Old 11-26-2012, 12:57 PM   #3935
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by yomny View Post
Guys just wondering if anyone's had the issue im having when trying to update the license on my proecu software. I go and read my license count and shows 0, so i select and run the ECUTEK update but at the end i dont get the "license update downloaded" window, i just get a "thank you..." and no license update. I've read over the how to's several times but no update. Is there something im missing? Thanks
have you already flashed at least one tune? if so, this is normal.
xjohnx is offline
Old 11-26-2012, 01:03 PM   #3936
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
I had a similar issue when I tried to install the tune my first time ever. The tune did not install and the license was at 0. Nothing I did could fix it.
I called John and I had to have my laptop connected to the internet and connected to my car. He remotely signed into my laptop fixed the license, gave me a newer tune and installed it.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline
Old 11-26-2012, 01:23 PM   #3937
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
yes i've flashed one tune and well now we're trying to work out a little knock im getting when reving the car. I'm thinking john's working a fix based on some logs i did and i will eventually have to flash the car again but wont be able to since i cant update my license.
John had to do the same thing with me, remotely update and flash.
PS- Anyone on the lastest flash getting knock when reving the engine. If i slap the gas pedal as to give it a quick rev up to lets say 4k rpm's i would get a knock sound. I did a log and indeed i'm getting knock counts up to 4 when the gas is suddenly punched back to back, it may not do it if you give it a quick rev.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline
Old 11-26-2012, 01:25 PM   #3938
xjohnx
Grip>Slip
xjohnx's Avatar
You don't need to update your license. The license lives on your ECU after you flash your car. Seeing 0 there is normal after the first flash. You shouldn't have any problems flashing subsequent tunes.
xjohnx is offline
The Following User Says Thank You to xjohnx For This Useful Post:
yomny (11-26-2012)
Old 11-26-2012, 01:30 PM   #3939
yomny
yomny's Avatar
Oh ok so that means after the first flash im good to go. Thanks for that, i was actually stuck on that parts and fearing i would have to keep bothering john for license updates.
yomny is offline
Old 11-26-2012, 01:33 PM   #3940
xjohnx
Grip>Slip
xjohnx's Avatar
Yep. You can verify this by connecting the cable to your car/laptop, opening ProECU, going to tools -> detect vehicle, then Program Vehicle ECU. Click the query ECU button. In the text on the right hand side look for something that says "A standard tuner license is present in this ECU. Programming will NOT consume a further flash license."
xjohnx is offline
Old 11-26-2012, 01:40 PM   #3941
yomny
yomny's Avatar
Man, you just saved me a couple of nights of sleep. I was going nuts, and having this knock issue literally blinded me, even though john instructed me to read over the first half of the instructions where it said "the first time..." i completely omitted that portion. thanks a lot.
yomny is offline
Old 11-26-2012, 02:16 PM   #3942
ngabdala
No knocking here bro
ngabdala is offline
The Following User Says Thank You to ngabdala For This Useful Post:
yomny (11-26-2012)
Old 11-26-2012, 02:30 PM   #3943
yomny
yomny's Avatar
Thanks man, im not sure why mine is doing that. I'm completely stock, as i was driving home today and when giving the gas pedal a quick kick as to rev match i hear the chirp, knock noise. Sucks, hopefully john could help me out with this, as i dont mind the noise im positive the knock can't be good for the car. Glad to hear you dont get any knock man. Aside from this little noise, the latest flash makes the car so much easier to drive, less twitchy or snappy when getting on the throttle, taking off is also smoother and the power delivery is progressively increased through out the rpm range. The one thing i dont know yet is what the racerom traction control does or how it works.
yomny is offline
Old 11-26-2012, 02:50 PM   #3944
Yruyur
Yruyur's Avatar
Do some logs and send them to him via the support console. When you have the log then open it by double clicking on it and look at with the 2D view tab to see the knock and how the car is running at that moment.
Sent from my flux capacitor using Taptalk
Yruyur is offline
Old 11-26-2012, 03:38 PM   #3945
xjohnx
Grip>Slip
xjohnx's Avatar
any chance you can make a video of the noise?
xjohnx is offline
Old 11-26-2012, 03:48 PM   #3946
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
It sounds strange to be getting knock while not under load (revving). Makes me wonder if it isn't some mechanical noise that is causing false knock at the sensor but isn't actually knock.
Jeff86 is offline
Old 11-26-2012, 04:04 PM   #3947
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Saw the latest racerom notes and still have the p0018 cel. Cant wait to try the latest flash and see if it gets rid of the cel. Now im anxious!
brichard0625 is offline
Old 11-26-2012, 04:06 PM   #3948
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
I'm anxious too! I finally broke down and ordered my Visconti tune last week after deliberating between his and those guys giving away an intake with their tune. Really excited and I know I made the right choice. Be picking up my cable from the post office after work today
Jeff86 is offline
The Following User Says Thank You to Jeff86 For This Useful Post:
xjohnx (11-26-2012)
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 10:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
