05-10-2016, 06:47 PM | #379 | |
Drives: 2017 BRZ
C |
The Following 2 Users Say Thank You to cjd For This Useful Post: | Bramick (05-11-2016), strat61caster (05-11-2016) |
05-11-2016, 02:44 PM | #380 | |||
With it in regular mode the car is more forgiving to stabbing the pedal for whatever reason, with diagnostic brake/pedal/dance mode the car will punish you for not being smooth on the brakes or just plain old freak out. ABS is still active in pedal/brake dance mode, it just seems to give way to ice mode much more readily. I'm not exactly in a position to go through and investigate like others around here. http://www.sccaforums.com/forums/aft/392890 Try it at a Test and Tune event, a ideally with a skidpad so you can take the same two corners 20x in a row, make the change and then immediately do it another 20x times. When I did that it was a lightbulb, "Oh, THAT'S trail braking!" because with the car in regular TC off mode it certainly tries it's best to keep you braking in a straight line. To me it's a shift in how I brake, just because I CAN brake harder, doesn't mean I should, I really have to be more delicate in my braking application, I can't stab at the brakes anymore, I have to squeeze the pedal. I felt the weight transfer and effects of trail braking before in standard mode (part of that was really attacking the brakes), but there's so much more of it in diagnostic mode. I overdid it and lost the backend at least 3x during the first skidpad session with it off (to cut myself some slack and garner a bit of sympathy I was trying to figure out left foot braking at the same time), by the end of the day it felt like on demand rotation under braking. It really is a 4th/5th mode in the traction control and changes how you step up to the limits of traction. Getting the most out of the car with TC on is very different than with TC off, and it's different again without EBD. Quote:
It's definitely the case that EBD limits the trail braking potential of the 86 in standard modes. Effective and masterful use of the brake pedal is critical in being deemed a skilled driver, no argument can be made against that. Without using the trail braking available you're leaving speed on the table, plain and simple, that was established in racecars 40+ years ago by Jackie Stewart and Mark Donohue, earlier in motorbikes I believe, and it's the standard today. The best way to get faster is to raise your minimum speed in the corner, not brake later or accelerate harder. 'Bad driver' is a combative phrase, those not capable of utilizing the brake dance still have more to learn, plain and simple. I'd bet there's some very fast guys out there who prefer not using it but understand it's potential, but I have a hunch the guys that do use it will come out on top all else being equal. I am still miles away from being able to parade myself up as an example, but sometimes the language barrier between the extremely skilled and the intermediates who are hunting for the speed is too great, let's build a bridge together. Last edited by strat61caster; 05-11-2016 at 03:07 PM. |
The Following 3 Users Say Thank You to strat61caster For This Useful Post: |
05-12-2016, 11:48 PM | #381 | |
If nothing gives you might want to try a few runs with ABS disabled. Should be able to stab the pedal all you want then and for your case would be safer if you're hitting ice mode so frequently.
05-13-2016, 01:21 AM | #382 | |
The only way to disable the abs is to pull the fuse to my knowledge (and budget) which is illegal for street classes in SCCA. Worth an experiment for sure, but it wasn't a problem for me after experimenting with the diagnostic mode and getting comfortable with it at the test n tune, seat time can fix many many problems that the impatient use as excuses to spend money. |
05-13-2016, 11:29 AM | #383 | |
The Following User Says Thank You to Beastronix For This Useful Post: | strat61caster (05-13-2016) |
05-13-2016, 11:34 AM | #384 |
Drives: 2013 Subaru BRZ Limited LR
I am eagerly awaiting @2superblus review of this item.
I use an Aim SoloDL for data capture via obd port; has anyone used the pass thru with success? |
05-13-2016, 01:45 PM | #385 | |
Communication wise everything will work perfectly fine. The pass-thru is a full 16pin which just acts as an extension for any other devices you want to use. The 86Nanny will run at communication spec for these cars and doesn't spam the network causing any error frames for your other devices. It simply joins the network & talks exactly as the rest of the nodes in the car do. Bart should have something up soon.
The Following User Says Thank You to Beastronix For This Useful Post: | GeorgeJFrick (05-13-2016) |
05-13-2016, 04:47 PM | #386 | |
Drives: 2017 BRZ
C |
The Following User Says Thank You to cjd For This Useful Post: | Beastronix (05-13-2016) |
05-13-2016, 04:49 PM | #387 | |
Drives: 2017 BRZ
05-13-2016, 04:59 PM | #388 |
Drives: 13 BRZ WRB
I am looking to install it either tonight or this weekend. You will know how it goes next weekend.
The Following User Says Thank You to 2superblus For This Useful Post: | Beastronix (05-13-2016) |
05-15-2016, 03:31 AM | #389 | |
Drives: MX5 Miata Mk2.5 1.6
EBD DOES NOT funtction at each wheel, ABS does this...
Back to the ancient art of driving! |
05-15-2016, 10:40 AM | #390 | |
05-15-2016, 10:44 AM | #391 | |
The Following User Says Thank You to Blokatos For This Useful Post: | stevesnj (05-15-2016) |
05-15-2016, 07:12 PM | #392 | |
I've done two autox events so far in my C-street 2013 FR-S both doing the pedal dance. I have yet to experience any of the negative side effects. As for the "good driver/bad driver" bs, who cares what the guy next to you is doing? I tend to focus on things I can control. |
Similar Threads | ||||
Where to buy "heel/toe" shaped gas pedal? | dookie11 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2019 11:24 AM |
Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 08:55 AM |
