View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 05-24-2014, 10:33 AM   #4103
FR-S Matt
I'm going today to get some Lucas 10003 Upper Cylinder Lubrication & Injector Cleaner 32 oz. Safest solution and its sad we have to take matters into our own hands. Should bill Toyota for this.
Old 05-24-2014, 12:05 PM   #4104
arjon9397
Drives: Scion FRS 2014
Just curious for what the owners/drivers of FRS/BRZ's that are MECHANICS/AUTO ENGINEERS would think/comment on the "self-solution/measures" the rest of us are taking... They should have better knowledge in determining a more "scientific" method/explanation of the issue and narrowing down the solution (just like in medicine).
To those group of owners/drivers who are Mechanics/Auto Engineers - what do you guys think/recommend?
arjon9397 is offline   Reply With Quote
Old 05-24-2014, 12:50 PM   #4105
twag4
Drives: frs
The Lucas upper cylinder lubricant did nothing but anger my crickets. The Lucas semi-synthetic two cycle oil stopped them within one block of the fuel station.
twag4 is offline   Reply With Quote
Old 05-24-2014, 01:01 PM   #4106
sybrite
Drives: 2013 Subaru BRZ
Agreed. Mine went away in a very short distance after putting some Lucas Oil 2-cycle in. I would wonder what the long term effects may be if any.
sybrite is offline   Reply With Quote
Old 05-24-2014, 01:21 PM   #4107
BC-Boy
BC-Boy's Avatar
Drives: 2013 Brz sport-tech
ive been running shell non synthetic ashless low smoke, no build up what so ever, i mix it with redline injector cleaner, it has no smell either .take out your 02 sensor and check it mine are super clean with no build up.
BC-Boy is offline   Reply With Quote
Old 05-24-2014, 01:39 PM   #4108
arjon9397
A bit of skepticism...
Hey there Sybrite and BcBoy..
It was good the Lucas 2-cyln Oil stopped the cricket noise. But don't you guys think that can potentially damage the engine at some point in-time? (as that oil was designed for other types of engine, and not this type).
Also, for how long will the cricket noise disappear with adding the Lucas Oil? I'm leaning on the premise that it's only a temporary fix (just like replacing the fuel pump). (Somewhat similar to giving pain meds without getting to the root cause of the pain...)
Thanks for your comments.. Keep 'em flowing!
- Albert
Old 05-24-2014, 02:09 PM   #4109
sybrite
I'm certainly no expert on the matter. I did read several forums and pasted a link to another forum a page or two back. There, a guy that seems a lot more educated did some extensive testing (http://www.ls1.com/forums/f48/been-testing-oil-91206/). They found cleaner pistons, 2-5% increase in MPG, and some other stuff if you browse through the forums. Looks like they tested for over 100k miles, or something like that.
I hear that people are adding a couple ounces of the oil to each fill up, so it might be worth trying it on a tank, then run without the oil to see how long before the crickets come back. If they don't come back for a while, then maybe it's best to add it only when the crickets are there. Like many others, I had my fuel pump replaced under warranty, but they came back soon after. Like I said, I'm not a gearhead by any means. I just really hate the crickets. They sound so embarrassing.
- Albert
Old 05-24-2014, 08:11 PM   #4110
sirsol66
Drives: 2013 FRS- Hot Lava
Well, I tried the Lucas ucl today. First I added one oz to the quarter tank I had, and the crickets were still there but maybe a bit quieter. I then filled up to fill tank and the crickets were back with a vengeance. I then got home and added another ounce, so now I'm at the recommended 2 ounce per full tank. We'll see tomorrow how it does.
sirsol66 is offline   Reply With Quote
Old 05-24-2014, 10:20 PM   #4111
Mooseknuckle44
Mooseknuckle44's Avatar
I'm gonna try 1oz of the Supertech 2 strocke TCW3, recommended from someone earlier in this thread, added to a full fillup. If that does little to nothing then I'm gonna try 1.5 oz on the next.
I feel the less we add the better and if 1- 1.5 oz does the job then I'll be satisfied with doing this per tank. I always drive to nearly emtpy anyways so I should get a pretty good mixup if I inject oil first down the gas inlet followed by the full 11-12 gallons of fuel. If non-ethanol wasn't $4.50+/gallon I'd just run that. This is more money efficient. Hopefully.
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
Mooseknuckle44 is offline   Reply With Quote
Old 05-24-2014, 10:38 PM   #4112
BC-Boy
BC-Boy's Avatar
i know that my the mix im using 100% cured the chirp, it is not noticiable anymore, just has a regular engine noise .
Old 05-25-2014, 08:26 PM   #4113
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Waiting for results
N1rve
Old 05-26-2014, 12:56 AM   #4114
sirsol66
Originally Posted by N1rve View Post
Waiting for results
Day 2, and honestly I'm not impressed. At times it does seem the crickets a tad quieter than usual, but they're certainly still there. I'm going to ride out this tank and them try the other oils as suggested.
Old 05-26-2014, 09:07 AM   #4115
andrew20195
The noise (as determined by Fuji engineers) is caused by cavitation (bubbles) in the high pressure pump with certain fuel blends in certain conditions. It makes sense to me that adding a lubricant to the fuel can affect the noise, as the oil changes the surface tension of the fuel making it less likely to foam up.
The only potential downside is the additives may reduce the octane rating of the fuel, but 2 oz. per tank is negligible.
andrew20195 is offline   Reply With Quote
Old 05-26-2014, 12:34 PM   #4116
protpibe
protpibe's Avatar
I added 2 oz of Shell synthetic 2stroke oil to a full tank of 94 octane fuel (10% ethanol) yesterday and the crickets are gone.
I'm actually very pleased with the results thus far. I'll post up again if they come back.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
