BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
04-14-2023, 02:51 AM | #29 |
30 minute maintenance
Drives: My18 wrxsti My19 brzts
I`d like to know how your foot can just slip off the brake pedal.
Wait until my Flex capacitor hits 88
04-14-2023, 06:22 AM | #30 | |
Weight Weenie
Drives: 15 FR-S
1.5 would be an improvement not a detriment and would not lead to spinning IMO. |
The Following User Says Thank You to new2subaru For This Useful Post: | ZDan (04-14-2023) |
04-14-2023, 07:30 AM | #31 |
Drives: '23 BRZ
04-14-2023, 07:37 AM | #32 |
Drives: '23 BRZ
-1.5 is a lot better than 0 degrees front camber for sure. But you don’t spin due to having more front grip. You spin from lack of rear grip, likely due to driver error (big lift, slow hands , etc). The idea that adding 1.5 front camber *caused* 360 is laughable. Do the same thing with 0 front camber and you’ll still spin.
04-14-2023, 08:37 AM | #33 | ||
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
I wouldn't mind doing a few minor things to improve the turn in and handling of the car but I'm not too keen from straying very far from stock, i.e. camber plates etc. Going with -1 ~ -1.5 sounds like it would be a nice improvement. Quote:
I guy I know in our autocross region runs -3 on his ATS and he chews through tires pretty quickly, even with fairly frequent rotations. |
04-14-2023, 09:34 AM | #34 | ||
Drives: '23 BRZ
The Following User Says Thank You to ZDan For This Useful Post: | Desertnate (04-14-2023) |
04-14-2023, 09:38 AM | #35 |
Drives: '23 BRZ
The Following 2 Users Say Thank You to ZDan For This Useful Post: | Desertnate (04-14-2023), gen3v8 (04-14-2023) |
04-14-2023, 09:58 AM | #36 | |
By putting the SPC 81305 camber bolt in the lower hole and moving the lower bolt to the top hole, you should be able to get around -2 to -2.6 degrees camber up front. Cheap and effective. Just be aware it reduces clearance between the tire and strut.
2022 BRZ Build 2013 FR-S Build |
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post: | Desertnate (04-14-2023), ZDan (04-14-2023) |
04-14-2023, 10:38 AM | #37 |
Drives: '23 BRZ Limited
Your toe settings will have more impact on wear than camber. I run 0 toe up front on my street car. For an autoX car I'd likely run some toe out to help turn in, and I suspect that's what he is doing as well.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | Desertnate (04-14-2023) |
04-14-2023, 02:06 PM | #38 | |
Drives: 2022 BRZ; 2014 BRZ
Yeah, and you'd be lucky to get -1.5*. Think I had -1.3* with just crash bolts. If you aren't constrained by class rules, I'd go with one of the cammed camber bolts. You'll be able to get a little more out of those. As far as tire wear, it's negligible, especially if you do any type of performance driving. On my Camaro I had before the BRZ I was running about -3* and was still wearing the outside edges the fastest. On my daily tires, I never really noticed any significant camber wear. On the BRZ I'm running -4* up front, and finally not chewing up the outside shoulder of my autocross tires. I imagine it'll shorten the life of my daily tires by some amount, but doubt it will be enough to outweigh the additional life I get out of my autox sets.
The Following User Says Thank You to foshjowler For This Useful Post: | Desertnate (04-14-2023) |
04-14-2023, 02:47 PM | #39 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Agree, but Subaru needs to make these for everyone, not just enthusiasts, even if they market to us. So they cheap out and count on us to make the changes. Besides my car came with Prius tires so it’s not like grip was on their mind.
04-19-2023, 03:38 PM | #40 | |
Drives: '22 BRZ
Last summer was my first time ever doing any performance driving in a rwd car. But even a noob like me could feel a difference. With 0 camber car would understeer more at the limit, which felt safer to me. After getting camber first few runs I was very surprised that handling changed that much, I had to change my driving style completely. All I am saying is for the street 0 camber would be safer because understeering is better than oversteering (although I'd imagine in worst case scenario the traction control would save you anyway) |
04-19-2023, 03:48 PM | #41 | |
Drives: '22 BRZ
My point is for an experienced driver 2.5 degree negative camber might be of benefit. But that story where you are describing saving yourself going into the turn because of the negative camber I am pretty sure if 99% of regular people who just drive the car on the street would try that - they would end in a guardrail. And since this car is built for the street and the average Joe in mind it kind of makes sense to have 0 camber. |
04-20-2023, 12:49 PM | #42 |
Drives: 2013 GT86 fully standard
My Goodyears Eagle f1s after 1 track day on std alignment, worn half way down to the rim edge . Camber helped it a bit, i only have 1.6deg nowdays since it does almost only road driving, but the std granny alignment is a bit crap. (Gen1 though)
2013 GT86, fully standard daily and occasional track day car
Similar Threads | ||||
SOLD: Raceseng caster + camber - adjustable front camber plates | higrip | Brakes, Suspension, Chassis | 4 | 09-17-2019 01:43 PM |
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
