Old 12-21-2015, 08:49 AM   #393
churchx
churchx's Avatar
Drives: 2014 GT86
Tim: problem being .. i doubt statement of problem being in stock intake, as yet to seen any aftermarket intake to be THAT much better then stock + aftermarket drop in filter, to consider stock being problem/bottleneck. Yes, some bring +5whp on top of stock+AM filter (in most cases those that "bring more gains" are just via manipulating MAF sensor readings resulting running much leaner on stock tune, and once MAF calibration is done, so are most of those "gains"). Those just 5whp .. do not make stock looking in my eyes as THAT of a limiting factor due some supposed "major flaws".
Old 12-21-2015, 08:53 AM   #394
Tim Radley
Drives: GT86, SQ5, RS3
Well I have datalogging that shows the problem. I made a test piece that removed the stock airbox and found a good improvement.
The other problem is some of the people doing aftermarket intake manifolds are just copying stock. If you polish a turd ... well its still a turd.
Tim Radley is offline   Reply With Quote
The Following 2 Users Say Thank You to Tim Radley For This Useful Post:
FRS Justin (12-21-2015), Nigelr32 (12-21-2015)
Old 12-21-2015, 01:05 PM   #395
celek
Resident Gear Head
celek's Avatar
I think Tim and myself are looking after the throttle body not before though
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
FRS Justin (12-22-2015)
Old 12-21-2015, 02:31 PM   #396
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Originally Posted by FRS Justin View Post
Here is another article that should make everyone happy on the light weight subject please read. so we can get back on topic.
http://www.uucmotorwerks.com/flywhee...heel_works.htm
Thank you for posting that. The presentation is a bit pedestrian but it is good material.
It's physics guys. Basic. F*cking. Physics. And basic, basic math.
It isn't magic.
And @celek was right about the WHP gain on any inertia-based chassis dyno, of which there are many.
celek: only losses in friction of gears/bearings and tire-road affect whp readings.
In a brake dyno? Or any other dyno that can evaluate steady-state operation? Yes. On an inertial dyno? No. 1/4 ET? Oh, it'll make a difference.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
Old 12-22-2015, 04:20 PM   #397
Lonewolf
Lonewolf's Avatar
Drives: Moped
Celek- Have you seen this yet?
http://www.enginelabs.com/…/pri-2015-king-engine-bearing-s…/
Old 12-22-2015, 04:56 PM   #398
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
King makes some fantastic bearings. At this point they're all I'll use in my GTI since I seem to just chew up everything else...
Old 12-23-2015, 12:09 AM   #399
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Tim Radley View Post
Problem is there are two major design flaws in the intake system that really hold it back in N/A form. I've seen it in the datalogging from both road and dyno. Might print a new intake manifold over Christmas to test out as I want to leave the car in N/A form whilst i set the Holinger up.
What kind of material do you plan on using? Will it withstand the heat? I'd love to see the end result of a printed manifold.
Intent > Content
Old 12-23-2015, 05:06 AM   #400
wizzo
Drives: 2014 Toyota 86
Will you be able to tell us which of the piper cams will work with OEM pistons, and if they do not, how much additional clearance are we after?
Also, i wonder if we will need to use some sort of phaser limiter like the mustang 5.0 guys etc.
wizzo is offline   Reply With Quote
Old 12-23-2015, 05:38 AM   #401
swarb
Why don't you ask the people who make the cams? The would be the best way to get an accurate answer.
Old 12-23-2015, 07:15 AM   #402
Tim Radley
Colorfabb XT-CF20. I've also got some Taulmann high temp nylon to try. The CF20 will take boost pressure without issue.
Old 12-24-2015, 12:50 PM   #403
celek
Resident Gear Head
celek's Avatar
I saw them at PRI ofcourse I am fully assembled already but my rod bearing is from a RB26 Nissan
FRS Justin (12-24-2015)
Old 12-26-2015, 08:30 PM   #404
burdickjp
Drives: 2013 ultramarine Scion FR-S
Nylon likes to absorb moisture. Not sure on Taulman's specific versions.
burdickjp is offline   Reply With Quote
Old 01-14-2016, 01:02 PM   #405
celek
Resident Gear Head
celek's Avatar
Winter is here and its killing me!
Old 01-18-2016, 05:00 AM   #406
Fricke
Drives: Toyota GT86
Have been following your thread and just have a suggestion
Why not buy some secondhand BMW M throttle body's from s38 or the s50 or S54 thes throttle body's are very common too use in Europe for custom builds.
Do they can be handed for as little as 100$
Djust a thought.
Fricke is offline   Reply With Quote
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 06:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 10:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 08:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 10:48 AM
