Old 08-09-2019, 12:29 PM   #379
SmoothIsSlow
Originally Posted by Pat View Post
Yeah, I heard someone saying 135*F +.
I think saying, "No way you have made it through the session" is a bit much. I ran 285 without issues. Other people here have seen 300. The Mobil 1 engineers say it's not an issue. But that's a discussion for other thread, I guess.
I'm going to send my 0-20 in for analysis after 8 track days and some high temps. Blackstone is still the one to go to for that, right?
Sorry to resurrect a thread from last month. @Pat did you ever get the results back? Were you running a cooler for your 0w20? What temperatures do you see?
I am running 5w30 in my BRZ with the powertrain and cooling completely stock, switching out the oil every other track day or so. Ambient temp rarely exceeds 80F in the PNW.
SmoothIsSlow is offline   Reply With Quote
Old 08-09-2019, 12:39 PM   #380
Pat
Pat's Avatar
Drives: 2023 BRZ
Yes, I got the results back. I was not running an oil cooler on with the oil that was analyzed. The report said it was in good condition. Slightly better than average, in fact. They recommended I go 9,000 miles on my next oil change. I regularly saw 270s on track. Keep in mind tracks here are at 5,000 feet above sea level so the car may not make as much power, and therefore heat, as where you are. But the thinner air is also not as effective in cooling the radiators.
The car now has 100+ track days on it with 87,000 miles. No issues with the engine. It makes a couple more HP than some other stock 86s on the same dyno. No smoke or any other obvious bad things.
The Following 2 Users Say Thank You to Pat For This Useful Post:
bhmax (08-09-2019), Rosticles (08-12-2019)
Old 09-13-2019, 03:03 AM   #381
rx3
In order to improve cooling performance I intend to run a second oil cooler in addition to this dual radiator (turbocharged BRZ). Is there a technical reason why this would not work?
rx3 is offline   Reply With Quote
Old 09-13-2019, 07:54 AM   #382
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
You will be asking too much from your oil pump. I would highly recommend against this. Maybe someone can chime in with a bit more technical detail.
Also, why would you need 2 coolers? Are you driving in first gear, low speed at over 7k rpm constantly? I just dont see a need for this....
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
Old 09-13-2019, 08:04 AM   #383
rx3
Well, it's just getting too hot, despite running the engine pretty rich.
It's autocross/hillclimb like racing with constant full throttle or full braking.
Old 09-13-2019, 12:25 PM   #384
rx3
An alternative would also be to install a second oil cooler in parallel (this wouldn't cause an additional pressure drop), but the piping would be more difficult (would need 2 additional T-connections - not sure whether those would be readily available).
Also, since I have an AVO kit I could also install an oil cooler in the return line of the turbocharger (which has its own pump). Probably not particularly effective but since it would at least increase the oil capacity this may be sufficient to keep the engine temperatures at bay, since one run never lasts longer than 3 minutes and 30 seconds.
Old 09-13-2019, 12:59 PM   #385
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
You could try the forester xt cooler paired with an air to oil cooler. That might help. Or just add venting to the hood and a normal larger oil cooler
MS, CSCS, TSAC-F, CPT
Old 09-15-2019, 09:53 AM   #386
rx3
Thanks. The safest bet would probably just be to use a larger radiator and a large oil cooler. (I've installed the beatrush alumnium underpanel with vents, but this didn't really help much.)
Old 04-27-2020, 02:15 PM   #387
imprezive
Drives: 2017 BRZ - WRB - PP
I may have missed this while trying to read through all 10 pages, but if this is used with a JR SC kit, does that eliminate the need for the smaller oil cooler included with the kit?
imprezive is offline   Reply With Quote
Old 05-01-2020, 12:15 AM   #388
jflogerzi
jflogerzi's Avatar
No that cooler I believe is for the rotrex unit. By default the kits do not come with engine oil coolers unless you buy it used and someone includes it with the package.
2013 Series 10 FRS #553
Old 07-06-2020, 02:42 AM   #389
FunnyGopher
Drives: 2015 BRZ Limited
Hiya everybody!
I recently ordered this from CSG, and I love it! However, I got to one of the last steps where I install the airbox back into the car. I ran into a problem where the AN fitting that's welded to the top of the radiator, when looking at it straight down from the front of the car, is angled about 20 degrees to the left. It's preventing the OEM airbox from sitting where it needs to to install it back in the car. If it had been welded perpendicular to the radiator, I believe there'd be enough clearance for the box to fit right. I don't know if this fitting is just welded incorrectly, or if I'm missing something. What does this fitting look like on other's radiators?
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 07-08-2020, 03:13 PM   #390
ayoshioka1
Drives: 2019 BRZ / E36 325is
sit rep:
jackson racing dual cooler installed late 2019.
Have done about 6 track days here in SoCal - 5 of them 90+ degree weather.
oil temps were holding pretty steady at 210-220 and water at 200-205.
using mobil1 0w-20
PB Streets of Willow CW 1:28.750
23 GR86 Halo MT Prem - Racecomp Engineering SS-2 - Sayber Designs - Voltex - RE71RS - Project Mu
ayoshioka1 is offline   Reply With Quote
The Following User Says Thank You to ayoshioka1 For This Useful Post:
mrg666 (07-11-2020)
Old 07-08-2020, 07:24 PM   #391
Grady
Grady's Avatar
When you say too hot what it the temp?
Old 07-08-2020, 08:39 PM   #392
ls1ac
ls1ac's Avatar
Late than never, we did what was suggested and put small oil to air coolers on the turbo return lines. (Small transmission coolers.) This was the hottest oil in the system. Therefor the greatest delta T for air exchange. It only helped a little but at that point we were looking for anything. Have since increased the radiator size fan size and scoops for the oil coolers, and we do have two in a row but we have a dry sump..
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 06:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 12:26 PM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 03:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 12:04 PM
