, dpfarr
Old 10-20-2020, 12:11 AM   #3949
B T
If I've learned anything from Zach, it's wait for the VVT to be activated, I'm wondering if yours isn't on yet.
B T is offline   Reply With Quote
The Following 2 Users Say Thank You to B T For This Useful Post:
CSG Mike (10-21-2020), Side (10-21-2020)
Old 10-20-2020, 11:37 AM   #3950
B T
Getting rid of my passenger side Radium catch can and D-box if anyone is interested.
Old 10-20-2020, 12:25 PM   #3951
Gloonge
Drives: 2013 frs raven
Are you running the driver side still? Picking up a lot of oil?
I have a passenger side one installed, been wondering if I should do the other side or not.
Gloonge is offline   Reply With Quote
Old 10-20-2020, 12:54 PM   #3952
B T
I routed the passenger side lines to the drivers side because it's easier to empty. The recycle line back to the intake never picked up anything, so I just removed those lines and vented to atmosphere.
Old 10-20-2020, 01:16 PM   #3953
Gloonge
Weird, I have move hooked directly to the pcv and getting like an ounce per pill change. Strange.
Old 10-20-2020, 01:27 PM   #3954
B T
So your driver's side has been collecting a lot of blowby?
Old 10-20-2020, 01:31 PM   #3955
Gloonge
Passenger side to TB, I read yours as driver side to air box.
Perhaps we are talking about the same side collecting
Old 10-20-2020, 01:55 PM   #3956
B T
I think so, it was passenger side collecting, but I routed those lines to driver's side now for easier access.
Old 10-20-2020, 02:01 PM   #3957
Gloonge
Gotcha, just longer lines. We're on the same page. I guess I don't need the second can then . Thank you!
Old 10-20-2020, 07:05 PM   #3958
AKITA
AKITA's Avatar
Drives: 2016 Scion FRS Halo
I also don't get much on the driver's side with std hose routing. I do pick up tiny amounts on the passenger side. I would agree that a standard routed driver side isn't pickup much.
AKITA is offline   Reply With Quote
Old 10-21-2020, 07:13 AM   #3959
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
As far as the vvt is concerned it's active. Or at least says it is. With the new roms they have programmed in a triple flash on the check engine light to let you know if it isn't active.
aKaGorganZola is offline   Reply With Quote
Old 10-28-2020, 10:15 AM   #3960
aKaGorganZola
So I think I've found the issue. It appears to me that my bypass valve is sticking open? It opens normally under vacuum but when I try pulling the line off the valve it doesn't release immediately. And the time it takes to drop differs each time.
I tried to take a video to show it but it's kind of difficult to get an angle of both but your can hear the click is the valve. From what I'm understanding that delay is not normal.
My thought is that it's opening just slightly too far and it's getting stuck like an old carb that didn't have the stops adjusted correctly. Is there an adjustable stop or will I need to remove the whole valve to fix it?
Old 10-28-2020, 02:57 PM   #3961
B T
I looked at this on mine when it was apart. You can try to reposition so it doesn't open quite as far, block the movement from opening fully or get in there and deburr the opening around the bypass port.
Old 10-28-2020, 03:40 PM   #3962
toast
Drives: 14 BSP Edelbrock BRZ
There are stops for the actuator, it is adjustable and has a lock nut on it. That is all set at the factory, I would be very leery of moving those. I can't tell from the video what you are referring to, when you connect the vacuum hose back up it will take a moment for that air column to reach the vacuum level to close the valve.
toast is offline   Reply With Quote
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
