Old 07-17-2013, 06:36 PM   #379
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Originally Posted by abutterman View Post
Just did a fluid change to Redline MTL 70w80 as well as the Perrin rear shifter bushing and a Kartboy pulley. Shifting is much smoother all around. Had a good 45 minute drive home after installing everything and most of the resistance is gone and it tends to go into gear much easier
Good to know! I'm considering doing the same on my end.
Mad1723 is offline   Reply With Quote
Old 07-17-2013, 11:24 PM   #380
Dezoris
Dezoris's Avatar
For those with gear grinds in higher gears, dont skip gears. Go from 2 -3-4-5-6th.
S2000 and other Aisin trans had same problem eating syncros going from higher load 2nd or 3rd into 5th or 6th.
Old 07-17-2013, 11:27 PM   #381
Dezoris
Dezoris's Avatar
Originally Posted by ft_sjo View Post
It'll make two-fifths of fuck'all difference. The issue isn't the oil, even though the placebo'ites will argue it to the death.
Those who shift from 3rd to 5th or 6th after high revs who get grinds wont be helped by trans fluid.
But shift performance namely in extreme cold and hot will for sure.
Old 07-18-2013, 12:40 AM   #382
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Shift slower if skipping gears. It's a no brainer. If you're skipping gears you shouldn't be "on it" anyway.
Do you really want to save your synchros? Double clutch on your downshifts it essentially negates their purpose. Drive a 1960's Alfa or Lotus and the synchros only last for 20k miles, after that you essentially had a synchro-less tranny and if you didn't learn to double clutch, you weren't ever going to be shifting down.
PRO86 | STL | LuckyDog
Old 07-24-2013, 10:03 AM   #383
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Ok tranny/oil experts
So... Where I live and for spring to winter which is when the car sees it only miles my ambient ranges from 32-95F. My car is at 4.2 miles or 7500km+. Dealer changed first oil change however still original tranny oil. Therefore as this thread went all over the map lol... Which out of all discussed would be optimum choice for "my" car???
Old 07-24-2013, 03:52 PM   #384
cantholdanymore
cantholdanymore's Avatar
Drives: FR-S Very Hot Lava
See b post by Roddy above
cantholdanymore is offline   Reply With Quote
Old 07-24-2013, 08:04 PM   #385
OICU812
Just a dude
OICU812's Avatar
Thanks I am blind, next hurdle is fact that can't find a vendor that can ship all these fine oils to me in Canada fucking pain in ass. Thanks to Steve for replying though for sure, I was willing to send you a wad of cash for 3 flush jobs worth of oil but I understand...
NOW to find someone in this baron land to sell me some MTL and Motul....fak...
Old 07-24-2013, 09:40 PM   #386
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
It pissed me off I couldn't find anything also. I used pennzoil synchromesh, works good so far.
Rayme is offline   Reply With Quote
Old 07-25-2013, 02:20 PM   #387
OICU812
Just a dude
OICU812's Avatar
Ok I think I found someone up here that has the oil.
To clarify for tranny and diff oil
Transmission: Redline MTL GL4 70W80
Rear Differential:
Motul Gear 300 GL4/GL5 75W90
These are the exact lubricants being discussed correct? No other additives or such for the motul for rear diff required?
Old 07-26-2013, 07:48 PM   #388
Scoobidude
Drives: DGM BRZ
Rear Differential:
yes iam curious bout this also. im looking to do mine soon
Scoobidude is offline   Reply With Quote
Old 07-26-2013, 10:00 PM   #389
nix
nix's Avatar
Drives: AVO BRZ
I've had very good results with Redline MTL + 80w140 gear oil combo.
This topic is about the synchros but the position of the selection plate is also very sensitive on this car. If you are having to blip every time when changing down to second, always missing gear when shifting up to 3rd, or your reverse lockout collar feels like it doesn't lift high enough, then you need to have this plate adjusted. You have to drop the gearbox and remove the bolts around the shifter/surround, then have someone sit in the car and test shift to determine the best position to bolt it down.
nix is offline   Reply With Quote
Old 08-06-2013, 03:50 AM   #390
Panman
Panman's Avatar
Drives: 86 GTS
Can you elaborate? DO you mean (as I think you do):
1. Undo the gearbox support collar (Where the Cusco, Perrin, etc mounts go) to allow the gearbox some movement so you can move it within the tolerance of the bolts for the collar
2. Take off the top plate which has the reverse lockout tab on it to give you a true range of movement.
3. When you have the best position by moving the box within the range of tolerance, tighten it all up again.
If not can you given a step-by-step?
Panman is offline   Reply With Quote
Old 08-08-2013, 08:07 AM   #391
nix
nix's Avatar
Drives: AVO BRZ
Yes and thanks for describing it properly.
Old 08-09-2013, 12:25 AM   #392
nix
nix's Avatar
Drives: AVO BRZ
Some pics
Official Australian Toyota 86/Subaru BRZ Owners Thread Maj3sty AUSTRALIA 148 09-02-2017 06:55 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
Must-read for Top Gear fans Sport-Tech Other Vehicles & General Automotive Discussions 16 03-28-2012 09:38 AM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 11:05 AM
