View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 05-28-2014, 02:56 PM   #4131
FR-S Matt
Originally Posted by because racecar View Post
One ounce did not do the trick...
The bottle calls for 2-3 ounces per 10 gallons of gas. I put about 2.5 in on a fresh fillup. Waiting to see the results a bit further as I drive.
Old 05-28-2014, 03:02 PM   #4132
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
Originally Posted by JoeC View Post
I just filled up with my second consecutive tank of Ethanol free 91. Zero crickets regardless of the fuel level. Problem solved for me and the car runs a little better on straight gas. I'm not looking forward to the eventual scenario where I have to get gas with corn additive.
this.
I just wish it was more readily available. My car is running so much better on it, and its so quiet.
glorydays is offline   Reply With Quote
Old 05-28-2014, 11:14 PM   #4133
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by mweidner311 View Post
Forgive me if this was already covered in the earlier pages of this thread but out of curiosity has anyone tried running Marvels Mystery Oil in the gas?
Yep. I ran three tanks of Chevron 93 10% ethanol with 4 oz of MMO in each tank (each fill was about 10 to 11 gallons). The crickets did not go away, but the injector clacking dropped off to almost silence. So instead of hearing crickets and tractor clacking, I just heard crickets.
I have therefore concluded that MMO does not fix the problem. You may have a different result, but I doubt it. I'm trying the TC-W3 next.
Old 05-29-2014, 08:30 AM   #4134
HunterGreene
Hail Magnet
HunterGreene's Avatar
Added 1.5 oz of ashless 2-cycle last night after I filled up, not sure if it mixed entirely because the crickets were still there, if muted, this morning.
It has priests in it?
Old 05-29-2014, 08:36 AM   #4135
FR-S Matt
Takes a little bit to cycle in. I think I'm going to give the Lucas Upper Cylinder oil a tank or two before I come to a conclusion. My chirps have subsided for the time being, but I'm not holding my breath.
I also threw out that insulation Toyota did to my pump. It had a part number on it and everything, so it looked like Toyota was planning on using that as the solution if it worked. It did not, and if anything, it probably made my fuel pump hotter.
Old 05-29-2014, 09:38 PM   #4136
sirsol66
Drives: 2013 FRS- Hot Lava
Can you post the PN please?
sirsol66 is offline   Reply With Quote
Old 05-29-2014, 09:43 PM   #4137
RobertB
Drives: 2013 Subaru BR-Z
I believe the correct ratio would be around 2 ounces per tank in our cars.
RobertB is offline   Reply With Quote
Old 05-30-2014, 05:43 AM   #4138
BC-Boy
BC-Boy's Avatar
Drives: 2013 Brz sport-tech
mine are all gone, now i add ethanol to strait gas to boost it cause our gas is garbage, one thing i noticed , and i think this should be noted, i went to mix my 2stroke ashless into the the ethanol before mixing it in my tank, the jug being transparant i saw the oil just sink to the bottom in strands, usually it will cloud up the gas when mixed in gas, i let it sit for a minuite and all the oil collected at the bottom of the ethanol, then i shook it up, let it sit and it went from blue to clear and the oil at the bottom again, seems like the ethanol doesnt mix with the 2 stoke oil, so e85 may not be possible to mix a lube into it i would recommend testing prior, or youll have a accumulation of unmixed additive in your tank lurking at the bottom just waiting to clog your strainer
BC-Boy is offline   Reply With Quote
Old 05-30-2014, 05:55 AM   #4139
JFox
Drives: 2014 Scion FR-S
I'm at 2800 miles on my 2K14 FR-S. Still on factory fill oil.
I tried roughly 2oz (probably slightly less) of Walmart SuperTech TCW3 for the first time before filling up with QuikTrip 93. I never even noticed the crickets until I saw this thread. Sure enough...chirp chirp chirp.
After adding the SuperTech TCW3 I immediately noticed the engine seemed to run a LOT better. It might just be the placebo effect but within 2-3 miles it seemed like the engine was pulling a bit better, as well sounding much more healthy at high RPM. The crickets are still there but not nearly as bad. I also noticed improved idle smoothness. The car doesn't seem to shake like it used to when I would turn on the A/C or the headlights.
I'm only about 80 miles into this first run. One thing I did notice is the occasional rotten egg smell. I know TCW3 is supposedly safe for catalytic converters, but I sure hope it's not hurting mine.
JFox is offline   Reply With Quote
Old 05-30-2014, 06:52 AM   #4140
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Had mine changed yesterday. Once I got home, 7 miles away, I swear I could hear it chirping already.
Bobblehead is offline   Reply With Quote
Old 05-30-2014, 09:50 AM   #4141
Wepeel
Drives: '13 BRZ Ltd
So has anyone had the pump replaced and it resolved the crickets? I'm thinking the crickets return for every pump that's been replaced. Brought my car in for an inspection and they ordered a pump due to the noise (even without me asking). I don't think replacing it will do anything.
Wepeel is offline   Reply With Quote
Old 05-30-2014, 10:08 AM   #4142
Mooseknuckle44
Mooseknuckle44's Avatar
Mines been replaced. Chirps came back within 3,500 miles. Everyone I know that's had there's changed had their chirps come back as well.
non ethanol gas is the easiest fix if you can find it. I have a station
near me that sells but unfortunately it's $4.45/gallon and it's only 90 octane.
The other fix seems to be the TCW3 Ashless 2 cycle. I bought a 2oz(60 ml) medical syringe to carry mine to the gas station so I can add it to my next fillup. I'm running a full tank of non ethanol thru first.
Then gonna try the 2 cycle oil mixup.
Will update as soon as I see any results. LOVING the no chirping right now tho with the non ethanol.
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
Mooseknuckle44 is offline   Reply With Quote
Old 05-30-2014, 10:48 AM   #4143
Wepeel
Drives: '13 BRZ Ltd
That's what I figured. I'm thinking I will tell the dealer to not bother with the replacement. Would rather not have them messing around with fuel lines/pump (high pressure ones at that) if it's not going to resolve the issue anyway.
For me the crickets go away in the winter (consistently less than 45 degF or so) and if I run non-ethanol gas. But same with you, the non-ethanol stations are few and far between and it's expensive. Although it killed the crickets within the first 50-100 miles on that tank.
Old 05-31-2014, 12:18 PM   #4144
Vis101
Vis101's Avatar
Drives: 2013 Limited BRZ
I've been using Quick Trip gas for the past couple tanks and had a lower cricket issue. Filled up with Shell two days ago and the crickets are viscous.
Sent from my HTCONE using Tapatalk
Vis101 is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
