Old 03-21-2014, 09:47 AM   #4019
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by mikalem View Post
I know for the 75 with e85 mike can tune for stock fuel setup (its my config at the moment)
I had planned on doing e85 on the non-intercooled kit prior to my purchase of the intercooler kit. But it never happened lol.
I think the non-ic kit will be happier on e85 than pump imho.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
mikalem (03-21-2014)
Old 03-21-2014, 11:34 AM   #4020
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
As a guy living it, I completely agree!
mikalem is offline   Reply With Quote
The Following User Says Thank You to mikalem For This Useful Post:
xxscaxx (03-21-2014)
Old 03-21-2014, 03:36 PM   #4021
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We have done e85 on stock injectors no problem. We recommend the injectors and pump because it gives you more headroom. You have to bear in mind that we were not contracted to develop a CARB tune, so for this reason we can customize things to whatever people have.
70 on pump non-intercooled on 93 works. 91 stick with the 72.5 or 75mm. On e85 the 70mm really shines....you just need enough ethanol in there to cool the charge down, so in reality even e30 is enough to see the gains from the 70mm. Currently I'm finding myself between e40-e60 running flex fuel and it is super quick just on that. E85 is more HP on but on the 70 that's pushing the stock clutch right now.
Xero-Limit is offline   Reply With Quote
Old 03-21-2014, 03:39 PM   #4022
mikalem
mikalem's Avatar
On your non IC tune can you flip out from the 75 to the 70 without a retune? Making a checklist....
Old 03-21-2014, 04:03 PM   #4023
Xero-Limit
Xero-Limit's Avatar
Right now we can do via mapswitching. So it will default for the 70mm, but if you flip to a map it will do the 75. You can always run the 75 pulley on the 70 tune. You'll be down about 5-8 hp from the straight 75mm tune though.
Old 03-21-2014, 05:18 PM   #4024
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Originally Posted by sw20kosh View Post
That is great that Abbey was able to engineer a IAT sensor that works. The FA20club IAT sensor plate failed horribly as the sensor was reading the temp of the plate and not the air...
As long as your IAT sensor being in the direct airflow of only one runner does not cause too much airflow difference in that runner it should be perfect. I guess as long as the car is tuned afterwards it should be fine.
Wow I didn't know the the Fa20club plate was not good. I've been running it since I installed my kit and haven't noticed any issues. I do plan on going back to the stock MAF sensor when I get the updated tune from @DeliciousTuning and just using the plate as a boost source for my aem failsafe.
Does anyone know if I can run a non intercooled tune with a intercooler installed? I want to install my intercooler this weekend and I am still waiting for the updated tune. I thought I remember reading that you can but i want to make sure first.
Area86 is offline   Reply With Quote
Old 03-21-2014, 06:02 PM   #4025
xjohnx
Grip>Slip
xjohnx's Avatar
Interesting, I didn't know this. Thankfully I haven't been switching pulleys. Just to confirm, we have been tuning mine for the 70MM, correct?
speaking of flex fuel.. are they in stock? how long of a wait for all black fittings?
Old 03-21-2014, 06:05 PM   #4026
sw20kosh
Drives: 2013 Black FR-S
You won't "notice" anything unless you track your IAT temps from the sensor. You will see that the sensor heats up as the engine heats up and it will not read the temp of the actual air in the runners but instead the heat that the manifold soaks up from the rest of the engine.
Old 03-21-2014, 06:19 PM   #4027
Area86
Area86's Avatar
Ok I get what you are saying. I monitor the temps on my torque app and that makes sense now because thats pretty much what I see. Would I be able to remove it without a retune?
Sent from Samsung Galaxy Note 3
Old 03-21-2014, 06:30 PM   #4028
sw20kosh
Check with your tuner. It is dependent on the tune strategy used around the sensor.
If the tune gets conservative as the temp increases then your timing is being pulled back as the sensor warms up with the engine.
Old 03-21-2014, 07:07 PM   #4029
Xero-Limit
Xero-Limit's Avatar
We got you on the 70 so all good.
For flex fuel we just got our order of fittings today after a two week delay! We have ONE set of all black not yet spoken for, then enough for five of the black/silver.
Old 03-21-2014, 07:20 PM   #4030
xjohnx
Grip>Slip
xjohnx's Avatar
dammit mike. gimme the black. order incoming.
Edit: actually, i'm going to hold off to make sure the E85 fine tuning doesn't run into any issues first. hopefully you'll still have that black set at the end of the weekend once we've had a chance to tweak it.
Old 03-21-2014, 07:24 PM   #4031
NickFRS
Drives: 2013 Asphalt FRS
I have the ACT street prolite kit. So no worries on the clutch. Already have the non intercooled kit tuned on 92 oct. Just thinking about throwing the 70mm on with a 3bar and running E85. Is it possible with stock injectors and pump? Also would it max out the stock MAF in the stock airbox? My Current tuner has concerns.
@PRE-Erich
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 03-21-2014, 07:29 PM   #4032
Xero-Limit
Xero-Limit's Avatar
Originally Posted by NickFRS View Post
I have the ACT street prolite kit. So no worries on the kit. Already have the non intercooled kit tuned on 92 oct. Just thinking about throwing the 70mm on with a 3bar and running E85. Is it possible with stock injectors and pump? Also would it max out the stock MAF int he stock airbox?
@Erich-PRE
Ok, so you're good on the clutch. Our clutch was letting go on e85 in the colder weather. We dyno'd 285 in hot weather. On the 70mm. 3 bar will be OK on non-intercooled, but not once you put the IC in there.
Yes, possible stock injectors and pump.
Stock MAF will be right a the limit. The CEL threshold will need to be raised a bit, but you don't want it too close to 5v as you won't know when you do then.
Perrin 3" MAF CAI is a great on this setup. We also have our custom 3" warm air setup with an oversize filter, and that works just fine as it sits right at the opening just about (very similar to JRSC)
The Following User Says Thank You to Xero-Limit For This Useful Post:
NickFRS (03-21-2014)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
