, dpfarr
Old 06-30-2021, 12:38 PM   #4159
FrickingReallySlow
Drives: 2015 FR-S
Has anyone with Edelbrock SC installed also changed to the STI Engine mounts? thoughts on if its needed or what differences they've felt? I just have a regular D-Tune probably not above 250 WHP
FrickingReallySlow is offline   Reply With Quote
Old 06-30-2021, 04:54 PM   #4160
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Originally Posted by Glitch View Post
The bracket is by Verus and I picked it up from FTSpeed.com.
https://www.ftspeed.com/part/23a-par...r#.YNxlh-hKhhE
Indeed there is, I always keep a paper towel in the engine bay for checking fluids and the sort. Perhaps I should replace it with a yellow napkin for an extra 5hp.
I figured it was a like-minded driveway mechanic technique to avoid the wind from stealing your towelette.
Muskoka800 is offline   Reply With Quote
Old 06-30-2021, 07:34 PM   #4161
Z06ZN6
Drives: 2017 Toyota 86
Keep the paper, it's lighter. A cloth napkin would be heavier and may upset the balance of the car, especially being up so high in the bay and on the driver's side.
Z06ZN6 is offline   Reply With Quote
Old 07-01-2021, 12:51 AM   #4162
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
How is routing the hoses with the blower on top? Did you follow the normal coolant bleed process to get the excess air out?
EDIT:
Rookie question: can you drive with the Edelbrock and never use boost (similar to a turbo)? I rarely lay into 50%+ throttle
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 07-01-2021, 03:51 PM   #4163
B T
Just run the car with the reservoir open and add coolant/distilled water until its up the fill line. it'll naturally push the air out and into the reservoir over time. You'll technically be in boost anytime you're not pulling vacuum to open the supercharger bypass valve.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
BrahmaBull1990 (07-06-2021)
Old 07-06-2021, 02:09 PM   #4164
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I have a Radium PCV catch-can on the way. Does anyone know where to find a good install video for putting one of these on with an Edelbrock kit? Is it more difficult with the blower on top?
Old 07-06-2021, 06:19 PM   #4165
FrickingReallySlow
Drives: 2015 FR-S
Think there's some posts on this thread with pics about it. Also edelbrock can walk you through the process too if you email them. Only the passenger side needs a catch can so you don't need the dual setup.
you might want to leave on the existing hose on the throttle body/intake side since that side is hard to detach/reattach and just add an adapter/fitting to connect to radium hose
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
Old 07-08-2021, 11:06 AM   #4166
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
It looks like I am going to need to remove the Edelbrock airbox to get to the hoses for my Forester oil cooler. Alternatively, I can splice into the existing hose and just lengthen the hose to reach the oil cooler. I can get to the throttle body outlet without taking the air filter off, it's just the inlet on the block I need to get to.
Any tips for easily taking the intake off without removing too much? Can I just remove the screws on the air filter housing to get it out of the way?
Thank you. I am still learning how to do this stuff myself
Old 07-09-2021, 12:55 PM   #4167
B T
I always start with the clamps closest to the throttle body and the intake box then pull everything in between. Not going to be able to get the back of that housing off without removing the MAF assembly.
BrahmaBull1990 (07-09-2021)
Old 07-09-2021, 12:58 PM   #4168
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Thank you. So would you suggest just removing the closet clamps to the airbox and throttle body, then remove the MAF as a tube unit? I just need clearance to get to the throttle body coolant inlet under the blower.
Old 07-09-2021, 03:13 PM   #4169
B T
If you can remove it that way, I think it's easier to just take it all into pieces since installing as a single unit is pretty difficult.
BrahmaBull1990 (07-10-2021)
Old 07-10-2021, 07:31 PM   #4170
Hurricane Nate
Drives: 2020 BRZ (Black)
I have removed the air box a few times, typically i remove the clamp closest to the air box. The tube has enough flex that it’s not terrible to put the air box back on that way.
Hurricane Nate is offline   Reply With Quote
The Following User Says Thank You to Hurricane Nate For This Useful Post:
Old 07-10-2021, 07:55 PM   #4171
Hurricane Nate
Originally Posted by Decep View Post
Anyone have a link to the air filter for this setup? Been almost 25k miles probably time to change. I remember reading it’s a dry filter.
After doing some looking around, I’m 99.9% sure this is the air filter you are looking for.
https://www.knfilters.com/33-2591-re...ent-air-filter
Old 07-10-2021, 10:17 PM   #4172
Decep
Drives: 2013 FR-S Series 10
I dont know enough about K&N filters because i've never used them before i installed the Edelbrock, but i'd think the non oiled filter would be a different media.
I could just email Edelbrock and see what they say.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
