View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 03-24-2014, 09:12 PM   #3865
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I'm at ~800 miles on mine and I've been hearing it at idle since around 400-500 miles. I only use 93 octane BP gas. Next gas tank will be Exxon 93. Maybe that will make it go away.
Another issue I've noticed is that on cold starts (after sitting overnight/8 hours) the car will sound like it misfires and it'll pop, like its running rich. After a few seconds, it sounds normal. I doubt that I already have DI seal failure at 800 miles, but its definitely odd.
Bobblehead is offline   Reply With Quote
Old 03-24-2014, 09:43 PM   #3866
rick s
rick s's Avatar
Drives: 2013 FR-S Ultramarine 6MT
Originally Posted by Muskokan View Post
It's been pretty long since that oct revision, think they are throwing in the towel?
ABSOLUTELY!
On my third pump and the crickets remain. Maybe they could throw in some cash for headers and performance exhaust to drown them out at idle.
Fat chance, most likely will have to live with it, really depressing.
rick s is offline   Reply With Quote
Old 03-24-2014, 11:26 PM   #3867
Wilcats
Drives: Toyota 86
Would wrapping the pipes of the HPFP with Thermal wraps tone down the chirping noise?
Eight - Six
Wilcats is offline   Reply With Quote
Old 03-27-2014, 03:09 PM   #3868
twag4
Drives: frs
Gawd I wish toyota or Subaru or someone would pull their heads out of their arse and fix this noise problem already. I have the October 2013 pump and crickets went from light to incredibly obnoxious yesterday. The actual chirp is like a whistle now, that still chirps or pulsates. Holy God it is ridiculous.!I have a 10 series FRS and it is audible with the stereo volume on 44 playing classic rock.
twag4 is offline   Reply With Quote
Old 03-27-2014, 03:45 PM   #3869
theyhc
Drives: 2014 Scion FR-S
Originally Posted by Apex_BRZ View Post
Has anyone determined whether or not this is actually a PROBLEM rather than just a NOISE?
Mine does it, of course, but I've just been ignoring it. Car feels fine. Noise can be a bit irritating, but it only does it at idle so I'm not sure I honestly care as long as it isn't actually hurting anything.
Mine started doing it a couple of days ago. At first, I didn't really think too much into it, but then after a while, it was noticeable. I called my local dealer, and of course, they never "heard of the problem" which is horse shit because it's been an issue since launch.
But as far as it being a problem, it isn't. It's honestly just a loud/really loud fuel pump. I know that sounds really "generic" as far as an answer, but it's true. My cousin works for Toyota and he's been dealing with this issue for a long while now. There's a TSB, etc, that has gone around with his dealership, but it's a well known issue obviously. It honestly comes down to it being a loud fuel pump like I said. I know this isn't something anyone wants to hear, but it's true. I didn't like the answer either since I JUST got mine a month ago, but what can we do. It's still a first gen car so all we can do is wait and see what will happen. Who knows, maybe Toyota will see how loyal we are by sticking with this car and get us brand new ones when everything is taken care of! Lol!
theyhc is offline   Reply With Quote
Old 03-27-2014, 03:52 PM   #3870
damaster32
Drives: 2014 BRZ Limited
This has probably been asked before but would an aftermarket fuel pump solve the issue?
damaster32 is offline   Reply With Quote
Old 03-27-2014, 04:16 PM   #3871
strat61caster
strat61caster's Avatar
Potentially.
There are no aftermarket alternatives, if you 'stumble across one' that we 'haven't seen before' odds are it's the fuel pump that sits in the gas tank that is standard across many cars and is not the 'problem' fuel pump.
This isn't the only fuel pump to make funny noises.
http://rdx.acurazine.com/forums/showthread.php?t=861584
http://www.mdxers.org/forums/94-new-...ise-level.html
http://www.sciencedirect.com/science...77042812030261
http://papers.sae.org/2013-01-0253/
ineedyourdiddly
Old 03-28-2014, 06:10 PM   #3872
FRSure
Drives: Toyota
So.... My 605 miles 2014 Scion FRS started chirping today.... Using 93 Shell VPower.. :<
FRSure is offline   Reply With Quote
Old 03-28-2014, 07:48 PM   #3873
totally
Drives: 1998 Prelude SH, Scion FRS
2000 + miles on new (2nd replacement) pump
I'm trying not to be too hopeful. Got the this pump installed around 42K. Will check back after another 1000 or when they return.
To all those who say "Don't worry about it," consider:
1. If it's "normal", Toyota should have given buyers a heads up. It sure didn't chirp when I bought it. As much as I like to drive the car, probably would have held off until the noise was fixed if I'd known.
2. It sounds like a belt problem that the owner can't be bothered to fix -- just rides around in a broken car.
3. It hurts the resale value significantly; I'd say by at least a couple of thousand.
Anyway, I've got my fingers crossed.
totally is offline   Reply With Quote
Old 03-28-2014, 11:17 PM   #3874
PNW FRS
PNW FRS's Avatar
Ethanol-Free - Seems to Reduce Chirping
So, on a whim, I filled up a few days ago with a 50/50 mix of 91 octane (with up to 10% Ethanol) and 87 octane (no Ethanol) and within about 50 miles, noticed that the "chirping" sound had dissipated almost to a point where I had to really listen close to hear the sound.
Using the post about "Pure Gas" locations, found a place in Olympia (on Thurston Ave) that supposedly has 92 octane w/o Ethanol.
Going to try that next to see how it might help with that dang chirping sound.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 03-30-2014, 12:57 AM   #3875
jhh3000
Drives: BRZ Limited 6MT
Wanted to provide an update: seems like they still haven't resolved this issue yet. I've had crickets since I bought the car. Had the HPFP replaced at 9500 miles a few weeks back, now car is nearing 11000 miles and the crickets are back. Weather is warming up but doesn't seem to have much of an effect.
jhh3000 is offline   Reply With Quote
Old 03-30-2014, 01:22 AM   #3876
tailspin
tailspin's Avatar
Drives: Honda
I've noticed a lot of people stick with one brand and octane for their cars and only a few have filled up with any brand gas they come across. It *seems* like the few people who fill up at random gas stations have reported less chirps.
Could it be possible that this car can benefit by filling up with different brands of fuel instead of being loyal to one or two brands of fuel?
tailspin is offline   Reply With Quote
Old 03-30-2014, 01:35 AM   #3877
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
I don't have that many miles on my 2014 yet (2,500m/4000km) and have always used Shell 91 (no Ethanol) and so far a quiet fuel pump
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 03-30-2014, 01:47 AM   #3878
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
2014 at 2500 miles and I hear it constantly now
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 04:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
