Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
11-13-2011, 03:23 PM | #29 | |
11-13-2011, 03:29 PM | #30 | |
ლ(ಠ益ಠ)ლ
Drives: E36 5.7 V8
Here's a diagram for anyone that was confused of the applied principle in the Lotus 79 edit: As I was reading up on wiki about ground effects, I came across this: "as of 2007, Formula One cars still generate a proportion of their overall downforce by this effect: vortices generated at the front of the car are used to seal the gap between the sidepods and the track and a small diffuser is permitted behind the rear wheel centerline to slow down the high speed underbody airflow to free flow conditions." The vortices they speak of, how do they work and how are they used?
I wish I was cool enough to have an FR-S
11-13-2011, 03:39 PM | #31 |
Rocket Surgeon
Drives: PSM GGA OMG
Yes and no. Many exotics have functional undertrays, but they mostly create downforce in the diffuser section as I described earlier. The ride heights of street cars prevents the creation of low pressure regions under the car, high pressure air would simply rush right in.
11-13-2011, 03:48 PM | #32 | |
ლ(ಠ益ಠ)ლ
Drives: E36 5.7 V8
11-13-2011, 04:18 PM | #33 |
11-13-2011, 04:36 PM | #34 | |
Rocket Surgeon
Drives: PSM GGA OMG
They are caused when air tries to flow from the high pressure side of a wing to the low pressure side. The problem with those is that they create a lot of induced drag, which is shy you'll see little winglets on the ends of airplane wings, or great big end plates on the ends of racecar wings. If you can stop the flow of air around the ends of a wing you can reduce drag and increase lift/downforce. Anyway, you can do the same sort of thing on a smaller scale using a sharp edge. The reason you'd want to (because you're creating drag by doing so) is that vortices will stay attached to a surface in situations were laminar air flows won't. Fighter jets use chines ahead of their wings to create vortices over their wings at high angles of attack in order to turn tighter without causing flow separation (stalling). The Evo IX did sort of the same thing with the vortex generators along the top of its rear window. The little vortices helped prevent the airflow separating from the rear window and did the same job as the decklid spoiler I mentioned earlier. If you generate a vortex just behind the front wheel it will attach itself to the outside edge of the underbody. If it's powerful enough it will stay intact all the way up to the rear tire. The thing is, you can't have one flow of air intersect another flow of air, air molecules are solid things and bump into each other. So if you've got this swirling mass of air along the bottom edge of your car you can't very well have air flowing from the side of your car to the underside of your car. If you have a low pressure region underneath your car, that high pressure air next to your car will want to be underneath instead. It can't flow through the vortex, but it will interfere with it and start to break it up / detach it, so a wimpy little vortex won't do much good. This doesn't create a perfect seal with the road surface (air can flow under it, so you need to be low), and it's not as effective as sliding skirts, but it's a whole lot better than nothing. |
11-13-2011, 04:55 PM | #35 |
Rocket Surgeon
Drives: PSM GGA OMG
The surface of the diffuser can only pull up on a flow of air to a certain extent. If you try to pull up too hard or quickly the air flow detaches and the diffuser stalls (lots of drag, no downforce). If you had a perfect awesome airtight seal with the ground, you'd only want ~7 degrees of rise in the diffuser. Air leaking in from the side will allow/require you to have more of an angle. The extra pressure will reduce downforce, but will help your airflow stay attached to the diffuser at a greater angle (more downforce). And since more and more air will have leaked into the diffuser along its length, you can/should increase the angle of the diffuser along its length (have it curve up). How long/tall/wide it should be really depends on how much air is coming through the venturi section. The diffuser's main purpose is to reduce the drag induced in the nozzle by slowing down the air after it passes through the venturi. If you don't slow it down enough, you lose efficiency (more drag), if you slow it down too much you lose efficiency (more drag). There is a Goldilocks zone where the the diffuser is sized just right, and the drag caused by the undertray is at a minimum.
11-13-2011, 04:55 PM | #36 | |
Hook 'em
I was thinking along the same lines as recumbent bicycles that break speed records. The shells around the rider have very low cd, it would be cool to see a manufacturer come out with something similar, even if it was just a research/marketing vehicle. |
11-13-2011, 05:28 PM | #37 | |
Rocket Surgeon
Drives: PSM GGA OMG
They even go so far as to have rapid prototyping departments that can pop out a redesigned trim piece in an hour or two. Then they test it on the full scale, pre-production prototype in their on-site wind tunnels. Then they redesign it and have another prototype made, etc. |
11-13-2011, 07:04 PM | #38 |
Drives: In the market for something fun
Man did this thread get academic.
11-13-2011, 09:58 PM | #39 | |
Hook 'em
It would be awesome to have rapid prototyping capabilities at home for designing aftermarket parts. There's more and more relatively cheap machines that can print out small .STL parts coming to market. One day I'll have to add one to my stable of nerdy tools/toys. |
11-13-2011, 11:11 PM | #40 |
Reverse Burnouts
Drives: 2013 Argento FRS
Im pretty sure they have done some aerodynamic testing for this car, lexus does it for most of thier cars, toyota does it for their economic lineup. Knowing the CoD means its been in the wind tunnel a few times at least. Im wondering how well the aerodynamics were tuned to relieve lift and how smooth the underbody is and if there is a strong suction under the creating more downforce and less drag
11-13-2011, 11:31 PM | #41 | |
Drives: '06 AM V8V Coupe
11-14-2011, 01:30 AM | #42 | ||
Drives: N/A
And BTW, the CoDs reported aren't 100% comparable to street versions. They do not always measure with mirrors, antenae, spoilers, etc. The fact that they are even advertising the CoD is a gift. They could write a small book just on the aerodynamics and related measurements of this car. old greg, thanks for sharing! |
Similar Threads | ||||
New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 584 | 08-28-2023 08:53 PM |
Porsche to include 7 speed manual option in new 911 | cyde01 | Other Vehicles & General Automotive Discussions | 54 | 03-31-2012 07:26 PM |
Casey Stoner high speed cornering at 1000fps | tranzformer | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 08-01-2011 04:20 PM |
Need For Speed Shift 2 | Dragonitti | Other Vehicles & General Automotive Discussions | 12 | 04-09-2011 10:49 PM |
86 Drag car?!?! | MtnDrvr86 | Other Vehicles & General Automotive Discussions | 5 | 01-14-2010 06:35 PM |
