Old 02-21-2021, 11:19 PM   #3893
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Originally Posted by cjd View Post
Strat already noted why this isn't quite right. I thought Sti was called out at some point as an example of a manufacturer performance part line not included, npbut maybe it was just TRD... Rules are a pain the way they're written. Anyway, still legal in STX for different reasons. At least the lip, skirts, spats. Skirts are nice cone protection.
Yes, STi catalog stuff is not legal.
I'm not talking about that, I'm talking about the part just before it (that I quoted), stating that parts "listed in the vehicle manufacturer’s US accessory catalog" are legal, hence why I have a 2017 Subaru BRZ accessory catalog showing the lip kit.
Breezio is offline   Reply With Quote
Old 03-08-2021, 12:49 PM   #3894
Victarion
Drives: 2019 brz
Anybody have any tips on pressing out bushing in spc rear lower control arm and installing diftech bushing?
Victarion is offline   Reply With Quote
Old 03-08-2021, 06:53 PM   #3895
strat61caster
strat61caster's Avatar
If you don't havea a drill press or vice a local machine shop can probably do it in <15 minutes for<$75
ineedyourdiddly
Old 03-09-2021, 09:40 AM   #3896
Victarion
Drives: 2019 brz
Appreciate it yeah I ended up getting it out with vice was just harder press out than I thought would be.
Old 03-12-2021, 10:30 PM   #3897
Autoenthusiastasm
Drives: 2013 BRZ Limited - stock
I’ll be installing adjustable coil overs. I’m assuming I need to put the side pieces in my trunk to avoid illegal weight loss. How do you get access to adjust your shocks. Do you notch the panels.
Autoenthusiastasm is offline   Reply With Quote
Old 03-12-2021, 11:08 PM   #3898
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
You may notch the panels according to Section 13 in the Street Category which carries forward into Street Touring. Here is the quote:
13.1 AUTHORIZED MODIFICATIONS
If a modification is not specifically authorized in this or previous Sections of these Rules, it is not allowed.
The addition of small holes for attachment hardware for authorized modifications is implicit (e.g., holes for fasteners to mount additional gauges, holes for brackets to mount shock absorber remote reservoirs). However, these holes may serve no other purpose.
also see this section in the rules too:
F. Spare tires, tools, and jacks may be removed. Any fastening hardware and/or other pieces that can no longer be firmly secured in the absence of the spare tire may be removed if necessary to ensure compliance with
76 — 2021 SCCA® National Solo® Rules
13. Street Category
Section 3.3.3.B.1, Safety Inspection Requirements.
I'm pretty sure that you're covered between the two.
RongTurnRacing is offline   Reply With Quote
Old 03-12-2021, 11:58 PM   #3899
cjd
cjd's Avatar
Drives: 2017 BRZ
You do need the foam bits, but not the cover, tools, not spare and mounting hardware.
Old 03-13-2021, 01:11 AM   #3900
strat61caster
I just push the flap to the side, no need to cut anything.
ineedyourdiddly
Old 03-14-2021, 10:18 AM   #3901
Autoenthusiastasm
Just pushing the flap back was all I needed for the install, no need to remove panels. Thanks
Old 04-15-2021, 02:21 PM   #3902
e1_griego
e1_griego's Avatar
Drives: Many
Really fun battle at the Vegas Tour this weekend.
Not sure if Kate or Jonathan Mudge post here but I had a great time despite dirty runs both days.
e1_griego is offline   Reply With Quote
Old 04-19-2021, 01:41 PM   #3903
bslate3
Drives: 2015 CWP BRZ
Anyone tried out the new Kumho V730’s? It’s way cheaper than Yoko’s. But will it come close to being a competitive tire?
bslate3 is offline   Reply With Quote
Old 04-19-2021, 03:55 PM   #3904
Chuckls
Moutain Runner
V730 was plenty fast. S2k in my class running it and he's consitently laying down fast times.
Chuckls is offline   Reply With Quote
Old 04-19-2021, 07:06 PM   #3905
sifl
sifl's Avatar
Drives: 2013 Subaru BRZ Premium MT
My co-driver and I tried out the new Kumho tires this past weekend. We did back-to-back testing with the Yokohama tires, same course, same conditions.
On a 40 second course, asphalt, in 55 degree weather, the Yokohama tires were faster for us. We had some trial and error issues with tire pressures for the Kumho tires, but we felt we had it set petty well after four runs for each of us driving.
We'll try them out again in our next event and see how they compare.
Sent from my SM-G973U using Tapatalk
sifl is offline   Reply With Quote
Old 04-23-2021, 06:39 PM   #3906
ka-t_240
I don't think Mudge is on here that I have seen, but I race w/ him in Montana when I go out there from MN.
ka-t_240 is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
