, dpfarr
Old 09-21-2020, 03:41 PM   #3907
AKITA
AKITA's Avatar
Drives: 2016 Scion FRS Halo
Originally Posted by Smaay View Post
When under full boost it sounds like the bypass valve is open, how is that possible? if its under spring tension? What is causing the P0171 codes? its all metered air going in so whats making the lean condition?
So if doesn't close.. as pointed out.. you will have a leak and a lean condition. I understand and agree it's a lot riding on a inexpensive part.
AKITA is offline   Reply With Quote
Old 09-21-2020, 04:59 PM   #3908
Decep
Drives: 2013 FR-S Series 10
Should the coolant expansion tank for the supercharger be on the MAX line when it’s cold, or should it be in the middle on a cold engine?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 09-21-2020, 07:42 PM   #3909
Side
Side's Avatar
Drives: 2018 BRZ tS
My understanding was that it should be just below the middle line on a cold engine. You want enough in there that it circulates properly on a cold start, but has room for overflow during hard driving.
Side is offline   Reply With Quote
Old 09-21-2020, 09:45 PM   #3910
Decep
i figured as much. thanks. i had to add a teensy bit.
RCE SS-1 Coilovers
Corsa Catback
Old 09-21-2020, 11:53 PM   #3911
Smaay
Drives: 2013 FRS
so I finally shined a light under the runners, I have the 3 bolt bypass valve. If I pull off the hose at the manifold and suck on it, the valve doesnt budge and I can suck in quite easily. I attached the hose and at idle I can see the valve get pulled open. If I pinch the hose the valve immediately closes. Based on the post 2368 I have a huge leak in the diaphram. This is the source of my P0171. The fuel trims are like 40%.
So I need to fix that first.
Smaay is offline   Reply With Quote
The Following 2 Users Say Thank You to Smaay For This Useful Post:
AKITA (09-22-2020), BirdTRD (09-23-2020)
Old 09-22-2020, 01:01 AM   #3912
Cerbrian
Cerbrian's Avatar
Drives: 13' white out frs
I've been reading that edelbrock changed to a dry air filter. Does anyone have a part number for it?
Sent from my SM-N975U using Tapatalk
Cerbrian is offline   Reply With Quote
Old 09-22-2020, 04:44 PM   #3913
Auto_egr
Drives: 2017 CWP BRZ w/PP
I received my kit today. Looks like the updated K&N PN is SP3737, Edelbrock PN 51-0157.
Auto_egr is offline   Reply With Quote
The Following User Says Thank You to Auto_egr For This Useful Post:
Cerbrian (09-22-2020)
Old 09-26-2020, 11:36 PM   #3914
toast
Drives: 14 BSP Edelbrock BRZ
So the new valves fail just like the old ones? That's great.
Move the source of the valve to vacuum once you get a new one.
toast is offline   Reply With Quote
Old 09-27-2020, 03:57 AM   #3915
Side
Side's Avatar
Drives: 2018 BRZ tS
He has the old bypass valve. The new bypass valve is two bolts.
Old 09-27-2020, 10:35 AM   #3916
toast
Ah, ok. Been a while since I've had my car and forgot which bypass valve has which.
Old 09-28-2020, 04:47 PM   #3917
B T
Just ran the car for the first time with the remote MAP sensor modification. No power drop in upper rpm due to MAP fluctuations in the runner anymore. Feels much better.
B T is offline   Reply With Quote
Old 09-28-2020, 04:54 PM   #3918
Gloonge
Drives: 2013 frs raven
Got a link to the diy?
Gloonge is offline   Reply With Quote
Old 09-28-2020, 06:29 PM   #3919
Smaay
Drives: 2013 FRS
Got an update, Edelbrock sent me a warranty replacement of the 3 bolt bypass. I was able to change it out in about 45 minutes. Just took off the Throttle Body and it was pretty easy.
Driveability is much better. I havent thrown a P0171 yet. and I havent seen the issue of no power at full throttle and yet my boost gauge was saying 10psi.
as for the bad valve, I couldnt even suck on it and get it to move. I might as well been sucking through a straw. the new valve I easily could suck it in and move the valve. The diaphram must be totally torn.
Old 09-28-2020, 06:35 PM   #3920
Smaay
Drives: 2013 FRS
So other than the SC my car is all stock. I want to get an exhaust and get tuned and I like to get the most I can for pump gas. (Not messing with flex fuel)
Been watching all the FTspeedfactory videos. I want a good exhaust (catback) thats not too loud (i live in Kaliforniastan) and doesnt have a terrible drone in the 3K range.
I love the idea of going full header back but will i get the most gains for that? and again the CA thing.
So those with experience, please educate on what works and what numbers you have got in TQ and HP.
Thanks
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
