Old 08-17-2021, 10:28 AM   #393
jflogerzi
jflogerzi's Avatar
The garage that did mine mounted it a bit with an offset to give it more clearance
2013 Series 10 FRS #553
Old 08-17-2021, 10:40 AM   #394
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
I would contact them. I had a fitment issue with the flanges not aligning to the head studs properly. They sent a replacement.
Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 08-17-2021, 10:47 AM   #395
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
No issues here with my JDL 4-2-1 EL and the ISR overpipe. Stock engine mounts.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 08-17-2021, 12:49 PM   #396
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I sent them a message using the contact form on their site. We will see what they say.
Old 08-17-2021, 04:51 PM   #397
Mike_ZN6
Mike_ZN6's Avatar
JDL got back to me right away! They will be sending out a new overpipe. Hopefully this one resolves the issue.
Old 08-17-2021, 05:12 PM   #398
steverife
Drives: 2016 Scion FRS
I had very limited dealings with them when I purchased my header and FP/OP, but those dealings were very pleasant.
steverife is offline   Reply With Quote
Old 08-19-2021, 12:41 PM   #399
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Just hammer the pipe.
You won't lose any measurable power.
Old 08-19-2021, 02:08 PM   #400
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
JDL 4-2-1 EL header
Here's my VirtualDyno run on a flat road in my BRZ.
My setup is a JDL 4-2-1, stock FP and OP, OnPoint Dyno dyno tune on 94 Octane. Car weighs in at 2945lbs with me in it and a basically full tank (verified from a corner balance in its current state). This run had about a 3/4 tank of fuel so I adjusted my weight based on fuel density vs fuel load accordingly.
JBezugs is offline   Reply With Quote
Old 08-19-2021, 02:27 PM   #401
Goingnowherefast
Here's a vdyno (weights fixed, TY JBezugs).
Blue = Tomei UEL w/ ~4 tune revisions ~E77
Red = JDL 4-2-1 w/ 1 tune revisions ~E71
Originally Posted by JBezugs View Post
VirtualDyno is accurate but you need to have your parameters set correctly.
Man you sniped me RIGHT before I saw the issue while reviewing my post lolol. Weights fixed. Mine are also from a recent corner balancing sessions so they are accurate and adjusted for fuel. Could you delete the quoted vdyno so people don't get confused?
Old 08-19-2021, 02:33 PM   #402
JBezugs
Good Job Subaru!
JBezugs's Avatar
I work quick I guess! Edited my post accordingly, those results look much better now!
Old 08-19-2021, 06:42 PM   #403
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
Dynos of Blub. E85, Delicious tune, Perrin intake, custom 2.5" exhaust and 2.5" metal core cat on both headers.
OEM is 91 pump gas and 100% unmodified.
Ace350 had a torque bump between 3000-3500.
JDL had a bunch more power past 7100.
Both eliminated torque canyon of OEM.
We sold the Ace and run the JDL now. Testing Crawford BPB but so far no power area gain. We'll play with the tune a bit. If no power gains we'll remove the BPB.
949 Racing is offline   Reply With Quote
Old 08-20-2021, 07:43 AM   #404
Goingnowherefast
Great data 949. Kind of confirmed my suspicions. In 2021, considering the price hike and broken weld issues, there's not much reason to get the ACE350 over the JDL 4-2-1 IMO. Unless you're really looking for low end torque.
Old 08-20-2021, 11:20 PM   #405
jflogerzi
jflogerzi's Avatar
JDL really needs to be dialed in to extract all it's power.
Old 08-20-2021, 11:36 PM   #406
Mike_ZN6
Mike_ZN6's Avatar
This is exactly what many people on this forum have been waiting for!
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
