, dpfarr
Old 01-20-2021, 09:33 PM   #4019
Decep
Drives: 2013 FR-S Series 10
Originally Posted by ninjan00dles View Post
That’s what they told me. I have a dry filter anyways but wanted to pass that info along. You could always email/call them if you don’t trust the information, they have excellent customer support
not that i dont trust you personally, it's just that it's not like a k&n filter is as tightly woven as a regular cotton one, it relies on the oil to attract dirt and other crap and keep it suspended in the filter.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 01-20-2021, 10:49 PM   #4020
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
Originally Posted by BR-ZED View Post
Another random question... is anyone running a lightweight battery with this kit? Does it hold up ok? My stock battery died, so was thinking of going with a Braille 14115 (11.5 lbs) to help counteract the weight I added with the supercharger...
I assume it takes a little more to crank the engine with the SC... and there is the water pump for the SC cooling system that runs after the car is turned off.... so is a smaller battery a bad idea? I was originally going to get a Duralast gold but then noticed it was 7.5 lbs heavier than stock. The only thing I don't like about the Edelbrock kit is the extra weight which I can definitely feel in corners. So reducing that as much as possible would be nice.
Anyone have any thoughts on this?
BR-ZED is offline   Reply With Quote
Old 01-21-2021, 01:42 PM   #4021
B T
Smaller batter should be fine, just don't leave the car in accessory position for long amounts of time or put a subwoofer in it. The OEM Audio + system in mine has drained the stock battery before.
B T is offline   Reply With Quote
Old 01-21-2021, 02:44 PM   #4022
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
A dry K&N will do a great job of keeping rocks and some twigs out of the intake, but not much else. I wouldn't run one dry on any engine I planned to keep. I'm skeptical of using them wet.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
B T (01-22-2021), toast (01-22-2021)
Old 01-22-2021, 09:09 PM   #4023
The smaller the battery, the more often you'll be replacing it.
BR-ZED (01-24-2021)
Old 01-24-2021, 01:14 PM   #4024
toast
Drives: 14 BSP Edelbrock BRZ
I ran a Shorai on my car for two years without issue, the last 18 months were with an Edelbrock. Only took it off during ski season when the car would sit outside all day in zero temps. Sold the car and still have the battery.
toast is offline   Reply With Quote
The Following 2 Users Say Thank You to toast For This Useful Post:
BR-ZED (01-24-2021), CSG Mike (01-25-2021)
Old 01-25-2021, 12:00 AM   #4025
BR-ZED
BR-ZED's Avatar
Thanks. I got the 11lb Braille 14115. Also going to keep it on a battery tender when not driving. I'll report back after some use to let you all know how it goes.
Am curious if people have thought much about weight reduction specifically for this kit. For autocross it's tough, since the easy weight reduction (trunk junk, spare tire, etc. is all in the rear of the car, moving the weight forward. This kit makes it even worse with so much weight added in the engine bay (supercharger, oil cooler, catch cans, etc. Need to think of creative ways to take weight off the front of the car to make it more balanced. Besides the battery, the obvious thing is using no windshield washer fluid (7 lbs). I think there are some lighter weight brackets made by Verus as well.
Old 01-25-2021, 05:12 PM   #4026
toast
The kit has you leave off the driver side fuel injector cover, I made a bracket for the passenger side to mount the ECU to that was aluminum to get rid of the passenger side. Those things are stupidly heavy. Not much else under the engine bay. 2 piece brake rotors, aluminum 4-pot calipers of your choosing (and those things are unsprung weight which is nice).
BR-ZED (01-26-2021), ninjan00dles (01-25-2021)
Old 01-25-2021, 07:25 PM   #4027
ninjan00dles
Drives: 2015 FRS
I was wondering why that (driver side cover) was left off lol. I thought I missed a step, I feel better now
ninjan00dles is offline   Reply With Quote
Old 01-26-2021, 10:23 AM   #4028
Gloonge
Drives: 2013 frs raven
Is there a part number out there for an actual dry filter for our intake? Lost a maf to this damn thing, sick of fighting with it.
I have not had any luck getting info out of edelbrock.
Gloonge is offline   Reply With Quote
Old 02-01-2021, 08:20 PM   #4029
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Edelbrock/Comp Cams Merger
So the first shoe drops...
In the interest of reducing overlap (or perhaps avoiding California taxes), Edelbrock is closing its Los Angeles headquarters...
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 02-02-2021, 03:24 PM   #4030
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Dang! That's too bad for SoCal residents. One of the reasons I went with the Edelbrock was that they were local to me, and I went on a tour of their facility. Gave me a better feeling about purchasing something if the manufacturer is a few miles away vs. across the country.
shiumai is offline   Reply With Quote
Old 02-04-2021, 11:59 AM   #4031
B T
Just wanted to point out I've got two of these remote MAP adapters left before I'm out for good.
Old 02-11-2021, 11:19 PM   #4032
shr133
shr133's Avatar
Drives: 2013 FRS
Originally Posted by B T View Post
I've only got 4 Remote MAP sensors left if anyone is interested.
I need a remote sensor block if you have any left... I have a sensor and a harness made...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
