I will be buying a badass turbo to maximize speeding tickets not my mpg. Last edited by McDeLtA_T; 01-27-2013 at 03:52 AM. Reason: Added a case study |
The Following 2 Users Say Thank You to McDeLtA_T For This Useful Post: | AllDayJonRay (02-28-2013), Supermassive (01-27-2013) |
01-27-2013, 03:50 AM | #38 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Thought that was fords whole thing with the Eco boost engines.. Smaller more fuel efficient turbo engines..
The Following User Says Thank You to Gixxersixxerman For This Useful Post: | dori. (02-22-2013) |
01-27-2013, 07:57 AM | #39 |
1337
Drives: 2013 BRZ WRB S/C
Affect!!!
01-27-2013, 08:44 AM | #40 | |
Add lightness!
Drives: 17' WRX
This conversation is stupid. If you install a turbo on this car, it's because you want to go faster. Going faster will cost you mpg. How much? Supermassive shared his experience. That's the only data in this thread. Everything else is pretty much speculation and garbage. |
01-27-2013, 10:04 AM | #41 |
Drives: Perrin/VORTECH Supercharger TestBRZ
What a thread...
The Following User Says Thank You to Huehuecoyotl For This Useful Post: | usptwins (02-02-2013) |
01-27-2013, 11:54 AM | #42 |
I think people are confusing fuel efficiency with power... Let me break it down for you.
Turbos are a great way to pull every ounce of power from the engine, and still put up those big mpg numbers. Reason? the turbo is not spooling in the everyday driving rev range. Simple as that. That is why manufacturers are turning to turbos to make power. It gives them a big horsepower number without sacrificing fuel as long as they tune it correctly. And the ecoboost engine does NOT get better gas mileage than the normal engine. Please see Ford Focus specs. Also, TDI is a whole different beast. You can't compare gas to diesel. Just because you can get 40mpg out of a turbo diesel 2.0L Jetta, doesn't make it more fuel efficient. First of all, we're talking a gas/petrol here. Secondly, I promise you that the old non-turbo diesel VWs got better gas milage than their turbo variants. So please stop claiming that turbos IMPROVE fuel economy, because it is NOT true. For those people that are putting turbos on their cars and getting better mileage, chances are you are just driving it better to avoid spooling the turbo in everyday driving situations, and effectively improving your gas milage by doing so... |
Similar Threads | ||||
At what milage did your OEM tires start to lose grip? | Liquidsnake | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 01-18-2013 05:38 PM |
Milage App. | execoll | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 09-14-2012 12:23 PM |
Carbon Effect Wing Mirrors | faz1 | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 08-25-2012 09:12 PM |
C&D: Japanese delays should not effect US allotments. | Draco-REX | BRZ First-Gen (2012+) -- General Topics | 11 | 04-21-2012 01:22 PM |
MR-S Effect... | Dimman | CANADA | 11 | 09-06-2011 11:49 AM |
