Old 03-01-2017, 12:26 AM   #393
Ultramaroon
not playing cards
Ultramaroon's Avatar
Now even more gentle.
Old 03-01-2017, 12:29 AM   #394
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Here's the only one I got. Was going to do a sound video when I got home, but I snapped my rear axle on the way home so it may be a bit 😂. That E-85 and boost got me.
Silverfox is offline   Reply With Quote
Old 03-01-2017, 12:51 AM   #395
Ultramaroon
not playing cards
Originally Posted by Jmonty View Post
Let's see some install pictures, the waiting is killing me
Yeah yeah...
Click on the image for full size.
Old 03-01-2017, 01:40 AM   #396
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Sorry, I did a quick search but gave up.
What's the diameter of the tube?
Old 03-01-2017, 02:58 AM   #397
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
So great to finally see these out there being used.
The design for sound and flow is mainly "can" specific...lets leave it at that for now
The soft merges do play a role in sound but all our merges are built the same. Headers and Cat-back are both hand ground and hand welded
The OD of the resonated Mid-pipe and "S" pipe are both 60mm.
AceHeader-MT is offline   Reply With Quote
Old 03-04-2017, 06:58 PM   #398
Reamer
Drives: 2015 FRS
A+++ for this exhaust. I am running ACE 350, ACE catless FP, and now their catback. For the first time in awhile I hear my engine over the exhaust. I can't believe how raspy running catless on the stock exhaust was and now running that same setup is absolutely 0 rasp. It seriously sounds like stock almost, you just hear the headers.
Sent from my Pixel using Tapatalk
Reamer is offline   Reply With Quote
Old 03-04-2017, 08:07 PM   #399
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'd love to hear this in person from ya!
MS, CSCS, TSAC-F, CPT
Old 03-04-2017, 08:21 PM   #400
Reamer
Drives: 2015 FRS
PM'd.
I'll get some video within the next few days, if not tomorrow too.
Old 03-04-2017, 08:35 PM   #401
Teseo
Drives: frs
You will add exhaust hole cover?
Old 03-04-2017, 09:04 PM   #402
Silverfox
Silverfox's Avatar
high power-low db prototype muffler
I have put about 100 miles on the exhaust so far.
Previously I was running ACE CS400 header, HKS resonated FP, and a Tomei 60s. That combination was blistering to the ear drum, but when I wanted it to be loud it checked that box a couple times and definitely turned heads.
While waiting for that ACE I installed the stock exhaust in place of the tomei. Finally I could enjoy my daily drive without blasting music to cover the exhaust. On the low end it sounded fine, but shortly after 4K rpm it would get extremely raspy and sounded very much like an autozone Honda exhaust.
Finally I was able to install the ACE exhaust. I was in the shop to install E-85, oil cooler, and catch cans so I had them install the exhaust as well. So I can't speak to install difficulty.
The exhaust has a slightly deeper tone than the stock exhaust on cold start and idle and is perfect for me living in an apartment complex. Sounds great but doesn't wake the neighbors. Once out of the gates this exhaust sounds fantastic. It is a deep just above stock sound up to 3.5k and then she has a nice growl up through the rest of the powerband. There is a little rasp up near 6k but it sounds just as it should.
The craftsmanship on the exhaust is top notch, and as of now I can't say anything other than praise. I'll be sure to post more once I've put more miles on her and a couple extended canyon runs.
Old 03-04-2017, 09:14 PM   #403
phrosty
Exit looks very similar to the "space ship" faux carbon fiber design you see all over the car. Very nice.
Looking forward to some sound videos.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 03-04-2017, 10:37 PM   #404
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
The "spaceship" you're referring to is actually a play on an old Toyota "T" logo.
EDIT: Forgot my picture proof.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 03-05-2017, 02:10 AM   #405
johan
Drives: '14 981CS, '99 NB1
Yeah yeah...
Interesting. First I've seen of your new "pipe". Considered rattle bombing the shroud black so "just the tip" is shiny? Seems like it would blend so much better that way.
You also need some deletes for those gaping holes on either side of the bumper
johan is offline   Reply With Quote
Old 03-05-2017, 02:18 AM   #406
Reamer
Drives: 2015 FRS
I'm considering getting the tip and shroud both powder coated black (or something else that handles high temps better) because I think it'll look clean. My car doesn't have the "murdered" out theme anywhere else on it, but I think it would blend well.
FNA rear fog light Kit 1 w/high power LED HATED1 Exterior Parts (Aero, Lighting, Etc.) 5 02-09-2015 04:31 AM
HKS High Power Spec-L Ti-Tip Tien Engine, Exhaust, Transmission 0 10-23-2013 11:54 PM
Mach V muffler delete prototype Mach V Dan Engine, Exhaust, Transmission 118 02-01-2013 07:41 AM
5W High Power CREE LED Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 0 09-21-2012 06:30 PM
