Old 05-02-2022, 01:40 PM   #4173
Compelica
Compelica's Avatar
Drives: 86 GT
Originally Posted by Racecomp Engineering View Post
Depending on which camber plates, there's usually a middle 0 position that is similar to stock angle. I wouldn't expect clearance issues with 225s and -2.25 degrees camber on stock wheels but I would look closely.
- Andrew
Thanks Andrew. My camber plates are these in the link below. I see there's a marker there, is that which you're referring to? Will check on the actual car later on.
https://i2.wp.com/www.corner3motorsp...00%2C375&ssl=1
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 05-02-2022, 02:02 PM   #4174
Unsure. If you have a set of OEM mounts nearby you should be able to compare.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Compelica (05-03-2022)
Old 05-22-2022, 11:25 AM   #4175
Danny318
Drives: 2019 BRZ
Looking for recommended changes to reduce understeer on track.
Car info 2019 pp
Hancook rs4 245 40 17 on 9in
RCE tarmac 2 with 7kg f/r springs
*edit* Ride height:
F: 13 1/2 in
R. 13 9/16 in
Recommended clicks for track
-3.4 f
-2.6 r
3mm toe in rear
0 toe front
Subframe and diff bushing stiffeners
The initial turn in is great, lots of bite but mid corner and track out it wants to plow and understeer and the front tires howl a lot. It’s manageable and still very fast, but I’d like a bit more neutral handling.
I’m wondering if lowering the front will help
Or stiffer rear springs
Or do I need a rear bar
Looking forward to advice
Danny318 is offline   Reply With Quote
Old 05-22-2022, 11:56 AM   #4176
bhmax
Drives: 13 BRZ, 17 Focus RS
I have the SS1 and had to go stiffer springs in the rear to get the balance like I want it.
bhmax is offline   Reply With Quote
The Following User Says Thank You to bhmax For This Useful Post:
Danny318 (05-22-2022)
Old 05-22-2022, 01:04 PM   #4177
marco_mc22
Drives: Toyota 86
Before purchasing other mods I’d try playing with shocks, roll center and alignment; mid corner push could be reduced stiffening front rebound and rear compression damping a little, lowering front roll center or raising rear and using less toe in rear to get more rotation. You can also open a bit the front toe, like 2mm open front and 0 to 2 closed rear.
Then if you’re still pushing you may try a stiffer rear bar.
marco_mc22 is offline   Reply With Quote
The Following User Says Thank You to marco_mc22 For This Useful Post:
Old 05-22-2022, 01:31 PM   #4178
Danny318
Drives: 2019 BRZ
What spring rates were you on and what did you end up with? On track or street?
Old 05-22-2022, 01:38 PM   #4179
bhmax
Tried the stock 6k and went to 7k in the rear. Like mentioned, there would be other ways to go about it but I had been running Swift SpecR and liked the higher rate in the rear. Mostly track, with a little bit of street and AX. I understeered pretty badly on track and the 7k rear took care of that for me.
Old 05-22-2022, 03:49 PM   #4180
Car info 2019 pp
Close to stock ride height (about 1/4in higher in rear than front)
-3.4 f
-2.6 r
3mm toe in rear
0 toe front
What are your actual ride heights? Center of wheel hub to fender.
- Andrew
Old 05-22-2022, 04:07 PM   #4181
Danny318
Drives: 2019 BRZ
- Andrew
F: 13 1/2
R. 13 9/16
Old 05-23-2022, 09:07 AM   #4182
F: 13 1/2
R. 13 9/16
You could go a 1/4 inch lower front and rear, but you don't have to.
Try increasing rear compression 3 clicks. Could also (or instead) reduce front rebound but that will have an affect on turn in. Start there because it's free, but adding some 8k rear springs is certainly another possible solution that works.
Would also try to get some tire temps and see if you need a smidge more front camber.
That's 3mm total rear toe in right?
- Andrew
Danny318 (05-23-2022)
Old 05-23-2022, 01:12 PM   #4183
Danny318
Drives: 2019 BRZ
- Andrew
Yeah, 3mm total toe.
I did try 4 clicks more of rear compression while on track and it really only made it more bumpy when driving to the gas station.
Tire temps with a pyrometer were pretty even so camber is good.
I will try lowering it. I know some run a lot lower in the front than rear (csg Mike right?). Does a lower front lead to less understeer?
I’m thinking I’ll need the 8k springs
The Following User Says Thank You to Danny318 For This Useful Post:
Racecomp Engineering (05-23-2022)
Old 05-23-2022, 01:26 PM   #4184
Yes lower in the front will help...forward rake.
- Andrew
Old 05-23-2022, 01:29 PM   #4185
marco_mc22
Drives: Toyota 86
A lower front is better as long as you have enough bump stroke to keep everything off from the bumpstops, otherwise it will be worse. Also, dropping til -35 or more requires to adjust roll center in my opinion. It gets higher when you’re lower, makes everything even stiffer.
Rear toe makes a great difference though, I’d give it a try.
Old 05-25-2022, 09:48 PM   #4186
Danny318
Drives: 2019 BRZ
I ordered 8k springs for the rear and hope to get them in for the next event in a month. I’ll lower the front a bit too. May even corner balance. Will update late June. Hopefully this gets it dialed. Thanks for all the suggestions.
Racecomp Engineering (05-26-2022)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
