#379 |
Drives: 2013 WRB BRZ
I hate being a bother but can someone check this log for me? I would appreciate the input. It's OFT OTS 2.63 93 Octane timings run with our 98 Octane. I did the pull about 15 minutes after cruising on the high way.
http://www.datazap.me/u/baderebra/93...6-7-9-10-13-14 |
#380 |
Drives: 2015 Subaru BRZ Series Blue
I don't think running 98 octane on 93 tune is a good idea.. Even running 93 on the 91 tune isn't recommended. I could be mistaken
http://instagram.com/cameronjones239
2015 Subaru BRZ Series Blue Build http://www.ft86club.com/forums/showt...09#post2002909 |
#381 |
It's always safe to run higher octane fuel on a lower octane tune.
The issue with 98 RON is that it's not as good as 93 AKI. I'm just testing the fuel here since no one in my area gave me a clear answer. |
#382 |
Drives: JAWS
How many miles do you have on the tune? Your IAM is 1 but based on your FLKC, it's not gonna stay at 1.
#383 |
#384 |
Drives: JAWS
I figured. It seems that the IAM won't drop for a while when the ECU is first learning even though you're seeing significant FLKC. Do another log after 50-100 miles on the tune.
#385 |
Will do. Thanks.
#386 | |
Oops, yup you're right. Was thinking the opposite -_-
#387 |
Drives: 2014 Toyota 86
So this is one of my first posts here, thought I would post up a FI log.
I aplogise that the data channels weren't the best, it was a rush to get on the track and I didn't think driving around the track fidiling with the data logger was the best idea ![]() http://www.datazap.me/u/harro/willow...5?log=0&data=8 |
#388 | |
take note of rpm and load where its occurring and pull about half the correction value out of the base timing b map. running the 91 map wont fix it as the only change is timing over 5000 rpm reduced by about 1 degree. |
#389 | |
Bit of knock flkc up to -1 degrees so not to bad, Check what your IAM is as you did not log it , should be 1. You could maybe pull a some timing out of the base timing B map where your seeing knock to be safe especially if your going to track regularly. The oil temps are about 235 c and its been pretty cool in brissie, are you running an oil cooler and 10W30 or 10W40 oil ? as 225C is about the max temp you want to see on 0W20 oil. |
#390 | |
Thanks for the look mate, I'll log IAM next time and see what it sits at. Yeah I'm running the mishimoto oil cooler, although it sits behind the intercooler for the SC - so it maybe getting a stream of hot air. May have to look at running 0-30W oil to get those temps under control. Cheers for the feedback mate, I really appreciate it - next time I catch up with you at the track I'll make you an instant coffee
#391 |
Drives: 2013 BRZ 6MT
I have no idea what I'm looking at here, so will you guys help me.
uncatted JDL UEL header 3" JDL overpipe and catted resonated front pipe 3" resonated Perrin catback Perrin intake tube K&N air filter Logged after flash(Sg 2 UEL v2.063 93 octane): Start 125 miles, End 154 miles http://www.datazap.me/u/wolvenhaven/...l?log=0&data=1 |
#392 |
Did you mean to post a ~13 second log?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
