Old 10-07-2020, 06:06 PM   #3935
sftateofmind
Evening Primrose
sftateofmind's Avatar
Originally Posted by Racecomp Engineering View Post
Do you have an alignment printout?
What spring rates do you have now?
Ride quality is mostly down to suspension travel, spring rates, and shock valving. I don't know much about Silvers coilovers, but if the valving isn't good, different spring rates will only help a little bit. Valving is reeeeeally important.
- Andrew
I went camping and just got home. Apologies for the delay.
Here is a print out of my alignment printout.
Here is a link to the springs. I have 6k rear and 6k front for rates.
sftateofmind is offline   Reply With Quote
Old 10-08-2020, 09:59 AM   #3936
No worries. I might go camping this weekend if Hurricane Delta doesn't complicate things too much. I get rained on every dang time....
Those spring rates should be able to ride well. Have you tried adjusting the damper settings at all?
- Andrew
Old 10-09-2020, 05:12 AM   #3937
sftateofmind
Evening Primrose
- Andrew
I haven't made any adjustments at the moment. Was hoping to better understand what direction to go in terms of adjustments to try and curb the issue of my ABS coming on in corners. The last thing I want is to ruin anything.
Old 10-09-2020, 09:14 AM   #3938
Try softening the dampers a couple clicks and see if it improves.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
sftateofmind (10-17-2020)
Old 10-14-2020, 12:26 PM   #3939
Alarik
Drives: BRZ '13
Most of those (including Tein) are much better than BC. We like KW and Bilstein a lot but they don't always come with camber plates.
- Andrew
Ok, i'm now looking on a Tein's Flex Z and just wondering won't they be too soft with 6kg spring rate for track use? Surface on our racetracks is kinda rough and bumpy so cars with soft suspension bounce too much. And the second question is will i need adjustable end links for Teins or i can reuse OEM ones?
Alarik is offline   Reply With Quote
Old 10-14-2020, 06:11 PM   #3940
Calum
That Guy
Drives: 2013 asphalt FRS MT
Any time you're using adjustable ride height dampers you should use adjustable endlinks to prevent preloading.
Old 10-14-2020, 07:51 PM   #3941
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Takumi788 View Post
I attached that exact thread and mentioned it in my original question on the last page of this thread. lol. That thread is bookmarked
Yeah, I will take a down vote on my post. This is the price to be paid for not reading a thread in its entirety. To save you the trouble allow me to do this to myself.
PikachuBRZ (03-08-2023)
Old 10-14-2020, 07:56 PM   #3942
Captain Snooze
Drives: Red Herring
Lots and lots and heaps of variables but I was using 6k/6k springs on track (probably smoother than your track but there's a bit of kurbing and ripple strips to contend with) now 7k/6k. I'm suggesting that damping would sort out the "bounciness". I'm not saying 6k is enough for you but when you say bounciness I think damping.
Because compromise.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
Alarik (10-15-2020), Pat (10-14-2020)
Old 10-15-2020, 09:54 AM   #3943
The spring rates are good. Stiffer would be better with very sticky tires.
If you're corner balancing the car I would recommend adjustable end links. Some coilovers will need them anyway (not sure with Tein Flex Z).
I don't have much experience with Tein Flex Z but my understanding is that they are more intended for the street.
- Andrew
Alarik (10-15-2020)
Old 10-15-2020, 11:35 AM   #3944
HaXx
Drives: jrsc_brz
the stock endlinks often get ruined when taking them out to put different struts in. I would urge you to have a new pair to put in while doing the work, even oem is fine.
the oem front endlink nut is often rusted onto the endlink bolt, but the bolt spins in the endlink, you have to put an allen in the hole at the end of the endlink bolt and spin the nut off. 9/10 the rusty allen hole crumbles, and you wind up spinning the nut and bolt together inside the endlink.
i have installed lowering springs and coilovers on multiple friends cars in my area and getting the stock front endlinks off is by far the hardest part, at times we have resorted to sawing them off and replacing with new.
it is hard to see, but you notice a small hole in the end of endlink bolt. that is where the allen goes. new endlinks use a fixed bolt inside the endlink housing which requires only a wrench, no allen.
hope this helps
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
The Following 3 Users Say Thank You to HaXx For This Useful Post:
Alarik (10-15-2020), Ohio Enthusiast (10-15-2020), RToyo86 (10-15-2020)
Old 10-20-2020, 11:31 AM   #3945
Compelica
Compelica's Avatar
Drives: 86 GT
Hi guys,
I'm running HKS Hipermax GT coilovers which comes with a 20mm or so drop from stock. The shorter endlinks that came with the car were installed as well.
I've raised the car back to stock height as I was dealing with ground clearance issues. I understand that the stock endlinks may create a preload on the sway bars when the car is lowered but what about the opposite (shorter endlinks, stock height)? The car drives normal and I don't notice any issues but is there something I should be concerned about?
Compelica is offline   Reply With Quote
Old 10-20-2020, 11:37 AM   #3946
It depends on the coilover.
I probably wouldn't be concerned for a daily driver. But you can check by uninstalling the endlinks and seeing where everything lines up.
- Andrew
Compelica (10-21-2020)
Old 10-20-2020, 02:16 PM   #3947
Flex Z are definitely street oriented coilovers. Unless you're super slammed, stock endlinks will be fine.
Old 10-20-2020, 04:04 PM   #3948
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
I was looking to upgrade my 2014 BRZ with lightly use 2018 OEM SACHS PP SHOCKS and springs. What else should I consider other than a straight swap? I already have camber bolts installed. This is for a daily driver.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
