#379 | ||
Drives: '23 BRZ
static weight and weight distribution acceleration (lateral g's and longitudinal g's) c.g. height track wheelbase To further determine individual tire loads, you just need to know relative front/rear roll stiffness. That's it. For simplicity, I talked about steady-state cornering (front/rear load distribution is same as static). You could just as easily calculate the individual wheel/tire loads for other points on the friction circle, like 0.71-g braking combined with 0.71-g cornering (trail-braking), and 0.5-g acceleration combined with .87-g cornering (lowish power/weight car accelerating out of low-speed corner). Quote:
Either way, once you do pick up an inside wheel, you increase the rate of loading the outside wheel and unloading the inside wheel at the opposite end of the car. It sounded to me like you were saying that when you picked up the inside front, you'd actually start to INCREASE load on the inside rear. Now I see you must have meant that if your *setup* is such that you lift the inside front first, that this keeps the inside rear loaded more. Agree! It is of course still preferable to keep all four on the ground, but if you have enough grip you will start to pick up an inside wheel given a track width, c.g. height, and grip levels. On just about any halfway decently set up fwd car (even totally stock) you will pick up the inside rear on corner entry due to massive static front weight bias and near-1g braking combined with some cornering load. On a rwd car with decent power/weight and weight distribution and setup, it is also possible to lift an inside front accelerating out of a low-speed corner (my 255hp 240Z did this). Given limitations on c.g. location and track width, you sacrifice a bit of ultimate cornering grip to get better drive out of the corners. On a 60/40 - 70/30 FF car, you use rear roll stiffness to keep the inside front planted for corner exit. On a 50/50-60/40 FR car, you dial in a lot of front roll stiffness to keep the inside rear loaded. |
#380 |
Drives: '23 BRZ
Regarding aftermarket control arms, I'm a *MUCH* bigger fan of offset bushings like those linked to by Calum above ( http://www.whiteline.com.au/product_..._number=KCA436 ) and keeping the stock arms, which are known to have been designed and tested for a lifetime of usage on the car by a small army of well-equipped design, analysis, and test engineers. Anything aftermarket, you're pretty much guaranteed that they don't have nearly the engineering development and testing behind them. I've seen some aluminum arms for the twins that have MINIMUM section properties at the point of MAXIMUM bending moment.
I ran offset aluminum/delrin bushings on the 240Z for many years, thousands of track miles, they *never* shifted and I had zero wear issues. I did lubricate them with Nevr-Sieze when I installed them, but no maintenence after that (some people install zerk fittings to periodically grease them). If one of the bushings wears out, no problem, you'll hear it, and you won't be structurally compromised. I'm *much* more worried about replacing well-developed and -engineered PRIMARY VEHICLE STRUCTURE from the factory with aftermarket parts. |
#381 |
i'm sorry, what?
Drives: Canada
properly installed anything is gonna last you a good amount of time
#382 | |
Drives: '23 BRZ
It pains me to see people so eagerly replace well engineered CRITICAL primary structures with aftermarket designs that may look great, but don't have the engineering development or testing behind them. If you don't have the ability to do the analysis yourself, I say *stay away* from aftermarket STRUCTURAL components. There's very little to nothing to be gained there, and a lot to lose... |
#383 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#384 | |
i'm sorry, what?
Drives: Canada
I meant to say something else with my comment, I left it too open for interpretation.
#385 | |
That Guy
Drives: 2013 asphalt FRS MT
Yes and no. While it is very simple, and certainly doesn't warrant $110 (FML) I would much rather use this type of design over everything else I've seen. So, fancy, no. Eloquent, yes. Unfortunately Sam Strano doesn't sell a similar Powerflex product. |
#386 |
Installed SPC LCA's and I must says they are fantastic for bringing the back into spec after a decent lower. I didn't need to use the toe kit. They are very stock like and the joint is nicer.
#387 | |
Señor Member
Thank you for the input :happy0180:
1974 TA22 Celica
2013 86 GT |
#388 |
Drives: Raven FR-S
my friend has some leftover swift springs in 6" 10k/12k and said i could have them for free. if i were to swap them out onto my kwv3s, would i have to revalve them? i was thinking of going to a stiffer rate but i think that might be way too high.
#389 |
10k/12k would be pushing it big time for KW V3.
- Andy |
#390 |
Drives: '13 BRZ Ltd
Real quick RCE - does the BRZ have the same rear tophats as the GR STI/WRX?
#391 |
Just a dude
Drives: Scion FR-S 2013
Hmm something on topic but haven't really grasped this yet. I was wondering with top hats "front" that (ADD) a degree of castor such as Vorshlaggs, how does this affect things? Does a person have to somehow go about having less NEGATIVE camber setup up front due to forces of more castor while turning? Guess I'm trying to ask is with plates that add castor, should a user use less negative camber versus a plate that does not add castor?
#392 | |
The @Hancha piece seems to be excellent as well. |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
